  • 9718阅读
  • 10回复
[求助]请教:flac3d 中table命令的含义和用法 [复制链接]
离线wildfire
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-01-11
这是说明中的示例:gen zone brick size 6 6 6
model elas
prop bulk 1e8 shear 7e7
fix x range x -0.1 0.1
table 1 100,1 100,-1e5
apply sxx 1.0 hist table 1 range x 5.9,6.1 y 0,6 z 0,2
hist zone sxx 6,0,0
step 100
plot create eg
plot add axes red scale 0.4
plot add surface yellow
plot show
命令参考中的说明是:
TABLE n <keyword> x1 y1 <x2 y2><x3 y3> : : :
This command sets up a table of x- and y-values for use by FLAC3D. Tables are used
to define:
(1) the variation of friction, cohesion and dilation with accumulated plastic shear
strain for the strain-softening model (see the PROP ftable, PROP ctable and PROP
dtable commands) or the variation of tensile strength with accumulated plastic
tensile strain (see the PROP ttable command); and
(2) histories of boundary conditions (see the APPLY command).
Multiple tables may be defined, each uniquely identified by a table number n. The
number of tables and x,y pairs are only limited by the amount of computer memory
available. The command PRINT table can be used to verify the contents of a table.
Individual tables can also be plotted using the PLOT table n command. Table numbers
need not be sequential, but they must not be zero.
Tables can also be created and manipulated with FISH functions. See Chapter 6 for
a description of FISH table functions.
Histories may also be copied to tables (see the HISTORY command). This allows the
user to perform post-processing on histories (by using FISH).
这里面x1 y1 <x2 y2><x3 y3> : : :是什么意思,他的含义是什么啊?
离线luckystar80
只看该作者 1楼 发表于: 2008-03-27
I  study the problem,too, i also want to more introduce about the dynamical analysis ,the table command is also very useful in the force apply.
离线ivory
只看该作者 2楼 发表于: 2009-01-23
Table     n  x1 y1  <x2 y2>  <x3 y3>
             建成一个点的坐标的表, 以供 FLAC 引用,n为是表号。
宁静致远
离线忆伊
只看该作者 3楼 发表于: 2009-09-23
离线忆伊
只看该作者 4楼 发表于: 2009-09-30
离线haixing123
只看该作者 5楼 发表于: 2009-10-27
同样的问题,请高手指点啊
离线叶落御风
只看该作者 6楼 发表于: 2012-09-17
同求,table中各参数的含义
离线ericlight
只看该作者 7楼 发表于: 2012-10-23
同求同求。。。。
离线ericlight
只看该作者 8楼 发表于: 2012-10-23
线性差值能明白,但是x的取值是如何随运行变化的不懂
离线an-yantu
只看该作者 9楼 发表于: 2013-01-31
学习了
岩土
离线hrf0430
只看该作者 10楼 发表于: 2013-03-21
有点懂了,但是表中的数据如何确定?剪胀角这个东东可以查表找到么?
