  • 24342阅读
  • 0回复
请求:ansys ls-dyna run is terminated with 1 error,please cheak the message file [复制链接]
离线alanhao123
只看楼主 倒序阅读 使用道具 楼主  发表于: 2013-10-26
回复本帖可获得2个土币奖励!
每人最多可获奖2次,奖池剩余20个土币 (中奖几率20%)
     Date: 10/26/2013      Time: 19:13:11
     ___________________________________________________
     |  Livermore  Software  Technology  Corporation   |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Version : ls971s R4.2     Date: 02/04/2009     |
     |  Revision: 50638           Time: 07:58:32       |
     |  Features enabled in this version:              |
     |    Shared Memory Parallel                       |
     |    ANSYS Database format                        |
     |  Licensed to:                                   |
     |  Platform   : PC WIN32                          |
     |  OS Level   : Windows 2K/XP/VISTA               |
     |  Compiler   : Intel Fortran Compiler 10.1       |
     |  Hostname   : PC-20130228NYJN                   |
     |  Precision  : Single precision (I4R4)           |
     |  Product ID : 50777                             |
     |  Unauthorized use infringes LSTC copyrights     |
Input file: li.k
The native file format       : 32-bit small endian
Memory size from default     :    20000000
expanding   memory to    20000000 starting ls-dyna
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Finite Element code.                   *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2009                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
contracting memory to           1 beginning of keyword reader
expanding   memory to       21002
expanding   memory to     1268456
expanding   memory to     4842914
expanding   memory to     4872914
expanding   memory to     4932914
expanding   memory to     5730041
expanding   memory to     6518365
expanding   memory to     6539362
expanding   memory to     6563362
expanding   memory to     6782691
expanding   memory to     6989520
expanding   memory to     9264639
expanding   memory to     9471468
expanding   memory to    13000926
expanding   memory to    13207755
expanding   memory to    13229855
expanding   memory to    13251855
expanding   memory to    13273855
expanding   memory to    13346600
Memory required to process keyword     :     13346600
contracting memory to           1 end of keyword reader
LS-DYNA will perform a structural only analysis
LS-DYNA user input
                         ls-dyna ls971s.50638 R4.2    date 02/04/2009
expanding   memory to        2417 material, node and element data
expanding   memory to        2494 material properties
expanding   memory to     2366223 element data
expanding   memory to     2797240 gradient of damage data
expanding   memory to     5738532 user control for contact interfaces
expanding   memory to     5738535 for boundary cond. vectorization
expanding   memory to     5934593 arbitrary element numbering input
contracting memory to     5854153 spc cards
expanding   memory to    10616447 process element material data
expanding   memory to    10618448 load curve data
contracting memory to    10616649 regularize time history data
contracting memory to    10616649 rigidwall definitions
expanding   memory to    11042569 nodal constraint sets
expanding   memory to    12609608 contact interfaces
expanding   memory to    13024266 implicit contact 1
expanding   memory to    14592916 implicit contact 2
expanding   memory to    24373535 contact segment data 1
*** Error Memory is set        4373535 words short
           Current memory size       20000000
           Increase the memory size by one of the following
           where #### is the number of words requested:
            1) On the command line set - memory=####
            2) In the input file define memory with *KEYWORD
               i.e., *KEYWORD #### or *KEYWORD memory=####
T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Initialization ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Element processing ... 0.0000E+00    0.00     0.0000E+00    0.00
  Binary databases ..... 0.0000E+00    0.00     0.0000E+00    0.00
  ASCII database ....... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact algorithm .... 0.0000E+00    0.00     0.0000E+00    0.00
  Contact entities ..... 0.0000E+00    0.00     0.0000E+00    0.00
  Rigid bodies ......... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Nonlinear ... 0.0000E+00    0.00     0.0000E+00    0.00
  Implicit Lin. Alg. ... 0.0000E+00    0.00     0.0000E+00    0.00
  T o t a l s            0.0000E+00    0.00     0.0000E+00    0.00
Problem time       =    0.0000E+00
Problem cycle      =         0
Total CPU time     =         0 seconds (   0 hours  0 minutes  0 seconds)
CPU time per zone cycle  =         0 nanoseconds
Clock time per zone cycle=         0 nanoseconds
Number of CPU's    1
NLQ used/max      96/   96
Start time   10/26/2013 19:13:11
End time     10/26/2013 19:13:23
Elapsed time      12 seconds(  0 hours  0 min. 12 sec.) for       0 cycles
E r r o r   t e r m i n a t i o n
