  • 3697阅读
[求助]请高手给分析一下这个错误原因(ANSYS分析重力坝时存在的问题) [复制链接]
离线znnnh
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-04-09
*** ERROR ***    SUPPRESSED MESSAGE    CP=    101.438  TIME= 16:24:35
The value of UY at node 138 is 2877562.13.  It is greater than the
current limit of 1000000.  This generally indicates rigid body motion
as a result of an unconstrained model.  Verify that your model is
properly constrained.
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
Rigid body motion can also occur when net section yielding has
occurred resulting in large displacements for small increments of load
or when buckling has occurred.  You can plot the time history curve
for node 138 in the UY direction to check for stiffness (slope of the
curve) approaching zero.
*** WARNING ***  SUPPRESSED MESSAGE    CP=    101.438  TIME= 16:24:35
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes.  Results should not be used for
any other purpose.
离线znnnh
只看该作者 1楼 发表于: 2008-04-11
没有人知道吗?急!
离线heter01
只看该作者 2楼 发表于: 2008-04-11
不知道哦
离线lovecan
只看该作者 3楼 发表于: 2008-07-01
貌似节点有点多 你用的啥版本啊 学生版的?
离线zong2006
只看该作者 4楼 发表于: 2008-07-01
模型约束施加有问题,产生了刚体运动,.计算不收敛.. .....
离线yfliu
只看该作者 5楼 发表于: 2008-11-28
边界条件加错了
离线cf802
只看该作者 6楼 发表于: 2008-11-28
约束没加好,或者节点没耦合,先NUMMRG下,再加边界约束
