  • 6869阅读
  • 0回复
[转载]冈萨雷斯 数字图像处理 MATLAB 代码 [复制链接]
离线mm85171
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-12-29
卖家:xjminga@126.com
商品名称:冈萨雷斯 数字图像处理 MATLAB 代码
商品描述:% README file for the DIPUM Toolbox. .UyE|t4
% %>_[b,
% These MATLAB functions were created for the book Digital Image sFU< PgV
% Processing Using MATLAB (DIPUM), by R.C. Gonzalez, R.E. Woods, and r8k(L{W
% S.L. Eddins, Prentice Hall, 2004, ISBN 0130085197.  The functions V35Vi6*p
% supplement and extend the image processing functionality of MATLAB |rmelQ-
% and the Image Processing Toolbox, both offered by The MathWorks. 7y=>Wa?T[
% 4=PjS<Lu8
% The free version of the DIPUM Toolbox E-LkP;
% ------------------------------------- m 2H4V+M+
% The free version of the DIPUM Toolbox contains only executable M  .#}
% MATLAB P-files.  P-files may be executed as MATLAB functions just JJ.8V72;!Z
% as M-files.  Unlike M-files, however, neither the help text nor the 3? {AGJ1
% source code is accessible.  Complete source code listings for all W{p}N
% functions are included in the book. k.T=&0J_1
% LiJYyp
% The registered version of the DIPUM Toolbox 7Z-j'pq
% ------------------------------------------- @sXFu[!U
% The registered version of the DIPUM Toolbox contains M-files with Z%T Ajm
% readable source code and help text.  Users who want the M-files in _1" ecaA
% electronic form may obtain, for a small fee, a password allowing them Ts iJK
% to download the registered toolbox.  More information about obtaining 9hp&HL)BOa
% the registered toolbox version is available at the book's web site: |diI(2w
% *4,Q9K_
%    http://www.imageprocessingbook.com/index_dipum.htm qY_qS=H^
% _ _Of0<
% Requirements Vns3859$8
% ------------ =KRM`_QShg
% This initial release of the DIPUM Toolbox was developed and tested ~^t@TMk$
% using MATLAB 6.5 and the Image Processing Toolbox 3.1.  The DIPUM ]5!3|UYS
% Toolbox is not supported for use with earlier versions of MATLAB or H DVimoOq
% the Image Processing Toolbox.  Most DIPUM functions require the OG\i?N
% Image Processing Toolbox.  [K{{P|(q
% )0{`}7X
% The DIPUM Toolbox works with all MATLAB platforms.  It includes one $-4](br|
% MEX-file (UNRAVEL, which is used for Huffman decoding).  Compiled [m~J6WB
% binaries for this MEX-file are provided for all MATLAB platforms. gesbt
% > A#5` $i
% Installation wjarQog5Y
% ------------ &$"#hGg
% To install the DIPUM Toolbox, place the folder containing the =u~nLL
% functions on a local hard drive or a network drive accessible to XN<SKW(H3
% your computer, and then include the folder location in the MATLAB dBWny&
% path.  To set the MATLAB path, start MATLAB and then select the K+g[E<x\=
% File/Set Path menu item.  Then select Add Folder.  Use the b F=MQ
% navigation window to select the folder containing the functions. Q PH=`s
% Click OK and then click Save.  The functions will then be ready for s.3"2waZ=T
% use within MATLAB. A=|XlP$6
% 3G} )$y3m
% Copyright 3^xUN|.F*V
% --------- j50vPV8m
% The DIPUM Toolbox is protected under U.S. and international copyright {I#_0Q,i
% law.  You may not transfer, publish, disclose, display, or otherwise MJn-] E
% make available either the free or the registered versions of the DIPUM J~~\0 u
% Toolbox to other people. In particular, you may not place either _k84#E0
% version of the DIPUM Toolbox on an Internet site, a computer bulletin  56.!L
% board, or an anonymous ftp directory from which it could be downloaded O&%'j
% or copied by other people.  Anyone may obtain the free version 0.GFg${v`
% directly from the book's web site. +ikSa8)*i
% z2=bbm:
% Disclaimer of Warranty g` rr3jP
% ---------------------- V>6klA}o
% The DIPUM Toolbox source code is furnished "as is." Neither the =]5tYIU
% authors nor the publisher of Digital Image Processing Using MATLAB h$S#fY8
% make or imply any warranties that the DIPUM Toolbox software is free  T:}Q3
% of error, that it is consistent with any particular standard of Y\xEPh
% merchantability, or that it will meet your requirements for any ~o}:!y
% particular application. The authors accept no responsibility for any Y$'j9bUJ
% mathematical or technical limitations of the functions that make up >7U/TVd&
% the DIPUM Toolbox. The DIPUM Toolbox should not be relied upon for CEy\1D
% solving a problem whose incorrect solution could result in injury to a 1HJ: ?]
% person or loss of property. Neither the authors nor the publisher of <'y<8gpM
% Digital Image Processing Using MATLAB shall in any event be liable for 3bEcKA_z(
% any damages, whether direct or indirect, special or general, }\4yU=JP K
% consequential or incidental, arising from use of the DIPUM Toolbox. y]9R#\P/
% 24sMX7Q,i
% The DIPUM Toolbox was not created by The MathWorks, nor is it \i.]-k
% supported by The MathWorks. =~^b
% >CB-a :
% About Version 1.1.4 =?sG~
% ------------------- ^W |YE72Y
% Release date: 15-July-2006 /\J0)V
% kUT2/3Vi
% Changes: @!ChPl
%  * bayesgauss:  Corrected typo in help text. X2w)J?pv
%  * ifrdescp:    Corrected typo in help text. WP<L9A
%  * im2jpeg:    Corrected bug in end-of-block computation. X+vKY
%  * imnoise2:    Corrected bug in the lognormal computation. Xr*I`BJ
%  * mahalanobis: Corrected typo in help text. ]4:QqdV
%  * pixeldup:    Corrected typo in comment. 1v@#b@NXM7
%  * rgb2hsi:    Corrected typo in comment. K.tNV{OL
% W/'1ftn?D
% About Version 1.1.3 W"{Ggk `
% ------------------- fI.|QD*$b
% Release date: 15-Dec-2004 l1KMEGmG
% Y2|i>5/|<
% Changes: ]ua3I}_B6v
%  * bayesgauss: Corrected bug in the optimized version that was 9#8vPjXW}.
%                released in DIPUM Toolbox 1.1. hA=uoe\
% l{By]S
% About Version 1.1.2 y:G%p3h)[
% ------------------- ?d')#WnC
% Release date: 04-Nov-2004 m$0W^u
% +NlnK6T/
% Changes: EOPx 4+o
%  * bayesgauss: Revised help text and some comments in the code. F>;Wbk&[|
% CTMC78=9}
%  * bsubsamp:  Corrected indexing errors that occurred under some U)}]Z@I-
%                conditions. Nc[@QC{
% )&Ii! tm3
%  * ifrdescp:  Revised help text.  A l[ZU
% yi7.9/;a
%  * imnoise3:  Revised help text. wO??"${OH
% q'D Ts9Bj
%  * lpfilter:  Removed a superfluous output variable. R >xd*A
% #~0Nk6*u
%  * statxture:  Removed unnecessary brackets surrounding output Y;'<u\^M"
%                variable. J}|X
% l u=a e<M
% About Version 1.1.1 \C~X_/sg
% ------------------- wMa8HeBE\
% Release date: 04-Jun-2004 )g5?5f;
% %ms%0%
% Changes: ;0DoZ
%  * Added missing ice.fig file to toolbox distribution. U-|]A\`)I
% 9>RkFV
% About Version 1.1 /VR~E'Cy%
% ----------------- $b8[/],
% Release date: 10-Mar-2004 g_>&R58
% emSq{A
% Changes: y^2#;0W
%  * Function bayesgauss was modified to improve performance. r. 82RoG?G
% qHt/,w='Q
% About Version 1.0 E@}F^0c
% ----------------- NAYLlW}A
% Release date: 01-Dec-2003 ?Uql 30A
% *V>?m6y/
% This initial release of the DIPUM Toolbox coincides with the U}92%W?
% initial publication of Digital Image Processing Using MATLAB. 7FX4|]
% hBgE%#`s
% Copyright 2002-2006 R. C. Gonzalez, R. E. Woods, & S. L. Eddins osC?2.
% Digital Image Processing Using MATLAB, Prentice-Hall, 2004 ^WA7X9ed
% $Revision: 1.15 $  $Date: 2006/07/15 20:43:48 $ .7iRV
商品价格:55
邮费信息:卖家承担邮费
