VB6 源代码,喜欢的朋友一起探讨。全部代码为本人自编,本人借楼主帖发放。 =m-_0xo
Public BhachNumber As String G::6?+S
Dim fso As New FileSystemObject, fldr As Folder '8%aq8
+n)(\k{
y)/d-
Option Explicit
i 0L7`TB
Dim AcadDoc As AcadDocument u4Vc:n
Dim FilPath As String '设置系统路迳 !nykq}kPN\
Dim AcadApp As Object 'AcadApplication \
fwf\&
Dim AcadColr As Integer 'CAD线色 Gt- -7S
Dim ReturnPnt As Variant z.[L1AGa|s
Dim LayerObj As AcadLayer 'CAD图层 9:@os0^O
Dim LayerStr As String wX|]8f2Z
Dim PolObj As AcadLWPolyline Jbs:}]2
Dim TextObj As AcadText >)5rOU
Dim VaraTtributes As Variant =XoNk1
Dim KK As Integer '定义玫瑰花图分度间隔 B&L{/.v_z\
Dim KL As Integer '定义玫瑰花图最大半径条数 Kji}2j'a
Dim StartPnt(0 To 2) As Double tD>m%1'&
Dim EndPnt(0 To 2) As Double t,MK#Ko
Dim II As Integer U7:~@eYy
Dim K As Integer i|=}zR
Dim TextString As String y@hdN=-
Dim InsertionPoint(0 To 2) As Double )?4m}
Dim HeightString As Double A7:
o q7b
Dim BlockObj As AcadBlockReference '}XW
Dim DrawNum1 As Double F3 wRHq
Dim LTName As String }KZ/>Z;^
Dim i As Integer BH*vsxe
Dim X0 As Single, Y0 As Single, X2 As Single, Y2 As Single BRH:5h
Dim R1 As Single, R2 As Single, Ang1 As Single, Ang2 As Single *TMg.
Dim Dat(4, 200) vtr:{
Dim CirclObj As Object PQf FpmG
Const Pi = 3.1415926 -3KB:K<
Dim R As Double `D#l(gZ
Dim dwPath As String 21cIWvy
Dim dwPath1 As String Jr1^qY`0+
Dim dwPath2 As String GW}KmTa]&
Dim dwPath3 As String '^P
Ud`
Dim ArcObj As AcadArc R %}k52`
Dim ArcStrA As AcadArc w*bVBuXs
Dim LineObj As AcadLine ?g<*1N?:
Dim LWPLObj As AcadLWPolyline 0<i~XN0g
Dim centerPoint(0 To 2) As Double '#q"u y
Dim radius As Double 0BE%~W
Dim startAngleInDegree As Double g"zk14'
Dim endAngleInDegree As Double 2%WZ-l!i
Dim startAngleInRadian As Double Y*"%;e$tg
Dim endAngleInRadian As Double eKu&_q
xD_jfAH'
Private Sub Command1_Click() iUl{_vb
StartPnt(0) = DrawNum1 2RM1-j
StartPnt(1) = 0 0A}'.LI
StartPnt(2) = 0 gqe
z-
R = 100 -'YX2!IU,
FilPath = App.Path & "\CPTY.dwg" 8V4Qyi|@F
Set BlockObj = AcadDoc.ModelSpace.InsertBlock(StartPnt, FilPath, 1, 1, 1, 0) crvWAsm
Call DrawArc 2c+q~8Jv
dwPath1 = "-赤平投影图" s
fti[
MsgBox "赤平投影结束,可以进行其它工作!" Y!Z@1V`
DrawNum1 = DrawNum1 + 300 R~c(^.|r
End Sub kZn!]TseN
J-X5n 3I&
Private Sub Command2_Click() }Efp{E
StartPnt(0) = DrawNum1: StartPnt(1) = 0: StartPnt(2) = 0 L8Z?B\
FilPath = App.Path & "\Rose.dwg" s]B^Sz=
Set BlockObj = AcadDoc.ModelSpace.InsertBlock(StartPnt, FilPath, 1, 1, 1, 0) 5B98}N
BlockObj.Update ',O@0L]L
Call DrwRose Ha 3XH_
dwPath2 = "-玫瑰花图" _&B
