  • 2876阅读
  • 8回复
[国内文献]一些岩土工程词汇 [复制链接]
离线sunjun830109
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-04-18
一些岩土工程词汇
一. 综合类
1.geotechnical engineering岩土工程
2.foundation engineering基础工程
3.soil, earth土
4.soil mechanics土力学
        cyclic loading周期荷载
unloading卸载
reloading再加载
viscoelastic foundation粘弹性地基
viscous damping粘滞阻尼
shear modulus剪切模量
5.soil dynamics土动力学
6.stress path应力路径
7.numerical geotechanics 数值岩土力学
二. 土的分类
1.residual soil残积土 groundwater level地下水位
2.groundwater  地下水  groundwater table地下水位 3.clay minerals粘土矿物
4.secondary minerals次生矿物
5.landslides滑坡
6.bore hole columnar section钻孔柱状图
7.engineering geologic investigation工程地质勘察
8.boulder漂石
9.cobble卵石
10.gravel砂石
11.gravelly sand砾砂
12.coarse sand粗砂
13.medium sand中砂
14.fine sand细砂
15.silty sand粉土
16.clayey soil粘性土
17.clay粘土
18.silty clay粉质粘土
19.silt粉土
20.sandy silt砂质粉土
21.clayey silt粘质粉土
22.saturated soil饱和土
23.unsaturated soil非饱和土
24.fill (soil)填土
25.overconsolidated soil超固结土
26.normally consolidated soil正常固结土
27.underconsolidated soil欠固结土
28.zonal soil区域性土
29.soft clay软粘土
30.expansive (swelling) soil膨胀土
31.peat泥炭
32.loess黄土
33.frozen soil冻土
三. 土的基本物理力学性质
1.cc  compression index
2.cu  undrained shear strength
3.cu/p0  ratio of undrained strength cu to effective overburden stress p0 (cu/p0)NC ,(cu/p0)oc subscripts NC and OC designated normally consolidated and overconsolidated, respectively
4.cvane  cohesive strength from vane test
5.e0  natural void ratio
6.Ip  plasticity index
7.K0  coefficient of “at-rest ”pressure ,for total stressesσ1 andσ2
8.K0’  domain for effective stressesσ1 ‘ andσ2’
9.K0n  K0  for normally consolidated state 10.K0u  K0  coefficient under rapid continuous loading ,simulating instantaneous loading  or an undrained condition 11.K0d  K0  coefficient under cyclic loading(frequency less than 1Hz),as a pseudo- dynamic test for K0 coefficient
12.kh  ,kv  permeability in horizontal and vertical directions, respectively
13.N  blow count, standard penetration test
14.OCR  over-consolidation ratio
15.pc  preconsolidation pressure ,from oedemeter test
16.p0  effective overburden pressure 17.p s  specific cone penetration resistance, from static cone test 18.qu  unconfined compressive strength
19.U, Um  degree of consolidation ,subscript m denotes mean value of a specimen
20.u ,ub ,um  pore (water) pressure, subscripts b and m denote bottom of specimen and mean value, respectively
21.w0 wL wp  natural water content, liquid and plastic limits, respectively
22.σ1,σ2  principal stresses, σ1 ‘ andσ2’ denote effective principal stresses
23.Atterberg limits阿太堡界限
24.degree of saturation饱和度
25.dry unit weight干重度
26.moist unit weight湿重度
27.saturated unit weight饱和重度
28.effective unit weight有效重度
29.density密度
30.compactness密实度
31.maximum dry density最大干密度
32.optimum water content最优含水量
33.three phase diagram三相图
34.tri-phase soil三相土
35.soil fraction粒组
36.sieve analysis筛分
37.hydrometer analysis比重计分析
38.uniformity coefficient不均匀系数
39.coefficient of gradation级配系数
40.fine-grained soil(silty and clayey)细粒土
41.coarse- grained soil(gravelly and sandy)粗粒土
42.Unified soil classification system土的统一分类系统
43.ASCE=American Society of Civil Engineer美国土木工程师学会
44.AASHTO= American Association State Highway Officials美国州公路官员协会
45.ISSMGE=International Society for Soil Mechanics and Geotechnical Engineering
国际土力学与岩土工程学会
四. 渗透性和渗流
1.Darcy’s law  达西定律
2.piping管涌
3.flowing soil流土
4.sand boiling砂沸
5.flow net流网
6.seepage渗透(流)
7.leakage渗流
8.seepage pressure渗透压力
9.permeability渗透性
10.seepage force渗透力
11.hydraulic gradient水力梯度
12.coefficient of permeability渗透系数
五. 地基应力和变形
1.soft soil软土 2.(negative) skin friction of driven pile打入桩(负)摩阻力
3.effective stress有效应力
4.total stress总应力
5.field vane shear strength十字板抗剪强度
6.low activity低活性
7.sensitivity灵敏度
8.triaxial test三轴试验
9.foundation design基础设计
10.recompaction再压缩
11.bearing capacity承载力
12.soil mass土体
13.contact stress (pressure)接触应力(压力)
14.concentrated load集中荷载
15.a semi-infinite elastic solid半无限弹性体
16.homogeneous均质
17.isotropic各向同性
18.strip footing条基
19.square spread footing方形独立基础
20.underlying soil (stratum ,strata)下卧层(土)
21.dead load =sustained load恒载 持续荷载
22.live load活载
23.short –term transient load短期瞬时荷载
24.long-term transient load长期荷载
25.reduced load折算荷载
26.settlement沉降
27.deformation变形
28.casing套管
29.dike=dyke堤(防)
30.clay fraction粘粒粒组
31.physical properties物理性质
32.subgrade路基
33.well-graded soil级配良好土
34.poorly-graded soil级配不良土
35.normal stresses正应力
36.shear stresses剪应力
37.principal plane主平面
38.major (intermediate, minor) principal stress最大(中、最小)主应力
39.Mohr-Coulomb failure condition摩尔-库仑破坏条件
40.FEM=finite element method有限元法
41.limit equilibrium method极限平衡法
42.pore water pressure孔隙水压力
43.preconsolidation pressure先期固结压力
44.modulus of compressibility压缩模量
45.coefficent of compressibility压缩系数
46.compression index压缩指数
47.swelling index回弹指数
48.geostatic stress自重应力
49.additional stress附加应力
50.total stress总应力
51.final settlement最终沉降
52.slip line滑动线
六. 基坑开挖与降水
1  excavation开挖(挖方)
2  dewatering(基坑)降水
3  failure of foundation基坑失稳
4  bracing of foundation pit基坑围护
5  bottom heave=basal heave (基坑)底隆起
6  retaining wall挡土墙
7  pore-pressure distribution孔压分布
8  dewatering method降低地下水位法
9  well point system井点系统(轻型)
10 deep well point深井点
11 vacuum well point真空井点
12 braced cuts支撑围护
13 braced excavation支撑开挖
14 braced sheeting支撑挡板
七. 深基础--deep foundation
1.pile foundation桩基础
1)cast –in-place灌注桩 diving casting cast-in-place pile沉管灌注桩
bored pile钻孔桩
special-shaped cast-in-place pile机控异型灌注桩
piles set into rock嵌岩灌注桩
rammed bulb pile夯扩桩
2)belled pier foundation钻孔墩基础
drilled-pier foundation钻孔扩底墩
under-reamed bored pier 3)precast concrete pile预制混凝土桩
4)steel pile钢桩
steel pipe pile钢管桩
      steel sheet pile钢板桩
5)prestressed concrete pile预应力混凝土桩
prestressed concrete pipe pile预应力混凝土管桩
2.caisson foundation沉井(箱)
3.diaphragm wall地下连续墙 截水墙
4.friction pile摩擦桩
5.end-bearing pile端承桩
6.shaft竖井;桩身
7.wave equation analysis波动方程分析
8.pile caps承台(桩帽)
9.bearing capacity of single pile单桩承载力 10.lateral pile load test单桩横向载荷试验
11.ultimate lateral resistance of single pile单桩横向极限承载力
12.static load test of pile单桩竖向静荷载试验
13.vertical allowable load capacity单桩竖向容许承载力
14.low pile cap低桩承台
15.high-rise pile cap高桩承台
16.vertical ultimate uplift resistance of single pile单桩抗拔极限承载力
17.silent piling静力压桩
18.uplift pile抗拔桩
19.anti-slide pile抗滑桩
20.pile groups群桩
21.efficiency factor of pile groups群桩效率系数(η)
22.efficiency of pile groups群桩效应
23.dynamic pile testing桩基动测技术
24.final set最后贯入度
25.dynamic load test of pile桩动荷载试验
26.pile integrity test桩的完整性试验
27.pile head=butt桩头
28.pile tip=pile point=pile toe桩端(头)
29.pile spacing桩距
30.pile plan桩位布置图
31.arrangement of piles =pile layout桩的布置
32.group action群桩作用
33.end bearing=tip resistance桩端阻
34.skin(side) friction=shaft resistance桩侧阻
35.pile cushion桩垫
36.pile driving(by vibration) (振动)打桩
37.pile pulling test拔桩试验
38.pile shoe桩靴
39.pile noise打桩噪音
40.pile rig打桩机
八. 地基处理--ground treatment
1.technical code for ground treatment of building建筑地基处理技术规范
2.cushion垫层法
3.preloading预压法
4.dynamic compaction强夯法
5.dynamic compaction replacement强夯置换法
6.vibroflotation method振冲法
7.sand-gravel pile砂石桩
8.gravel pile(stone column)碎石桩
9.cement-flyash-gravel pile(CFG)水泥粉煤灰碎石桩
10.cement mixing method水泥土搅拌桩
11.cement column水泥桩
12.lime pile (lime column)石灰桩
13.jet grouting高压喷射注浆法
14.rammed-cement-soil pile夯实水泥土桩法
15.lime-soil compaction pile 灰土挤密桩
lime-soil compacted column灰土挤密桩
lime soil pile灰土挤密桩
16.chemical stabilization化学加固法
17.surface compaction表层压实法
18.surcharge preloading超载预压法
19.vacuum preloading真空预压法
20.sand wick袋装砂井
21.geofabric ,geotextile土工织物
22.composite foundation复合地基
23.reinforcement method加筋法
24.dewatering method降低地下水固结法
25.freezing and heating冷热处理法
26.expansive ground treatment膨胀土地基处理
27.ground treatment in mountain area山区地基处理
28.collapsible loess treatment湿陷性黄土地基处理
29.artificial foundation人工地基
30.natural foundation天然地基
31.pillow褥垫
32.soft clay ground软土地基
33.sand drain砂井
34.root pile树根桩
35.plastic drain塑料排水带
36.replacement ratio(复合地基)置换率
九. 固结consolidation
1.Terzzaghi’s consolidation theory太沙基固结理论
2.Barraon’s consolidation theory巴隆固结理论
3.Biot’s consolidation theory比奥固结理论
4.over consolidation ration (OCR)超固结比
5.overconsolidation soil超固结土
6.excess pore water pressure超孔压力
7.multi-dimensional consolidation多维固结
8.one-dimensional consolidation一维固结
9.primary consolidation主固结
10.secondary consolidation次固结
11.degree of consolidation固结度
12.consolidation test固结试验
13.consolidation curve固结曲线
14.time factor Tv时间因子
15.coefficient of consolidation固结系数
16.preconsolidation pressure前期固结压力
17.principle of effective stress有效应力原理
18.consolidation under K0 condition K0固结
十. 抗剪强度shear strength
1.undrained shear strength不排水抗剪强度
2.residual strength残余强度
3.long-term strength长期强度
4.peak strength峰值强度
5.shear strain rate剪切应变速率
6.dilatation剪胀
7.effective stress approach of shear strength 剪胀抗剪强度有效应力法
8.total stress approach of shear strength抗剪强度总应力法
9.Mohr-Coulomb theory莫尔-库仑理论
10.angle of internal friction内摩擦角
11.cohesion粘聚力
12.failure criterion破坏准则
13.vane strength十字板抗剪强度
14.unconfined compression无侧限抗压强度
15.effective stress failure envelop有效应力破坏包线
16.effective stress strength parameter有效应力强度参数
十一. 本构模型--constitutive model
1.elastic model弹性模型
2.nonlinear elastic model非线性弹性模型
3.elastoplastic model弹塑性模型
4.viscoelastic model粘弹性模型
5.boundary surface model边界面模型
6.Duncan-Chang model邓肯-张模型
7.rigid plastic model刚塑性模型
8.cap model盖帽模型
9.work softening加工软化
10.work hardening加工硬化
11.Cambridge model剑桥模型
12.ideal elastoplastic model理想弹塑性模型
13.Mohr-Coulomb yield criterion莫尔-库仑屈服准则
14.yield surface屈服面
15.elastic half-space foundation model弹性半空间地基模型
16.elastic modulus弹性模量
17.Winkler foundation model文克尔地基模型
十二. 地基承载力--bearing capacity of foundation soil
1.punching shear failure冲剪破坏
2.general shear failure整体剪切破化
3.local shear failure局部剪切破坏
4.state of limit equilibrium极限平衡状态
5.critical edge pressure临塑荷载
6.stability of foundation soil地基稳定性
7.ultimate bearing capacity of foundation soil地基极限承载力
8.allowable bearing capacity of foundation soil地基容许承载力
十三. 土压力--earth pressure
1.active earth pressure主动土压力
2.passive earth pressure被动土压力
3.earth pressure at rest静止土压力
4.Coulomb’s earth pressure theory库仑土压力理论
5.Rankine’s earth pressure theory朗金土压力理论
十四. 土坡稳定分析--slope stability analysis
1.angle of repose休止角
2.Bishop method毕肖普法
3.safety factor of slope边坡稳定安全系数
4.Fellenius method of slices费纽伦斯条分法
5.Swedish circle method瑞典圆弧滑动法
6.slices method条分法
十五. 挡土墙--retaining wall
1.stability of retaining wall挡土墙稳定性
2.foundation wall基础墙
3.counter retaining wall扶壁式挡土墙
4.cantilever retaining wall悬臂式挡土墙
5.cantilever sheet pile wall悬臂式板桩墙
6.gravity retaining wall重力式挡土墙
7.anchored plate retaining wall锚定板挡土墙
8.anchored sheet pile wall锚定板板桩墙
十六. 板桩结构物--sheet pile structure
1.steel sheet pile钢板桩
2.reinforced concrete sheet pile钢筋混凝土板桩
3.steel piles钢桩
4.wooden sheet pile木板桩
5.timber piles木桩
十七. 浅基础--shallow foundation
1.box foundation箱型基础
2.mat(raft) foundation片筏基础
3.strip foundation条形基础
4.spread footing扩展基础
5.compensated foundation补偿性基础
6.bearing stratum持力层
7.rigid foundation刚性基础
8.flexible foundation柔性基础
9.embedded depth of foundation基础埋置深度
10.net foundation pressure基底附加应力
11.structure-foundation-soil interaction analysis上部结构-基础-地基共同作用分析
十八. 土的动力性质--dynamic properties of soils
1.dynamic strength of soils动强度
2.wave velocity method波速法
3.material damping材料阻尼
4.geometric damping几何阻尼
5.damping ratio阻尼比
6.initial liquefaction初始液化
7.natural period of soil site地基固有周期
8.dynamic shear modulus of soils动剪切模量
9.dynamic magnification factor动力放大因素
10.liquefaction strength抗液化强度
11.dimensionless frequency无量纲频率
12.evaluation of liquefaction液化势评价
13.stress wave in soils土中应力波
14.dynamic settlement振陷(动沉降)
十九. 动力机器基础
1.equivalent lumped parameter method等效集总参数法
2.dynamic subgrade reaction method动基床反力法
3.vibration isolation隔振
4.foundation vibration基础振动
5.elastic half-space theory of foundation vibration基础振动弹性半空间理论
6.allowable amplitude of foundation基础振动容许振幅
7.natural frequency of foundation基础自振频率
二十. 地基基础抗震 1.earthquake engineering地震工程
2.soil dynamics土动力学
3.duration of earthquake地震持续时间
4.earthquake response spectrum地震反应谱
5.earthquake intensity地震烈度
6.earthquake magnitude震级
7.seismic predominant period地震卓越周期
8.maximum acceleration of earthquake地震最大加速度
二十一. 室内土工实验
1.high pressure consolidation test高压固结试验
2.consolidation under K0 condition K0固结试验
3.falling head permeability变水头试验
4.constant head permeability常水头渗透试验
5.unconsolidated-undrained triaxial test不固结不排水试验(UU)
6.consolidated undrained triaxial test固结不排水试验(CU)
7.consolidated drained triaxial test固结排水试验(CD)
8.compaction test击实试验
9.consolidated quick direct shear test固结快剪试验
10.quick direct shear test快剪试验
11.consolidated drained direct shear test慢剪试验
12.sieve analysis筛分析
13.geotechnical model test土工模型试验
14.centrifugal model test离心模型试验
15.direct shear apparatus直剪仪
16.direct shear test直剪试验
17.direct simple shear test直接单剪试验
18.dynamic triaxial test三轴试验
19.dynamic simple shear动单剪
20.free(resonance)vibration column test自(共)振柱试验
二十二. 原位测试
1.standard penetration test (SPT)标准贯入试验
2.surface wave test (SWT)表面波试验
3.dynamic penetration test(DPT)动力触探试验
4.static cone penetration (SPT)  静力触探试验
5.plate loading test静力荷载试验
6.lateral load test of pile 单桩横向载荷试验
7.static load test of pile 单桩竖向荷载试验
8.cross-hole test  跨孔试验
9.screw plate test螺旋板载荷试验
10.pressuremeter test旁压试验
11.light sounding轻便触探试验
12.deep settlement measurement深层沉降观测
13.vane shear test十字板剪切试验
14.field permeability test现场渗透试验
15.in-situ pore water pressure measurement 原位孔隙水压量测
16.in-situ soil test原位试验
离线anglelover
只看该作者 1楼 发表于: 2007-10-21
谢谢了,我复制了。。。
离线huanggutou
只看该作者 2楼 发表于: 2007-12-05
离线xiaofeixia00
只看该作者 3楼 发表于: 2007-12-16
感谢你的劳动~你真好。。。。。
离线xiaofeixia00
只看该作者 4楼 发表于: 2007-12-16
感谢你的劳动~你真好。。。。。
离线xiaowabj
只看该作者 5楼 发表于: 2009-10-22
离线hgzyyl
只看该作者 6楼 发表于: 2010-04-02
感谢你的劳动~你真好。。。。。
离线abcdt5678
只看该作者 7楼 发表于: 2010-06-17
多谢汇总!
离线cazhu
只看该作者 8楼 发表于: 2011-05-30
复制了,谢谢lz
