  • 2187阅读
[你问我答]一道土力学题,求高人解答 [复制链接]
离线zhangxk
只看楼主 倒序阅读 使用道具 楼主  发表于: 2011-12-01
    A sample of clay is set up in a triaxial apparatus and anisotropically compressed, without allowing radial strains, to a vertical effective   stress          σ‘ = 156 kPa. It is found that the value of the earth pressure coefficient (ratio of horizontal to vertical effective stresses) measured in this process is    Ko = 0.65. The sample is then unloaded to a vertical effective stress of 100 kPa (point A) and allowed to reach equilibrium with zero pore pressure. It is found that Ko is now equal to 1.0.
    The deviator stress is now increased to 60 kPa without allowing drainage (point B). Without changing the total stresses, drainage is now permitted, and the pore pressure is allowed to dissipate. It is observed that yield occurs during this process (point C) and that the final equilibrium state at zero pore pressure is point D.
     Estimate the axial and radial strains occurring on.each stage AB, BC, and CD of the test. Assume that the behaviour of the clay can be described by the Cam clay model with values of soil parameters M = 0.9, A= 0.19, K = 0.06, N = 2.88, and G' = 2500 kPa.
      Compare the strengths that would be measured in conventional drained and undrained triaxial compression of the clay starting from state D.
只看该作者 1楼 发表于: 2011-12-02
先翻译过来啊。
离线zhangxk
只看该作者 2楼 发表于: 2011-12-02
题目太长了,这是David Muir Wood那本临界土力学剑桥模型那章的课后练习题。
离线erimkcgs
只看该作者 3楼 发表于: 2011-12-02
用剑桥粘土模型参数估算各变形阶段的轴向与径向应变量?
得过且过
离线mayan1989
只看该作者 4楼 发表于: 2011-12-02
这哥们估计是申请英国的岩土工程硕士了。
这题我不会,帮不了你。
不过,祝你一切顺利,加油。
离线zhangxk
只看该作者 5楼 发表于: 2011-12-02
是算各阶段轴向和径向变形的,谢谢各位了,问题解决了。先根据轴压和围压算出偏应力和有效应力,代入剑桥模型算出先期固结压力,画出屈服面。AB,BC阶段在屈服面内,只有弹性变形;CD阶段总应力不变,孔隙水压减到0,有效应力增加。再利用剑桥模型中应力应变本构关系就算出来了。这是大概思路。
离线lizh0306
只看该作者 6楼 发表于: 2011-12-09
离线weishi
只看该作者 7楼 发表于: 2011-12-19
回 5楼(zhangxk) 的帖子
zhangxk:是算各阶段轴向和径向变形的,谢谢各位了,问题解决了。先根据轴压和围压算出偏应力和有效应力,代入剑桥模型算出先期固结压力,画出屈服面。AB,BC阶段在屈服面内,只有弹性变形;CD阶段总应力不变,孔隙水压减到0,有效应力增加。再利用剑桥模型中应力应变本构关系就算出来了。 .. (2011-12-02 19:00)
嗯,经典,学习了
