  • 2616阅读
  • 0回复
请帮忙翻译下,谢谢 [复制链接]
离线bettypeng
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-03-28
The Beta angle can be measured directly using clear plastic tube protractors, but these have to be available in a range of diameters to match the core diameter. Alternatively, the most common method is to measure using a tape measure form the orientation line around the core to the maximum dip vector position
