  • 6653阅读
急求,运行时提示:warning—property not available to any zone in range [复制链接]
离线znc357711543
只看楼主 倒序阅读 使用道具 楼主  发表于: 2013-02-22
新手请教前辈,模型建模及初始参数赋值代码如下:
结果运行时提示warning—property not available to any zone in range,请问是哪里的问题啊?
感谢前辈阅读,耽误您一点时间,希望给出宝贵的建议。
附代码
模型代码如下:
new
gen zone brick size 152 10 20  p0 0 0 0   p1 76 0 0    p2 0 10 0    p3 0 0 10  group floorsandstone
gen zone brick size 152 10 10  p0 0 0 10  p1 76 0 10   p2 0 10 10   p3 0 0 15  group floormudstone
gen zone brick size 152 10 6   p0 0 0 15  p1 76 0 15   p2 0 10 15   p3 0 0 18  group coal
gen zone brick size 152 10 3   p0 0 0 18  p1 76 0 18   p2 0 10 18   p3 0 0 19.5  group mudstone1
gen zone brick size 152 10 4   p0 0 0 19.5  p1 76 0 19.5 p2 0 10 19.5 p3 0 0 19.6  group weakshale
gen zone brick size 152 10 7   p0 0 0 19.6  p1 76 0 19.6 p2 0 10 19.6 p3 0 0 23.1  group mudstone2
gen zone brick size 152 10 10  p0 0 0 23.1  p1 76 0 23.1 p2 0 10 23.1 p3 0 0 28.1  group siltstone
gen zone brick size 152 10 10  p0 0 0 28.1  p1 76 0 28.1 p2 0 10 28.1 p3 0 0 33.1  group sandstone
save moxing.sav
plot show
plot add block group
call  canshu.txt
初始平衡参数代码如下:
new
res moxing.sav
model elastic
prop den 2500  bulk 1.87e10 shear 1.58e10  coh 8.3e6  fric 39 tens 5e6 range group floorsandstone
prop den 2500  bulk 1.87e10 shear 1.58e10  coh 8.3e6  fric 39 tens 5e6 range group sandstone
prop den 2000  bulk 1.00e10 shear 5.94e9   coh 2.0e6  fric 25 tens 9e5 range group mudstone1
prop den 2200  bulk 1.39e10 shear 7.94e9   coh 3.2e6  fric 27 tens 2e6 range group floormudstone
prop den 2200  bulk 1.39e10 shear 7.94e9   coh 3.2e6  fric 27 tens 2e6 range group mudstone2
prop den 2700  bulk 1.72e10 shear 1.24e10  coh 5.0e6  fric 35 tens 3e6 range group siltstone
prop den 1400  bulk 8.33e9  shear 3.85e9   coh 1.0e6  fric 23 tens 5e5 range group coal
prop den 1100  bulk 7.78e9  shear 2.59e9   coh 0.5e6  fric 20 tens 1e5 range group weakshale
fix x range x -0.1 0.1
fix x range x 75.9 76.1
fix y range y -0.1 0.1
fix y range y 4.9 5.1
fix z range z -0.1 0.1
apply szz -3.39e6 gradient 0 0 2.26e4
set gravity 0 0 -9.81
apply sxx -5.92e6 gradient 0 0 3.95e4 rangex -0.1 0.1
apply sxx -5.92e6 gradient 0 0 3.95e4 rangex 75.9 76.1
apply syy -5.92e6 gradient 0 0 3.95e4 rangey -0.1 0.1
apply syy -5.92e6 gradient 0 0 3.95e4 rangey 9.9 10.1
hist unbal
set large
set mech ratio 1e-5
solve
save canshu.sav
一辈子跟自己作斗争
离线edelmann
只看该作者 1楼 发表于: 2013-02-22
group设置不能那么随意!后面的把前面的覆盖了!
好好看看手册吧!
离线znc357711543
只看该作者 2楼 发表于: 2013-02-22
回 edelmann 的帖子
谢谢前辈指导,不胜感谢。
一辈子跟自己作斗争
离线ajianme
只看该作者 3楼 发表于: 2013-02-25
离线tuotuo638
只看该作者 4楼 发表于: 2014-05-04
怎么改的呀~~~
离线mncwl
只看该作者 5楼 发表于: 2014-07-12
回 edelmann 的帖子
edelmann:group设置不能那么随意!后面的把前面的覆盖了!
好好看看手册吧! (2013-02-22 17:35)
同样遇到这个问题,找了半天问题都没解决,看了这个回复,虽然就只有覆盖两个字对我有用,但是够了,果断顶!
