I guess you probably did sth wrong by getting your different version of calculation massed up. Pals check it systematically.
1.Go to your output program, see the points selected there are the points you selected before calculation.
2.Open the curves program, using creating new curve. Then making sure you selected the right output file to generate the curve.
Cheers
