  • 2446阅读
菜鸟请飘过,高手帮忙指点FLAC中桩身水平推力计算与分析 [复制链接]
离线雍睿
只看楼主 倒序阅读 使用道具 楼主  发表于: 2012-10-19
本人近期在研究桩土相互作用中桩身推力分布情况,分析过程中却遇到了不小的问题,一直不能得到很好的解决和分析,冒昧的请教下论坛上的大侠。话不多说,直接上图,第一幅图就是我分析的理想模型,中间设置了两根桩,并进行了初始地应力平衡计算。
接着的命令流如下:
delete range x 77 80.8 y 0 2.5   z 19.36 77
delete range x 77 80.8 y 8.5 11 z 19.36 77
interface 1 face range x 77 80.8 y 0 2.5   z 19.36
interface 1 face range x 77  y 0 2.5   z 19.36  77
interface 1 face range x 80.8  y 0 2.5   z 19.36  77
interface 1 face range x 77 80.8    y 0    z 19.36  77
interface 1 face range x 77 80.8    y 2.5   z 19.36  77
interface 2 face range x 77 80.8 y 8.5 11 z 19.36
interface 2 face range x 77    y 8.5 11   z 19.36  77
interface 2 face range x 80.8  y 8.5 11   z 19.36  77
interface 2 face range x 77 80.8    y 8.5    z 19.36  77
interface 2 face range x 77 80.8    y 11  z 19.36  77
;==================================建立接触面
gen zone brick p0 77 0 19.36 p2 77 2.5 19.36 p1 80.8 0 19.36 p4 80.8 2.5 19.36 p3 77 0 38.225 p5 77 2.5 38.225 p6 80.8 0 38.89 p7 80.8 2.5 38.89 size 2 5 5  group anti_pile1
gen zone brick p0 77 0 38.225 p2 77 2.5 38.225 p1 80.8 0 38.89 p4 80.8 2.5 38.89 p3 77 0 41.225 p5 77 2.5 41.225 p6 80.8 0 41.89 p7 80.8 2.5 41.89 size 2 5 3 group anti_pile1
gen zone brick p0 77 0 41.225 p2 77 2.5 41.225 p1 80.8 0 41.89 p4 80.8 2.5 41.89 p3 77 0 77 p5 77 2.5 77 p6 80.8 0 77 p7 80.8 2.5 77 size 2 5 30 group anti_pile1
gen zone brick p0 77 8.5 19.36 p2 77 11 19.36 p1 80.8 8.5 19.36 p4 80.8 11 19.36 p3 77 8.5 38.225 p5 77 11 38.225 p6 80.8 8.5 38.89 p7 80.8 11 38.89 size 2 5 5  group anti_pile2
gen zone brick p0 77 8.5 38.225 p2 77 11 38.225 p1 80.8 8.5 38.89 p4 80.8 11 38.89 p3 77 8.5 41.225 p5 77 11 41.225 p6 80.8 8.5 41.89 p7 80.8 11 41.89 size 2 5 3 group anti_pile2
gen zone brick p0 77 8.5 41.225 p2 77 11 41.225 p1 80.8 8.5 41.89 p4 80.8 11 41.89 p3 77 8.5 77 p5 77 11 77 p6 80.8 8.5 77 p7 80.8 11 77 size 2 5 30 group anti_pile2
;==================================抗滑桩
ini xdisp 0 ydisp 0 zdisp 0
ini xvel 0 yvel 0 zvel 0
;==================================速度位移场清零
model mohr
prop density 2630 bulk 1.9e10 shear 1.08e10 coh 5.68e7 fric 19.8 dila 0     range group slide_bed;滑床材料
prop density 1680 bulk 1.15e7 shear 9.32e7  coh 9.86e5   fric 18.1 dila 0   range group slide_zone;滑带材料
prop density 1920 bulk 1.33e8 shear 1e8     coh 1.12e6   fric 18.9 dila 0   range group slide_mass;滑体材料
model elastic ran group anti_pile1;抗滑桩
prop density 2400 bulk 1e12  shear 1e12 range group anti_pile1
model elastic ran group anti_pile2;抗滑桩
prop density 2400 bulk 1e12  shear 1e12 range group anti_pile2
int 1 prop ks 1e11 kn 1e11 fric 30 ;接触面1
int 2 prop ks 1e11 kn 1e11 fric 30 ;接触面2
solve
下面阐述我分析过程中的疑问和困惑:
1 推力监测的对象:桩身or仅临桩身的桩侧土单元ID SXX 存在的疑惑:两种方式监测的结果是否一致,是否是一对相互作用力的关系?桩身推力分布照道理直接用桩身的推力分布就行?但工程实践中却往往采用的是桩侧土压力数据的测量,那是否更适合通过监测桩侧土压力与之对应。
2 最大的疑问,最想知道答案的问题
  抗滑桩顶、桩侧土截面SXX的云图如图2、3所示,为什么桩顶的SXX会偏大,这是什么原因造成的?这与实际不符,应该越接近地表土压力越小才正确。
   这种异常现象是不是FLAC算法本身的问题,能否将这局部数据作为异常数据剔除。
                  (桩顶)                                                           (桩侧土)
努力为了美满的生活
离线雍睿
只看该作者 1楼 发表于: 2012-10-19
千万别告诉我,这是软件的固有算法所至。
努力为了美满的生活
离线雍睿
只看该作者 2楼 发表于: 2012-10-19
有人会说这是由于桩身附近水平位移过大造成,因为位移与应变有关,应力与应变也有关,是这个原因造成而来异常。这种解释依然不能解决问题,困扰啊。
努力为了美满的生活
离线小珍鹏
只看该作者 3楼 发表于: 2012-10-23
想请问楼主是怎么模拟抗滑桩的?抗滑桩直接建好在计算时还用加滑坡推力吗?怎么模拟滑坡推力施加在抗滑桩上啊?我建的模型为什么计算时总是没什么变化,桩好像是不受力?
离线a15056714708
只看该作者 4楼 发表于: 2013-04-16
敢问下lz,你前面进行边坡建模的时候,滑体和滑带之间建立接触面了么?顺便问下能加一下qq不,可以互相交流下。我的qq1024670528.
