自己做的一个三维基坑开挖的模拟,建模完了进行计算的时候出现这个问题
SEVERITY : WARNING
ERROR CODE: /DIANA/LB/EL30/0093
ERRORMSG.W: Results of your calculation may be inaccurate.
One of the angles between edges at node 9568 of element 20613 is
less than 1 degree or larger than 179 degrees.
SEVERITY : WARNING
One of the angles between edges at node 10067 of element 21119 is
SEVERITY : WARNING
One of the angles between edges at node 10566 of element 21625 is
不知道是哪里的问题,请问有没有人碰到过类似的?
