  • 8758阅读
  • 1回复
[转载]冈萨雷斯 数字图像处理 MATLAB 代码1_readme [复制链接]
离线mm85171
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-12-29
% README file for the DIPUM Toolbox. dm0R[[7
% ~8Fk(E_
% These MATLAB functions were created for the book Digital Image =!A_^;NQf
% Processing Using MATLAB (DIPUM), by R.C. Gonzalez, R.E. Woods, and %g$o/A$
% S.L. Eddins, Prentice Hall, 2004, ISBN 0130085197.  The functions +4~_Ei[i
% supplement and extend the image processing functionality of MATLAB ./Zk`-OBT
% and the Image Processing Toolbox, both offered by The MathWorks. Lnl(2xD
% K hR81\
% The free version of the DIPUM Toolbox nsC3
% ------------------------------------- Xf]d. :
% The free version of the DIPUM Toolbox contains only executable 8U"v6S~A%Q
% MATLAB P-files.  P-files may be executed as MATLAB functions just K:[F%e
% as M-files.  Unlike M-files, however, neither the help text nor the epe)a
% source code is accessible.  Complete source code listings for all oUlY?x1
% functions are included in the book. /)>3Nq4Zx
% Ms#M+[a
% The registered version of the DIPUM Toolbox r.&Vw|*>
% ------------------------------------------- [#vH'y
% The registered version of the DIPUM Toolbox contains M-files with yjX9oxhtL
% readable source code and help text.  Users who want the M-files in (_]~wi-,
% electronic form may obtain, for a small fee, a password allowing them a(X@Q8l:
% to download the registered toolbox.  More information about obtaining `UyG_;
% the registered toolbox version is available at the book's web site: '3tCH)s
% 1W LXM^ 4
%    http://www.imageprocessingbook.com/index_dipum.htm !sP {gi#=
% qOtgve`jX
% Requirements kd(8I_i@
% ------------ `wEb<H
% This initial release of the DIPUM Toolbox was developed and tested 20h, ^
% using MATLAB 6.5 and the Image Processing Toolbox 3.1.  The DIPUM zT]8KA
% Toolbox is not supported for use with earlier versions of MATLAB or lIS-4QX1
% the Image Processing Toolbox.  Most DIPUM functions require the %JBz5G
% Image Processing Toolbox.  )F>#*P
% R4cM%l_#W
% The DIPUM Toolbox works with all MATLAB platforms.  It includes one ~L\z8[<C
% MEX-file (UNRAVEL, which is used for Huffman decoding).  Compiled z'n:@E
% binaries for this MEX-file are provided for all MATLAB platforms. b94DJzL1z
% {$ JYw{a
% Installation %)W2H^
% ------------ &)ChQZA
% To install the DIPUM Toolbox, place the folder containing the Do7Tj
% functions on a local hard drive or a network drive accessible to UKvWJnz
% your computer, and then include the folder location in the MATLAB xGg )Y#
% path.  To set the MATLAB path, start MATLAB and then select the F^BS/Yag
% File/Set Path menu item.  Then select Add Folder.  Use the I3I/bofz
% navigation window to select the folder containing the functions. lvz7#f L~
% Click OK and then click Save.  The functions will then be ready for VA_PvL.9
% use within MATLAB. }!r|1$,kL
% <{cQM$ #
% Copyright _C?hHWSf"
% --------- E6ElNgL
% The DIPUM Toolbox is protected under U.S. and international copyright hx%v+/
% law.  You may not transfer, publish, disclose, display, or otherwise t\,PB{P:J
% make available either the free or the registered versions of the DIPUM }2.`N%[
% Toolbox to other people. In particular, you may not place either /nNN,hz
% version of the DIPUM Toolbox on an Internet site, a computer bulletin J=I:CD%
% board, or an anonymous ftp directory from which it could be downloaded PiIpnoM
% or copied by other people.  Anyone may obtain the free version 2r?G6D|
% directly from the book's web site. xs bE TP?
% WPMSm<[
% Disclaimer of Warranty 0&|\N ? 8_
% ---------------------- E,U+o $
% The DIPUM Toolbox source code is furnished "as is." Neither the $|@@Qk/T
% authors nor the publisher of Digital Image Processing Using MATLAB <0&*9ZeD
% make or imply any warranties that the DIPUM Toolbox software is free 5x4yyb'
% of error, that it is consistent with any particular standard of Id .nu/
% merchantability, or that it will meet your requirements for any pJ"qu,w
% particular application. The authors accept no responsibility for any ?M9=yA
% mathematical or technical limitations of the functions that make up ChPmX+.i_
% the DIPUM Toolbox. The DIPUM Toolbox should not be relied upon for vMH
% solving a problem whose incorrect solution could result in injury to a :q% M_
% person or loss of property. Neither the authors nor the publisher of )'#A$ Fj
% Digital Image Processing Using MATLAB shall in any event be liable for WlC:l
% any damages, whether direct or indirect, special or general, k"iOB-@B+
% consequential or incidental, arising from use of the DIPUM Toolbox. *fS"ym@
% 3$>1FoSk
% The DIPUM Toolbox was not created by The MathWorks, nor is it m@v\(rT.
% supported by The MathWorks. IK=a*}19L
% |&)dh<
% About Version 1.1.4 h2]P]@nW;W
% ------------------- xj;H&swo
% Release date: 15-July-2006 ~IBP|)WA-
% MaQqs=
% Changes: 9vc2VB$
%  * bayesgauss:  Corrected typo in help text. }@q`%uzi
%  * ifrdescp:    Corrected typo in help text. 6}Ci>_i4#
%  * im2jpeg:    Corrected bug in end-of-block computation. 37.S\ gO]
%  * imnoise2:    Corrected bug in the lognormal computation. H=vUYz
%  * mahalanobis: Corrected typo in help text. "_NN3lD)X
%  * pixeldup:    Corrected typo in comment. R"t,xM
%  * rgb2hsi:    Corrected typo in comment. ,i`,Oy(BI
% Hd ={CFip
% About Version 1.1.3 A[{yCn`tM
% ------------------- ,Ah;A[%?~
% Release date: 15-Dec-2004  {Gk1vcq
% ZG8DIV\D7
% Changes: plstZ,#j
%  * bayesgauss: Corrected bug in the optimized version that was 08\, <9
%                released in DIPUM Toolbox 1.1. eJX9_6m-
% _|I#{jK
% About Version 1.1.2 0 ZKx<]!
% ------------------- $Sip$\+*
% Release date: 04-Nov-2004 2-v%`fA
% `kXs;T6&
% Changes: ]Q3ADh
%  * bayesgauss: Revised help text and some comments in the code. %pL''R9VF
% S g![Lsj
%  * bsubsamp:  Corrected indexing errors that occurred under some :J&oX <nF^
%                conditions. Ka V8[|Gn,
% MH\dC9%p
%  * ifrdescp:  Revised help text. \V~eVf;~
% Moza".fiN
%  * imnoise3:  Revised help text. j>"@,B g*
% J<h $ wM
%  * lpfilter:  Removed a superfluous output variable. `l[c_%Bm
% D'Df JwA
%  * statxture:  Removed unnecessary brackets surrounding output v^*K:#<Q!
%                variable. 3,qr-g|;jM
% ;$wVu|&
% About Version 1.1.1 !?h;wR
% ------------------- bJTBjS-7
% Release date: 04-Jun-2004 iz PDd{[
% z$. 88 ^
% Changes: Y\8)OBZ
%  * Added missing ice.fig file to toolbox distribution. O m2d .7S
% ?NsW|w_
% About Version 1.1 WP'!*[z
% ----------------- ;h
% Release date: 10-Mar-2004 ;dgp+
% 0GCEqQy8
% Changes: PKiy5D*8p
%  * Function bayesgauss was modified to improve performance. =-n}[Y}A
% U!\.]jfS
% About Version 1.0 uHzU-FZ|B
% ----------------- GGs}i1m
% Release date: 01-Dec-2003 f r6 fj
% OA;XiR$xP
% This initial release of the DIPUM Toolbox coincides with the Ai3*QX
% initial publication of Digital Image Processing Using MATLAB. I,vJbvvl!
% c`w}|d]mC
% Copyright 2002-2006 R. C. Gonzalez, R. E. Woods, & S. L. Eddins 4vB<fPN
% Digital Image Processing Using MATLAB, Prentice-Hall, 2004 $uVHSH5l
% $Revision: 1.15 $  $Date: 2006/07/15 20:43:48 $ ENs&RZ;
离线bad1985
只看该作者 1楼 发表于: 2008-08-06
goodsoftware
One world, one dream!
