  • 2338阅读
  • 8回复
盾构隧道施工引起的地表沉降及现场监控.pdf [复制链接]
离线土老帽
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-01-02
离线ty87936452
只看该作者 1楼 发表于: 2008-01-10
Thank you very much...
离线heter01
只看该作者 2楼 发表于: 2008-04-07
好东西,,下载了
离线liberty521
只看该作者 3楼 发表于: 2010-05-08
下载了,学习一下先
离线wind603
只看该作者 4楼 发表于: 2010-05-22
,谢了楼主,好东西啊
离线wenzhanzhen
只看该作者 5楼 发表于: 2010-10-18
During the construction of shie ld tunnels,support pressure is usually applied at the work face to prevent
excessive tunneling—induced soil movement or collapse.However,the selection and control of appropriate support
pressure is difficult due to variation of soil conditions and uncerlainty in construction.Support pressure should be
controlled SO that it is not SO low as to cause face collapse and not SO high as to induce ground hogging.Numerical
simulation is employed to study how the soil parameter and ground water affect the support pressure,and to give the
proper support pressure at the excavation face in a case study.
Keywords:shield tunnel;excavati‘on face;numerical solution;support pressure
离线wenzhanzhen
只看该作者 6楼 发表于: 2010-10-18
离线wenzhanzhen
只看该作者 7楼 发表于: 2010-10-18
离线xinn1021
只看该作者 8楼 发表于: 2012-03-31
     谢谢啦
许周 ╰☆且行且珍惜あすらさ
