genzone brick p0 0 0 0 p1 111.4 0 0 p2 0 10 0 p3 0 0 45 size 11 1 5 group 1
gen zone brick p0 0 0 45 p1 111.4 0 45 p2 0 10 45 p3 0 090 p4 111.4 10 45 & p5 0 10 90 p6 47 0 90 p7 47 10 90 size 11 1 9 group 3
gen zone wedge p0 66.4 0 90.1 p1 47 0 90.1 p2 66.4 1090.1 p3 111.4 0 45.1 & p4 47 10 90.1 p5 111.4 10 45.1 size 5 1 9 group 4
interface 1 face range plane norm 45,0,64.4 origin 47 590 dist=0.1
ini z add -0.1 range group 4
gen zone brick p0 111.4 0 0 p1 128 0 0 p2 111.4 10 0 p3111.4 0 45 &
size 2 1 5 group 2
modelmohr
pro bulk=1e8 she=3e7 dens 2e3 coh 12e3 &
friction 20 dilation 0. tension 1.0e10 range group 1
friction 20 dilation 0. tension 1.0e10 range group 2
int 1 prop ks 2e12 kn 2e12 fric 36
friction 20 dilation 0. tension 1.0e10 range group 3
friction 20 dilation 0. tension 1.0e10 range group 4
fix z range z -0.1 0.1
fix x range x -0.1 0.1
fix x range x 127.9 128.1
fix y
set gravity 0 0 -10
step 1000
ini state 0
ini xdis 0 ydis 0 zdis 0
;ini xvel 0 yvel 0 zvel 0
;set large
step 1000
;solve fos file cable.sav associated
以上为建立的interface的例子,但怎么运行出现 unrecognised parameter 41(gen) ..我自己把 gen zone wedge p0 66.4 0 90.1 p1 47 0 90.1 p2 66.4 10 90.1 p3 111.4 0 45.1 & p4 47 10 90.1 p5 111.4 10 45.1 size 5 1 9 group 4 命令单独输入时候没有出现问题,怎么运行整个程序时候就出现 “unrecognised parameter 41(gen)”,望大神指教
