  • 4081阅读
  • 8回复
预应力锚杆支护问题。。。。 [复制链接]
只看楼主 倒序阅读 使用道具 楼主  发表于: 2013-06-21
本人最近做了个预应力锚杆支护的例子,发现支护前后巷道变形量基本没变,求各位大神指导一下,代码如下:
def zhihu
loop a (1,60)
command
;--------------------------------------左帮锚杆--------------------------------------
    sel cable id 1 begin 12,a,78.85  end   10.5511,a,78.4618    nseg 10
    sel cable id 2 begin 10.5511,a,78.4618  end   10.2613,a,78.3841    nseg 6
    sel cable id 1 begin 12,a,79.85  end   10.5,a,79.85    nseg 10
    sel cable id 2 begin 10.5,a,79.85  end   10.2,a,79.75    nseg 6
    sel cable id 1 begin 12,a,80.85  end   10.5511,a,81.2832    nseg 10
    sel cable id 2 begin 10.5511,a,81.2832  end   10.2613,a,81.3159    nseg 6
;--------------------------------------右帮锚杆----------------------------------
    sel cable id 1 begin 16.5,a,82.05  end   1,a,82.05   nseg 10
    sel cable id 2 begin 18,a,82.05    end   18.3,a,82.05    nseg 6
    sel cable id 1 begin 16.5,a,81.05  end   18,a,81.05   nseg 10
    sel cable id 2 begin 18,a,81.05    end   18.3,a,81.05    nseg 6
    sel cable id 1 begin 16.5,a,80.05  end   18,a,80.05   nseg 10
    sel cable id 2 begin 18,a,80.05    end   18.3,a,80.05    nseg 6
    sel cable id 1 begin 16.5,a,79.05  end   18,a,79.05   nseg 10
    sel cable id 2 begin 18,a,79.05    end   18.3,a,79.05    nseg 6
;--------------------------------------顶板锚杆--------------------------------------
    sel cable id 1 begin 12.5424,a,81.1808  end  11.0574,a,82.6657   nseg 10
    sel cable id 2 begin 11.0574,a,82.6657  end  10.845,a,82.8778    nseg 6
    sel cable id 1 begin 13.3962,a,81.4654  end   12.7321,a,83.4576   nseg 10
    sel cable id 2 begin 12.7321,a,83.4576  end   12.6372,a,83.7422    nseg 6
    sel cable id 1 begin 14.25,a,81.75  end   13.5859,a,83.7422   nseg 10
    sel cable id 2 begin 13.5859,a,83.7422  end  13.4911,a,84.0268    nseg 6
    sel cable id 1 begin 15.1038,a,82.0346  end   14.4397,a,82.0268   nseg 10
    sel cable id 2 begin 14.4397,a,82.0268  end   14.3449,a,84.3114    nseg 6
    sel cable id 1 begin 15.9576,a,82.3192  end   17.0076,a,84.1397   nseg 10
    sel cable id 2 begin 17.0076,a,84.1397  end   17.1576,a,84.3977    nseg 6
end_command
end_loop
loop a (1,720)
      b=16*a-15
      g=16*a-14
      h=16*a-6
      d=16*a-5
      f=16*a
command
      sel cable id 1 prop   emod 2e10   ytens 3.1e7  xcarea 4.9e-4    gr_coh 10e5   gr_k 2e7    ran cid d f ;设置锚杆锚固段参数
      sel cable id 1 prop   emod 2e10   ytens 3.1e7  xcarea 4.9e-4    gr_coh 1      gr_k 1   gr_per 0.1 ran cid g h  ;设置锚杆自由端参数
      sel cable id 1 prop   emod 2e10   ytens 3.1e7  xcarea 4.9e-4    gr_coh 10e8   gr_k 2e10    ran cid b b ;模拟托盘
      sel cable id 1 pretension 60e3 ran cid b h
end_command
end_loop
end
zhihu
只看该作者 1楼 发表于: 2013-06-21
怎么没人啊???
离线飞lai鸟
只看该作者 2楼 发表于: 2013-07-06
预应力不好施加,要有技巧!
离线tjwjy
只看该作者 3楼 发表于: 2013-07-06
离线fybjwg
只看该作者 4楼 发表于: 2013-11-01
一共三种方法 这是其一 QQ495343165,请与我联系模拟预应力锚杆方法一
sel cable id=1 beg 0, 0, 0 end 0 ,29, 0 nseg 10
;建立锚杆自由段
sel cable id=1 beg 0,29,0 end 0,35,0 nseg 6
;建立锚杆锚固段
sel cable id=1 prop emod 2e10 ytension 310e3 xcarea 0.0004906 &
gr_coh 1 gr_k 1 gr_per 0.0785 range cid 1,10
;设置锚杆自由段参数
gr_coh 10e5 gr_k 2e7 range cid 11,17
;设置锚杆锚固段参数
sel delete link range id 1
;删除原来自动建立的链接
sel link id=100 1 target zone
;建立新链接
sel link attach xdir=rigid ydir=rigid zdir=rigid xrdir=rigid yrdir=rigid zrdir=rigid range id 100
;把新链接设置为刚性链接
sel cable id=1 pretension 60e3 range cid 1,10
;在锚杆(锚索)自由段施加
预紧力
离线244437282
只看该作者 5楼 发表于: 2013-12-04
学习了,谢谢各位了!
离线zpp080425
只看该作者 6楼 发表于: 2013-12-12
一,你没有对cable id=2赋参数值,,仅仅对cable id=1赋值;二 这段预应力程序你是由别人改写来的,这个程序我觉得不靠谱,,表达的是端头锚固这一种形式(自由端参数设置的小),现在用的全长锚固比较多,端头锚固支护效果本来就不太好。
离线严志伟
只看该作者 7楼 发表于: 2013-12-29
回 fybjwg 的帖子
fybjwg:一共三种方法 这是其一 QQ495343165,请与我联系模拟预应力锚杆方法一
;建立锚杆自由段
;建立锚杆锚固段
....... (2013-11-01 15:01)
gr_coh 10e5 gr_k 2e7 range cid 11,17;;设置锚杆锚固段参数
,为什么cid  11,17,而不是cid  11,16,因为前面建立的锚杆锚固段为nseg 6,有疑问,请大侠指教
离线zhongyibei
只看该作者 8楼 发表于: 2015-03-10
楼主在,我也碰到你这个问题,施加预应力锚杆后,请问你后面解决这个问题的???
