  • 1847阅读
  • 1回复
为什么我的桩在显示位移的时没有横向位移呢?求高手指教 [复制链接]
离线wc200303
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-02-16
为什么我的桩在显示位移的时候是竖直往下的,怎么没有横向位移呢?求高手指教
set log on
plot show
plot block group
;1
gen zone brick &
p0 0 0 -8 p1 30 0 -8 p2 0 16 -8 p3 0 0 4 &
size 5 8 8 group 1 rat 0.7 1 0.7
;2
gen zone brick &
p0 30 0 -8 p1 90 0 -8 p2 30 16 -8 p3 30 0 4 &
p4 90 16 -8 p5 30 16 4 p6 90 0 22 p7 90 16 22 &
size 60 8 8 group 1 rat 1 1 0.7
;3
gen zone brick &
p0 0 0 4 p1 30 0 4 p2 0 16 4 p3 0 0 7 &
size 5 8 6 group 3 rat 0.7 1 1.4
;4
gen zone brick &
p0 30 0 4 p1 33 0 4.9 p2 30 16 4 p3 30 0 7 &
p4 33 16 4.9 p5 30 16 7 p6 33 0 18 p7 33 16 18 &
size 3 8 6 group 3 rat 1 1 1.4
;5
gen zone brick &
p0 33 0 4.9 p1 40 0 7 p2 33 16 4.9 p3 33 0 18 &
p4 40 16 7 p5 33 16 18 p6 40 0 18 p7 40 16 18 &
size 7 8 6 group 3 rat 1 1 1.4
;6
gen zone brick &
p0 40 0 7 p1 45 0 8.5 p2 40 16 7 p3 40 0 18 &
p4 45 16 8.5 p5 40 16 18 p6 45 0 22 p7 45 16 22 &
size 5 8 6 group 3 rat 1 1 1.4
;7
gen zone brick &
p0 45 0 8.5 p1 60 0 13 p2 45 16 8.5 p3 45 0 22 &
p4 60 16 13 p5 45 16 22 p6 60 0 22 p7 60 16 22 &
size 15 8 6 group 3 rat 1 1 1.4
;8
gen zone brick &
p0 60 0 13 p1 65 0 14.5 p2 60 16 13 p3 60 0 22 &
p4 65 16 14.5 p5 60 16 22 p6 65 0 25 p7 65 16 25 &
;9
gen zone brick &
p0 65 0 14.5 p1 90 0 22 p2 65 16 14.5 p3 65 0 25 &
p4 90 16 22 p5 65 16 25 p6 90 0 25 p7 90 16 25 &
size 25 8 6 group 3 rat 1 1 1.4
range name=Chuang group 1
range name=Poti group 3
gen separate 3
int 1 wrap 1 3
model m
prop bulk 3.77e6 shear 1.60e6 den 1480 fri 15 coh 23e4
int 1 prop ks 4e7 kn 4e9 fric 15
fix x y z range z -7.9 -8.1
fix y range y -0.1 0.1
fix y range y 15.9 16.1
fix x range x -0.1 0.1
fix x range x 89.9 90.1
set large
set grav 0 0 -10
solve
ini xdis 0.0 ydis 0.0 zdis 0.0
ini xvel 0 yvel 0 zvel 0
ini state 0
m m
prop bulk 4.2e7 shear 1.97e7 den 1645 fri 25 coh 23e3 range Poti
prop bulk 1e9 shear 1.60e7 den 1800 fri 25 coh 23e3 range Chuang
sel pile id=1 begin=(34,2,18) end=(34,2,-6) nseg=8
sel pile id=2 begin=(34,4,18) end=(34,4,-6) nseg=8
sel pile id=3 begin=(34,6,18) end=(34,6,-6) nseg=8
sel pile id=4 begin=(34,8,18) end=(34,8,-6) nseg=8
sel pile id=5 begin=(34,10,18) end=(34,10,-6) nseg=8
sel pile id=6 begin=(34,12,18) end=(34,12,-6) nseg=8
sel pile id=7 begin=(34,14,18) end=(34,14,-6) nseg=8sel pile id=22 begin=(35,1,18) end=(35,14,-6) nseg=8
sel pile id=8 begin=(35,3,18) end=(35,2,-6) nseg=8
sel pile id=9 begin=(35,5,18) end=(35,4,-6) nseg=8
sel pile id=10 begin=(35,7,18) end=(35,6,-6) nseg=8
sel pile id=11 begin=(35,9,18) end=(35,8,-6) nseg=8
sel pile id=12 begin=(35,11,18) end=(35,10,-6) nseg=8
sel pile id=13 begin=(35,13,18) end=(35,12,-6) nseg=8
sel pile id=14 begin=(35,15,18) end=(35,14,-6) nseg=8
sel pile id=15 begin=(36,2,18) end=(36,2,-6) nseg=8
sel pile id=16 begin=(36,4,18) end=(36,4,-6) nseg=8
sel pile id=17 begin=(36,6,18) end=(36,6,-6) nseg=8
sel pile id=18 begin=(36,8,18) end=(36,8,-6) nseg=8
sel pile id=19 begin=(36,10,18) end=(36,10,-6) nseg=8
sel pile id=20 begin=(36,12,18) end=(36,12,-6) nseg=8
sel pile id=21 begin=(36,14,18) end=(36,14,-6) nseg=8sel pile prop emod=8.0e10 nu=0.3 xcarea=0.7854 xcj=0.0 xciz=0.0 per=3.14 &
cs_sk=1.3e11 cs_scoh=0.0 cs_sfric=10.0 cs_nk=1.3e11 cs_ncoh=0.0 &
cs_nfric=0.0 cs_ngap=off
离线小珍鹏
只看该作者 1楼 发表于: 2012-10-25
请问楼主桩的参数怎么选取?
