  • 4377阅读
请高手指点abaqus [复制链接]
离线冷冰冰
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-04-24
在计算桩基承载力时,任务提交后,提示:Error in job ex12-1: USER SUBROUTINE VOIDRI IS MISSING。这是什么意思,什么办法可以解决。
come on
离线caowei1042
只看该作者 1楼 发表于: 2012-04-28
缺少用户子程序
离线冷冰冰
只看该作者 2楼 发表于: 2012-04-28
回 1楼(caowei1042) 的帖子
caowei1042:缺少用户子程序  (2012-04-28 09:28)
嗯,我已经安上了,并且用户子程序也验证通过了。显示如下:
Abaqus Product Install Verification...
Sat Apr 28 15:26:38 2012
Running system requirement checks.
Requirement:    Windows Server 2003, Windows XP, Windows Vista, or Windows 7
Product:        All Abaqus Products
Status:         Pass - Found Windows 7 Home Basic Home Edition  (Build 7600)
                (x86).
Requirement:    Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product:        Abaqus make utility with C++
Status:         Pass - Found Microsoft Visual C++ 9.0.21022.8.
Requirement:    Intel Fortran Compiler 10.1 or 11.1
Product:        Abaqus make utility with Fortran and Abaqus with user
                subroutines
Status:         Pass - Found Intel Fortran Compiler 11.1 Build 20100414
                Package ID w_cprof_p_11.1.065.
Requirement:    HP-MPI 01.01.00.00
Product:        Abaqus analyses using MPI-based parallelization and
                Abaqus/CFD
Status:         Pass - Found HP-MPI 01.01.00.00.
Requirement:    Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
                3.5, or greater
Product:        Abaqus Documentation
Status:         Pass - Found Internet Explorer 8.0.7600.16968
Making C:\Temp\verify. All verification files will reside in this directory.
Abaqus/Standard
         ...PASS
         Continuing...
Abaqus/Standard with user subroutines
         ...PASS
         Continuing...
Abaqus/Explicit (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit (double precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (single precision)
         ...PASS
         Continuing...
Abaqus/Explicit with user subroutines (double precision)
         ...PASS
         Continuing...
Abaqus/Viewer
         ...PASS
         Continuing...
Abaqus/CAE
         ...PASS
         Continuing...
Geometry Translator for CATIA V4
         ...PASS
         Continuing...
Geometry Translator for CATIA V5
         ...PASS
         Continuing...
Direct Geometry Import for CATIA V5
         ...PASS
         Continuing...
Geometry Translator for I-DEAS
         ...PASS
         Continuing...
Geometry Translator for Parasolid
         ...PASS
         Continuing...
Geometry Translator for Pro/ENGINEER
         ...PASS
         Continuing...
SolidWorks Associative Interface
         ...PASS
         Continuing...
Abaqus/AMS
         ...PASS
         Continuing...
Abaqus Interface for MSC.ADAMS
         ...PASS
         Continuing...
Abaqus/Standard parametric studies
         ...PASS
         Continuing...
Abaqus/Explicit parametric studies
         ...PASS
         Continuing...
Abaqus/Design
         ...PASS
         Continuing...
Abaqus Interface for Moldflow
         ...PASS
         Continuing...
         ...PASS
         Continuing...
         ...PASS
         Continuing...
Abaqus make utility with object code
         ...PASS
         Continuing...
Abaqus scripting interface
         ...PASS
         Continuing...
Abaqus analyses using parallelization
      Running thread-based parallel with 2 cpu(s)
            Abaqus/Explicit domain-level parallel
         ...PASS
            Abaqus/Standard direct solver
         ...PASS
         Continuing...
Abaqus/Foundation
         ...PASS
         Continuing...
Abaqus noGUI (CAE/Viewer)
         ...PASS
         Continuing...
Abaqus/CFD
         ...PASS
         Continuing...
Clean-up...
Verification directory C:\Temp\verify has been deleted.
最后我又重新调用子程序时还是提示错误Error in job Job-1: Problem during compilation - ifort.exe not found in PATH.这个问题出在哪
come on
只看该作者 3楼 发表于: 2012-07-19
调用了嘛?填调用地址了没有啊?
