  • 1728阅读
求教:组合桩+褥垫层的命令流 [复制链接]
离线小沫aini
只看楼主 倒序阅读 使用道具 楼主  发表于: 2014-07-31
刚开始学,按书上的例子改写的,但是书上没有加褥垫层,大家看看写的哪里出错了,谢谢!!!
;带承台组合桩模拟,单桩直径600mm,1、4号桩为长桩20m,2、3号桩为短桩5m
n
;承台下土体模型的建立
;1号桩
gen zone radcyl p0  (0,0,0)  p1  (0.9,0,0)  p2  (0,0,-20)  p3  (0,0.9,0)  &
                p4  (0.9,0,-20) p5  (0,0.9,-20) p6  (0.9,0.9,0)   p7  (0.9,0.9,-20) &
                p8  (.3,0,0)  p9  (0,.3,0)  p10 (.3,0,-20)  p11 (0,.3,-20) &
                size 3 20 6 3  ratio 1 1 1 1.4
gen zone radcyl p0  (0,0,-20)  p1  (0.9,0,-20)  p2  (0,0,-25)  p3  (0,0.9,-20)  &
                p4  (0.9,0,-25) p5  (0,0.9,-25) p6  (0.9,0.9,-20)   p7  (0.9,0.9,-25) &
                p8  (.3,0,-20)  p9  (0,.3,-20)  p10 (.3,0,-25)  p11 (0,.3,-25) &
                size 3 5 6 3  ratio 1 1 1 1.4 fill
;2号桩
gen zone radcyl p0  (1.8,0,0)  p1  (2.7,0,0)  p2  (1.8,0,-5)  p3  (1.8,0.9,0)  &
                p4  (2.7,0,-5) p5  (1.8,0.9,-5) p6  (2.7,0.9,0)   p7  (2.7,0.9,-5) &
                p8  (2.1,0,0)  p9  (1.8,0.3,0)  p10 (2.1,0,-5)  p11 (1.8,0.3,-5) &
gen zone radcyl p0  (1.8,0,-5)  p1  (2.7,0,-5)  p2  (1.8,0,-25)  p3  (1.8,0.9,-5)  &
                p4  (2.7,0,-25) p5  (1.8,0.9,-25) p6  (2.7,0.9,-5)   p7  (2.7,0.9,-25) &
                p8  (2.1,0,-5)  p9  (1.8,0.3,-5)  p10 (2.1,0,-25)  p11 (1.8,0.3,-25) &
                size 3 20 6 3  ratio 1 1 1 1.4 fill
gen zone reflect normal 1 0 0 ori 1.8 0 0 range x 1.8 2.7 y 0 0.9
;3号桩
gen zone copy -1.8 1.8 0 ran x 1.8 2.7 y 0 0.9
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 0 0.9 y 1.8 2.7
;4号桩
gen zone copy 1.8 1.8 0 ran x 0 0.9 y 0 0.9
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 1.8 2.7 y 1.8 2.7
gen zone reflect normal 1 0 0 ori 1.8 0 0 ran x 1.8 2.7 y 0.9 2.7
;承台外土体模型的建立,6m
gen zone radtunnel p0  (0,0,0)  p1  (6,0,0)  p2  (0,0,-25)  p3  (0,6,0)  &
                p4  (6,0,-25) p5  (0,6,-25) p6  (6,6,0)   p7  (6,6,-25) &
                p8  (2.7,0,0)  p9  (0,2.7,0)  p10 (2.7,0,-25)  p11 (0,2.7,-25) p12 (2.7,2.7,0) p13 (2.7,2.7,-25) &
                size 9 25 9 5  ratio 1 1 1 1.3
group clay ran z -20 0
group sand ran z -20 -25
;1号桩接触面
interface 1 face range cylinder end1 (0,0,0.1)  end2 (0,0,-20.1) radius .31 &
                       cylinder end1 (0,0,0.1)  end2 (0,0,-20.1) radius .29 not
interface 2 face range cylinder end1 (0,0,-19.9) end2 (0,0,-20.1) radius .31
;2号桩接触面
interface 3 face range cylinder end1 (1.8,0,0.1)   end2 (1.8,0,-5.1) radius .31 &
                       cylinder end1 (1.8,0,0.1)   end2 (1.8,0,-5.1) radius .29 not
interface 4 face range cylinder end1 (1.8,0,-4.9) end2 (1.8,0,-5.1) radius .31
;3号桩接触面
interface 5 face range cylinder end1 (0,1.8,0.1)   end2 (0,1.8,-5.1) radius .31 &
                       cylinder end1 (0,1.8,0.1)   end2 (0,1.8,-5.1) radius .29 not
interface 6 face range cylinder end1 (0,1.8,-4.9) end2 (0,1.8,-5.1) radius .31
;4号桩接触面
interface 7 face range cylinder end1 (1.8,1.8,0.1)   end2 (1.8,1.8,-20.1) radius .31 &
                       cylinder end1 (1.8,1.8,0.1)   end2 (1.8,1.8,-20.1) radius .29 not
interface 8 face range cylinder end1 (1.8,1.8,-19.9) end2 (1.8,1.8,-20.1) radius .31
;建立桩体模型
;1号桩
gen zone cyl p0 (0,0,21) p1 (.3,0,21) p2 (0,0,1)  p3 (0,.3,21)  &
             p4 (.3,0,1) p5 (0,.3,1) &
             size 1 20 6
;2号桩
gen zone cyl p0 (1.8,0,27) p1 (2.1,0,27) p2 (1.8,0,22)  p3 (1.8,.3,27)  &
             p4 (2.1,0,22) p5 (1.8,.3,22) &
             size 1 5 6
gen zone reflect normal 1 0 0 ori 1.8 0 0 ran x 1.8 2.1 y 0 0.3 z 22 27
;3号桩
gen zone copy -1.8 1.8 0 ran x 1.8 2.1 y 0 0.3 z 22 27
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 0 0.3 y 1.8 2.1 z 22 27
;4号桩
gen zone copy 1.8 1.8 0 ran x 0 0.3 y 0 0.3 z 1 21
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 1.8 2.1 y 1.8 2.1 z 1 21
gen zone reflect normal 1 0 0 ori 1.8 0 0 ran x 1.8 2.1 y 1.5 2.1 z 1 21
group zhuang14 range z 1 21
ini z add -21.0 range group zhuang14
group zhuang23 range z 22 27
ini z add -27.0 range group zhuang23
;建立垫层模型
;1号桩
gen zone cyl p0 (0,0,6) p1 (.3,0,6) p2 (0,0,5.7)  p3 (0,.3,6)  &
             p4 (.3,0,5.7) p5 (0,.3,5.7) &
             size 1 1 6
gen zone radcyl p0  (0,0,6)  p1  (0.9,0,6)  p2  (0,0,5.7)  p3  (0,0.9,6)  &
                p4  (0.9,0,5.7) p5  (0,0.9,5.7) p6  (0.9,0.9,6)   p7  (0.9,0.9,5.7) &
                p8  (.3,0,6)  p9  (0,.3,6)  p10 (.3,0,5.7)  p11 (0,.3,5.7) &
                size 3 1 6 3  ratio 1 1 1 1.4
;2号桩
gen zone copy 1.8 0 0 ran z 5.7 6
gen zone reflect normal 1 0 0 ori 1.8 0 0 ran x 1.8 2.7 z 5.7 6
;3号桩
gen zone copy 0 1.8 0 ran x 0 0.9 z 5.7 6
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran y 1.8 2.7 z 5.7 6
;4号桩
gen zone copy 0 1.8 0 ran x 0.9 2.7 z 5.7 6
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 0.9 2.7 y 1.8 2.7 z 5.7 6
group DC ran z 5.7 6
interface 9 face range z 5.69 5.71
ini z add -5.7 range group DC
;建立承台模型
;1号桩
gen zone cyl p0 (0,0,6.6) p1 (.3,0,6.6) p2 (0,0,6)  p3 (0,.3,6.6)  &
             p4 (.3,0,6) p5 (0,.3,6) &
             size 1 1 6
gen zone radcyl p0  (0,0,6.6)  p1  (0.9,0,6.6)  p2  (0,0,6)  p3  (0,0.9,6.6)  &
                p4  (0.9,0,6) p5  (0,0.9,6) p6  (0.9,0.9,6.6)   p7  (0.9,0.9,6) &
                p8  (.3,0,6.6)  p9  (0,.3,6.6)  p10 (.3,0,6)  p11 (0,.3,6) &
;2号桩
gen zone copy 1.8 0 0 ran z 6 6.6
gen zone reflect normal 1 0 0 ori 1.8 0 0 ran x 1.8 2.7 z 6 6.6
;3号桩
gen zone copy 0 1.8 0 ran x 0 0.9 z 6 6.6
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran y 1.8 2.7 z 6 6.6
;4号桩
gen zone copy 0 1.8 0 ran x 0.9 2.7 z 6 6.6
gen zone reflect normal 0 1 0 ori 0 1.8 0 ran x 0.9 2.7 y 1.8 2.7 z 6 6.6
group cap ran z 6 6.6
ini z add -5.7 range group cap
pau
save pile_geom.sav
model mohr                                              range group clay
prop bulk 2.9033e6  shear 1.34e6  coh 24.7e3 fric 28.2  range group clay
model mohr                                              range group sand
prop bulk 11.433e6  shear 2.45e6  coh 9.76e3 fric 24.3  range group sand
model elas                         range group DC
prop bulk 2.9033e6  shear 1.34e6   range group DC
model elas                         range group cap
prop bulk 2.9033e6  shear 1.34e6   range group cap
model elas                         range group zhuang14
prop bulk 2.9033e6  shear 1.34e6   range group zhuang14
model elas                         range group zhuang23
prop bulk 2.9033e6  shear 1.34e6   range group zhuang23
;0.8c、fai
interface 1 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 2 prop kn 1e9  ks 1e9  coh 300000    fric 45
interface 3 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 4 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 5 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 6 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 9 prop kn 1e8  ks 1e8  coh 0         fric 0
interface 7 prop kn 1e8  ks 1e8  coh 19.76e3   fric 22.56
interface 8 prop kn 1e9  ks 1e9  coh 300000    fric 45
ini dens 1930 range group clay
ini dens 1550 range group sand
ini dens 1930 range group DC
ini dens 1930 range group cap
ini dens 1930 range group zhuang14
ini dens 1930 range group zhuang23
model null range z -0.1 0.95
fix z range z -25.1 -24.9
fix x range x -0.1 0.1
fix x range x 5.9 6.1
fix y range y -.1 .1
fix y range y 5.9 6.1
set grav 0 0 -10
hist unbal
solve
save pile0.sav
离线探索者
只看该作者 1楼 发表于: 2014-11-25
谢谢您的经验分享,我跟您一样也是要做褥垫层跟桩的组合!我也是初学者!!!
只看该作者 2楼 发表于: 2014-11-26
New learner。。。
离线探索者
只看该作者 3楼 发表于: 2014-11-27
追问一下,您的垫层是碎石垫层吗???谢谢您的回答!!
