  • 3065阅读
这是提示的错误信息。那位高手可以告诉我是什么意思吗? [复制链接]
离线znnnh
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-04-06
*** ERROR ***    SUPPRESSED MESSAGE    CP=    60.609  TIME= 16:35:30 k'[ S@+5
The value of UY at node 1096 is 10036947.1.  It is greater than the    HDF!`
current limit of 1000000.  This generally indicates rigid body motion  o%Be0~n'
as a result of an unconstrained model.  Verify that your model is      AezvBY0'`z
properly constrained.                                                  ~|CJsD/
MvFM ,
*** ERROR ***    SUPPRESSED MESSAGE    CP=    60.609  TIME= 16:35:30 =ze FK_S!
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***                )%iRZ\`f
Rigid body motion can also occur when net section yielding has          JQ) 4}t
occurred resulting in large displacements for small increments of load  gEr4zae
or when buckling has occurred.  You can plot the time history curve    :vc[/<
for node 1096 in the UY direction to check for stiffness (slope of the  <i_> y~v`
curve) approaching zero.                                                F . K2
5l41Q
*** WARNING ***  SUPPRESSED MESSAGE    CP=    60.609  TIME= 16:35:30 $nB-ADRu@
The unconverged solution (identified as time 1 substep 999999) is      3[0w+{ (Q
output for analysis debug purposes.  Results should not be used for    4GG1E. z}
any other purpose.                                                      w`c0a&7
/COM,ANSYS RELEASE  8.1    UP20040329      16:39:51    04/06/2008 r-RCe3%g%
gEZwW]r-
这是提示的错误信息。那位高手可以告诉我是什么意思吗?速回!谢谢!
离线geofem
只看该作者 1楼 发表于: 2008-04-06
constraints are not enough.
ZSOIL2D/3D QQ群:68722113
岩土工程数值分析开发平台,共享、开放、合作、提高。
离线znnnh
只看该作者 2楼 发表于: 2008-04-06
刚学这个,还是不太明白。能不能解释的更清楚一些呢?谢谢!
离线helmhlotz
只看该作者 3楼 发表于: 2010-12-02
边界条件没约束住,出现刚体位移,试着增强约束试试
