  • 18564阅读
  • 94回复
锚索框架梁计算 [复制链接]
离线zong2006
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-05-14
锚索框架梁计算程序-----自用的. RX6s[uQ
7 8n`VmH~L
第 1号梁的内力: WPXLN'w+
X(m) 梁的挠度W(mm) 剪力V(kN) M(kN.m) WJJwhr
.0000000E+00 .4400751E+00 .0000000E+00 .0000000E+00 o+F]80CH
.3333333E+00 .5217646E+00 .1114030E+02 .1856717E+01 YVT\@+C'
.6666667E+00 .6033995E+00 .2228060E+02 .7426867E+01  ~d\>f
.1000000E+01 .6834301E+00 .3342090E+02 .1671045E+02 K2gg"#ft?
.1333333E+01 .7588511E+00 .1720304E+03 .5095234E+02 YI!@ ,t
.1666667E+01 .8258432E+00 .3106399E+03 .1313974E+03 =T3O;i
.2000000E+01 .8621307E+00 .4492494E+03 .2580456E+03 WN`|5"?$
.2333333E+01 .8415647E+00 -.3499016E+03 .1202629E+03 <>I4wqqb
.2666667E+01 .7929233E+00 -.2230084E+03 .2477800E+02 PZB_6!}2[F
.3000000E+01 .7425619E+00 -.9611517E+02 -.2840926E+02 KvtX>3#qM
.3333333E+01 .6998748E+00 -.6404590E+02 -.5510281E+02 xmp^`^v*
.3666666E+01 .6739664E+00 -.3197668E+02 -.7110648E+02 PD$@.pib
.4000000E+01 .6687769E+00 .9259033E-01 -.7642058E+02 CgxGvM4
.4333333E+01 .6847240E+00 .3236707E+02 -.7101065E+02 wz1fl#WU
.4666667E+01 .7215331E+00 .6464160E+02 -.5484230E+02 UX!)\5-
.5000000E+01 .7745286E+00 .9691614E+02 -.2791614E+02 lAZn0EU
.5333333E+01 .8348683E+00 .2190367E+03 .2474294E+02 DI,8y"!5
.5666667E+01 .8945501E+00 .3411572E+03 .1181088E+03 Pko2fJt1
.6000000E+01 .9253547E+00 -.4641216E+03 .2521805E+03 KsR^:_e
.6333334E+01 .9022928E+00 -.3415032E+03 .1179099E+03 _G1C5nkDl4
.6666667E+01 .8494834E+00 -.2188848E+03 .2451165E+02 lQ!)0F
.7000001E+01 .7972447E+00 -.9626666E+02 -.2801352E+02 *\4u:1Cu
.7333334E+01 .7504436E+00 -.6429340E+02 -.5477312E+02 bzh`s<+
.7666668E+01 .7216954E+00 -.3232001E+02 -.7087600E+02 [:xpz,
.8000001E+01 .7145671E+00 -.3466187E+00 -.7632022E+02 UP?]5x>
.8333334E+01 .7266652E+00 .3184686E+02 -.7106962E+02 U?W?VEOO!7
.8666667E+01 .7594847E+00 .6404034E+02 -.5508916E+02 -!JnyD
.9000000E+01 .8092128E+00 .9623395E+02 -.2837677E+02 >?yxig:_
.9333333E+01 .8675921E+00 .2187326E+03 .2411809E+02 Z.x9SEe1t
.9666666E+01 .9241228E+00 .3412314E+03 .1174457E+03 9 U!-Zn!
.9999999E+01 .9521892E+00 .4637299E+03 .2516056E+03 @Z{!T)#}j
.1033333E+02 .9249598E+00 -.3412484E+03 .1174350E+03 XaH%i~}3
.1066667E+02 .8720858E+00 -.2187159E+03 .2410719E+02 6O9?":3;
.1100000E+02 .8170419E+00 -.9618347E+02 -.2837683E+02 $Il:Yw_
.1133333E+02 .7687594E+00 -.6409680E+02 -.5508790E+02 ;c;5O@R}3
.1166666E+02 .7368397E+00 -.3201038E+02 -.7110610E+02 F?EAIL
.1200000E+02 .7268763E+00 .7580566E-01 -.7642899E+02 \ W.uV[\
.1233333E+02 .7356637E+00 .3208850E+02 -.7106938E+02 rV6SN.
.1266666E+02 .7677965E+00 .6410120E+02 -.5503728E+02 DuzJQ Sv
.1300000E+02 .8169697E+00 .9611389E+02 -.2833039E+02 n)6mfoe
.1333333E+02 .8729733E+00 .2186965E+03 .2413335E+02 ~P5;k_&
.1366666E+02 .9252563E+00 .3412795E+03 .1174613E+03 ^}\!Sn
.1400000E+02 .9521191E+00 .4638630E+03 .2516555E+03 aNxq_pRb
.1433333E+02 .9220299E+00 -.3412399E+03 .1175412E+03 '"~ 2xiin
.1466666E+02 .8686928E+00 -.2190118E+03 .2416366E+02 1,pg7L8H
.1499999E+02 .8115070E+00 -.9678430E+02 -.2846680E+02 ~Q36lR
.1533333E+02 .7627642E+00 -.6437268E+02 -.5532676E+02 25m6/Y
.1566666E+02 .7275132E+00 -.3196301E+02 -.7138300E+02 8H<:?D/tH
.1599999E+02 .7123237E+00 .4466553E+00 -.7663554E+02 jJU9~5i?
.1633333E+02 .7227665E+00 .3252673E+02 -.7114014E+02 Zwm2T3@e
.1666666E+02 .7538316E+00 .6460681E+02 -.5495203E+02 l$mfsm|{:
.1699999E+02 .7998267E+00 .9668695E+02 -.2806665E+02 n |Is&fy
.1733333E+02 .8528807E+00 .2187319E+03 .2449646E+02 SIr^\iiOB
.1766666E+02 .9053034E+00 .3407783E+03 .1177588E+03 )cUFb:D*"
.1800000E+02 .9287198E+00 .4628246E+03 .2516849E+03 |',$5!:0O
.1833333E+02 .8988408E+00 -.3413707E+03 .1174468E+03 klON6<w
.1866666E+02 .8405616E+00 -.2186261E+03 .2410254E+02 H}}g\|r&
.1900000E+02 .7763682E+00 -.9588098E+02 -.2830713E+02 b8$(j2B~
.1933333E+02 .7308599E+00 -.6409827E+02 -.5497461E+02 =bDy :yY}
.1966667E+02 .6919193E+00 -.3231604E+02 -.7104053E+02 w]Byl3}Gt
.2000000E+02 .6780369E+00 -.5333252E+00 -.7651367E+02 }2CVA.Qm!
.2033333E+02 .6828176E+00 .3210828E+02 -.7125049E+02 R3\oLT4
.2066667E+02 .7095836E+00 .6475037E+02 -.5511218E+02 4y$tp1 8
.2100000E+02 .7576617E+00 .9739252E+02 -.2809912E+02 ujH ^ML
.2133334E+02 .8092123E+00 .2193974E+03 .2471301E+02 2C@s-`b
.2166667E+02 .8522087E+00 .3414023E+03 .1181753E+03 ,R8:Y*@P
.2200000E+02 .8765312E+00 -.4640701E+03 .2523081E+03 /QT"5fxKJ
.2233334E+02 .8444037E+00 -.3414647E+03 .1180521E+03 X@cO`P
.2266667E+02 .7856705E+00 -.2188587E+03 .2466915E+02 8O='Q-& 8
.2300001E+02 .7225466E+00 -.9625470E+02 -.2785589E+02 2F- ]0kGR|
.2333334E+02 .6630321E+00 -.6384943E+02 -.5453670E+02 /ltGSl
.2366667E+02 .6209397E+00 -.3144415E+02 -.7042161E+02 NJ];Ck
.2400001E+02 .6079037E+00 .9606323E+00 -.7550378E+02 v5Qp[O_
.2433334E+02 .6110336E+00 .3217889E+02 -.6998488E+02 "1X@t'H38
.2466668E+02 .6324269E+00 .6339667E+02 -.5405619E+02 #G`UR
.2500001E+02 .6715009E+00 .9461688E+02 -.2770147E+02 gI5"\"T{
.2533334E+02 .7220409E+00 .2196267E+03 .2465642E+02 b,MzHx=im
.2566668E+02 .7709760E+00 .3446370E+03 .1187084E+03 W:V:Ej7 h
.2600001E+02 .7833006E+00 -.4572402E+03 .2544151E+03 z&@O\>Q
.2633335E+02 .7406820E+00 -.3316104E+03 .1229299E+03 aW.[3M;?v
.2666668E+02 .6809877E+00 -.2059805E+03 .3332193E+02 ;wF 0s
.2700001E+02 .6088052E+00 -.8035352E+02 -.1438268E+02 RV{'[8gM
.2733335E+02 .5338520E+00 -.4280615E+02 -.3491303E+02 [\ALT8vC?m
.2766668E+02 .4845576E+00 -.5258789E+01 -.4293502E+02 <~ 9a3c?
.2800002E+02 .4381243E+00 .3228662E+02 -.3841991E+02 E%tGwbi7
.2833335E+02 .4079034E+00 .2895410E+02 -.2820459E+02 nPh| rW=
.2866668E+02 .3874001E+00 .2562158E+02 -.1911233E+02 DuV@^qSbG.
.2900002E+02 .3667160E+00 .2228857E+02 -.1112944E+02 6'YsSde".
.2933335E+02 .3488929E+00 .1485889E+02 -.4958069E+01 AQR/nWwx
.3000000E+02 .3053379E+00 .4882813E-03 .1757813E-01 NKJ+DD:'
yWkg4
+PfXc?VU
.... mO|YX/>
Wd78 bu|
.... f 3t&Bcw$
Kp.d#W_TX
c u:1|gt
.... y?4%eD
xfsf
-w#*~Q{'*
第 12号梁的内力: kH9P(`;Vq
X(m) 梁的挠度W(mm) 剪力V(kN) M(kN.m) 8n`O{8:fi
.0000000E+00 .4453868E+00 .0000000E+00 .0000000E+00 "pLWJvj6-
.3333333E+00 .5250576E+00 .1070378E+02 .1783963E+01 m.0: R
.6666667E+00 .6046679E+00 .2140755E+02 .7135851E+01 )*tV
.1000000E+01 .6827381E+00 .3211133E+02 .1605566E+02 ,rZp(moj
.1333333E+01 .7563878E+00 .1680046E+03 .4940832E+02 1NI%J B
.1666667E+01 .8218753E+00 .3038978E+03 .1280587E+03 "T+oXK\B
.2000000E+01 .8575456E+00 .4397910E+03 .2520068E+03 #eKg!]4-R
.2333333E+01 .8376292E+00 -.3421518E+03 .1172373E+03 )~CnDk}^R
.2666667E+01 .7904332E+00 -.2178375E+03 .2390572E+02 y^xEZD1X6-
.3000000E+01 .7415902E+00 -.9352325E+02 -.2798776E+02 `L#`WC@[o
.3333333E+01 .7004795E+00 -.6244781E+02 -.5398299E+02 <1xs ya[e
.3666666E+01 .6754807E+00 -.3137238E+02 -.6961964E+02 !`$xN~_
.4000000E+01 .6709734E+00 -.2969360E+00 -.7489788E+02 "S ~(|G
.4333333E+01 .6871733E+00 .3141315E+02 -.6971162E+02 [n!5!/g>j
.4666667E+01 .7236371E+00 .6312335E+02 -.5395567E+02 f:_mrzz
.5000000E+01 .7762822E+00 .9483350E+02 -.2762964E+02 XI"8d.VR
.5333333E+01 .8367840E+00 .2181433E+03 .2453330E+02 x.ZW%P1
.5666667E+01 .8952952E+00 .3414530E+03 .1177995E+03 E Qn4+
.6000000E+01 .9263448E+00 -.4667141E+03 .2521683E+03 z&x3":@u<
.6333334E+01 .9019821E+00 -.3423876E+03 .1173183E+03 Jg:%|g
.6666667E+01 .8507083E+00 -.2180612E+03 .2390950E+02 =FfxHo1k
.7000001E+01 .7973160E+00 -.9373499E+02 -.2805594E+02 :K]&rGi,
.7333334E+01 .7523060E+00 -.6278479E+02 -.5414296E+02 b!hs|emo;
.7666668E+01 .7231855E+00 -.3183459E+02 -.6991212E+02 \ =(r6X
.8000001E+01 .7139184E+00 -.8843994E+00 -.7536502E+02 {6,  l#z
.8333334E+01 .7265683E+00 .3070142E+02 -.7039594E+02 +* AdSzX
.8666667E+01 .7590061E+00 .6228723E+02 -.5489767E+02 i=mk#.j~
.9000000E+01 .8080039E+00 .9387305E+02 -.2887158E+02 AIK99
.9333333E+01 .8653529E+00 .2197500E+03 .2339963E+02  WPnw
.9666666E+01 .9211626E+00 .3456270E+03 .1176288E+03 "z/)> ?Wn
.9999999E+01 .9490781E+00 .4715039E+03 .2538173E+03 I C?bqC+
.1033333E+02 .9219366E+00 -.3436590E+03 .1184904E+03 $~s|%>@
.1066667E+02 .8666832E+00 -.2190084E+03 .2471145E+02 $-Wn|w+h<a
.1100000E+02 .8101434E+00 -.9435797E+02 -.2751579E+02 {@tqeu%IM
.1133333E+02 .7610234E+00 -.6321027E+02 -.5377721E+02 B>=NE.ulUL
.1166666E+02 .7281614E+00 -.3206305E+02 -.6965673E+02 @ UgZZ
.1200000E+02 .7162900E+00 -.9158325E+00 -.7515247E+02 dd&n>A3O=
.1233333E+02 .7236642E+00 .3086005E+02 -.7016284E+02 sH_5.+,`
.1266666E+02 .7525396E+00 .6263568E+02 -.5457753E+02 DE659=Tq
.1300000E+02 .7978069E+00 .9441156E+02 -.2840382E+02 Z&w/JP?
.1333333E+02 .8507283E+00 .2173884E+03 .2355967E+02 'Bc{N^
.1366666E+02 .9024321E+00 .3403659E+03 .1165205E+03 ` <3xi9
.1400000E+02 .9260346E+00 .4633434E+03 .2504706E+03 %D9,Femt
.1433333E+02 .8964518E+00 -.3408469E+03 .1163311E+03 <[W41{
.1466666E+02 .8371059E+00 -.2176458E+03 .2324535E+02 I(2qXOG
.1499999E+02 .7793921E+00 -.9444434E+02 -.2876911E+02 :<w2j 6V
.1533333E+02 .7277380E+00 -.6228442E+02 -.5489141E+02 ln~;Osb
.1566666E+02 .6931943E+00 -.3012598E+02 -.7029271E+02 Q^c)T>OAI
.1599999E+02 .6782812E+00 .2032471E+01 -.7497855E+02 M}c gVMW
.1633333E+02 .6843532E+00 .3372754E+02 -.6901241E+02 LFHzd@Y7"
.1666666E+02 .7114673E+00 .6542285E+02 -.5248882E+02 A.@/~\
.1699999E+02 .7552034E+00 .9711823E+02 -.2539563E+02 5UU1HC;C
.1733333E+02 .8043323E+00 .2196011E+03 .2738798E+02 yR|Beno
.1766666E+02 .8517587E+00 .3420858E+03 .1210036E+03 C 7e
.1800000E+02 .8702266E+00 .4645701E+03 .2554484E+03 Mb0l*'ZF
.1833333E+02 .8330762E+00 -.3083830E+03 .1296501E+03 |:jka
.1866666E+02 .7630240E+00 -.1702888E+03 .4985390E+02 :e|[gEA
.1900000E+02 .6886804E+00 -.3219452E+02 .1611587E+02 Rx\.x? &
.1933333E+02 .6062304E+00 -.2146259E+02 .7169290E+01 :1/K$A)^{
.2000000E+02 .4427611E+00 .7934570E-03 .1892090E-01 v0|[w2Q2
kafRuO~$
ecg>_%.>
~,jBm^4
k.MAX8
sCi"qtHP
oMNgyAp^
y8k*{1MuO
 +?I 1Og
rr;p;
{ t1|6R0
Hvj1R.I/
[ 此贴被zong2006在2008-05-14 01:05重新编辑 ]
附件: FBeamS.rar (119 K) 下载次数:225 ,该附件已加密,拥有50威望才能下载
共2条评分
dongtingkang 鲜花 +1 - 2008-05-14
byy9323 鲜花 +1 - 2008-05-14
离线zd1234
只看该作者 1楼 发表于: 2008-05-14
离线zhouye018
只看该作者 2楼 发表于: 2008-05-14
离线further
只看该作者 3楼 发表于: 2008-05-14
急需啊,楼主,下不了。。。。
厚德载物,自强不息!
离线further
只看该作者 4楼 发表于: 2008-05-14
谢谢楼主分享,急用。。。。
厚德载物,自强不息!
离线further
只看该作者 5楼 发表于: 2008-05-14
楼主帮忙啊
厚德载物,自强不息!
离线qinxinyi
只看该作者 6楼 发表于: 2008-05-15
楼主帮忙啊
念了十几年书,想起来还是幼儿园比较好混。
离线qinxinyi
只看该作者 7楼 发表于: 2008-05-15
    好样的  我看看    我正在做这方面的事
离线mafei210
只看该作者 8楼 发表于: 2008-05-15
版主,怎么不能下载啊。我急需
离线mafei210
只看该作者 9楼 发表于: 2008-05-15
楼主帮帮忙啊。急需
离线mafei210
只看该作者 10楼 发表于: 2008-05-16
不能用。骗子
离线mesmer951
只看该作者 11楼 发表于: 2008-05-16
先下来看看
