  • 4619阅读
  • 1回复
abaqus桩基承载力问题 [复制链接]
离线lifelone
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-04-09
参考《abaqus在岩土工程应用》例题,模拟的桩基承载力问题,做到最后出现:ERROR in job messaging system: Error in connection to analysis
Error in job Job-1: The executable D:\Program\abaqus\product\6.10-1\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-1 aborted due to errors.
请论坛高手给指点指点!
版本6.10 12-1-1.rar (108 K) 下载次数:49
只看该作者 1楼 发表于: 2013-10-18
同求?、?????????
