  • 4875阅读
  • 1回复
为什么没pfc的版块发帖?pfc直剪的命令流和问题 [复制链接]
离线376872386
只看楼主 倒序阅读 使用道具 楼主  发表于: 2014-09-02
请教各位帮忙看看,我用的是颗粒球的加载,不是伺服,因为自己写的一个墙体伺服加载错了运行不了,就改用球的了(希望好心人有墙体加载的直剪命令发我下哈),出现了下面两个错误。
1.直剪的结果是上盒的球体往上走了。
2.上盒球体加的力该怎么算成应力。prop yforce=-1e6 range x 0,0.07 y 0.059,0.06
(添加不来附件啊,不好意思了,复制到下面)
模型建立
;fname: biax_1.DAT  Creation and packing of particles - biaxial sample
new
set random   ;reset random-number generator
set disk on    ;treat balls as disks of unit thickness
;creat walls with overhang of extend
def make_walls
    extend = 1.0
    _x0 = width
    _y0 = height/2
    _x1 =  width
    _y1 = height* (1.0 + extend)
    command
        wall id = 1 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = -width/2
    _y0 = 0.0
    _x1 = width* (1.0 + extend/2)
    _y1 = 0
    command
        wall id = 2 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = 0.0
    _y0 = height * (1.0 + extend)
    _x1 = 0.0
    _y1 = height/2
    command
        wall id = 3 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = width* (1.0 + extend/2)
    _y0 = height
    _x1 = -width/2
    _y1 =  height
    command
        wall id = 4  kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = 0.0
    _y0 = height/2
    _x1 = 0.0
    _y1 = -height
    command
        wall id = 5 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = width
    _y0 = -height
    _x1 = width
    _y1 = height/2
    command
        wall id = 6 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = -width
    _y0 = height/2
    _x1 = 0
    _y1 = height/2
    command
        wall id = 7 kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
    _x0 = width
    _y0 = height/2
    _x1 = width* (1.0 + extend)
    _y1 = height/2
    command
        wall id = 8  kn = w_stiff nodes (_x0,_y0) (_x1,_y1)
    end_command
end
; assemble sample
def assemble
    s_stiff  = 0.0      ;shear   stiffness
    n_stiff = 5e8     ;normal   contact stiffness
    w_stiff = 5e9     ;
    tot_vol = height * width * 1.0
    rbar=0.5 * (rlo + rhi)                                             ;求颗粒的平均半径
    num = int((1.0 - poros) * tot_vol / (pi*rbar^2)) ;求可生成颗粒的总数目
    mult = 1.6        ;initial radius multiplication factor
    rlo_0 = rlo / mult                                                     ;initial minimum radius
    rhi_0 = rhi / mult                                                     ;initial maximum radius
    make_walls
    command
        gen id=1,num rad=rlo_0,rhi_0 x=0,width y=0,height tries 10000000
        prop dens=1000 ks=s_stiff kn=n_stiff
    end_command
    ii = out(string(num)+' particles were created')
; get actual porosity
    sum = 0.0
    bp = ball_head
    loop while bp # null                                                  ;通过遍历所有颗粒计算颗粒总体积
        sum = sum + pi * b_rad(bp)^2
        bp = b_next(bp)
    end_loop
    pmeas = 1.0 - sum / tot_vol                                       ;actual porosity
    mult = sqrt((1.0 - poros) / (1.0 - pmeas))
    command
         ini rad mul mult
         cycle 1000
         prop ks=5e8 fric 0.25
         cycle 250
    end_command
end
set dt dscale
print info
; change lateral wall stiffnesses
def cws
    command
        wall id 2 kn=w_stiff
        wall id 4 kn=w_stiff
    end_command
end
macro zero 'ini xvel 0 yvel 0 spin 0'       ;通过采用宏macro将命令'ini xvel 0 yvel 0 spin 0'简化为zero
    SET height=0.06 width=0.07 rlo=0.0003 rhi=0.0004 poros=0.1
assemble
    SET w_stiff= 5e8                               ; make lateral wall stiffness=1/10 of ball stiffness
cws
cyc 500
zero
def bound
    bp=ball_head
    loop while bp#null                   ;scan all balls
    section
        cp=b_clist(bp)
        loop while cp # null             ;scan ball's contacts
            if c_nforce(cp) # 0.0 then
                b2=c_ball2(cp)
                if pointer_type(b2)=101 then ;b2 is a wall
                    b_xfix(bp)=1               ;fix original ball in x,y
                    b_yfix(bp)=1
                    b_color(bp)=1
                    exit section               ;all done for this ball
                end_if
            end_if
            if c_ball1(cp)=bp
                cp=c_b1clist(cp)
            else
                cp=c_b2clist(cp)
            end_if
        end_loop
    end_section
    bp=b_next(bp)
  end_loop
end
bound
ini xvel=0 yvel=0 spin=0
del wall 1
del wall 2
del wall 3
del wall 4
cycle 1
def replace ;Replace unbalanced forces wiht applied forces
    bp=ball_head
        if b_xfix(bp)=1
            b_xfap(bp)=-b_xfob(bp)
            b_yfap(bp)=-b_yfob(bp)
        end_if
        bp=b_next(bp)
    end_loop
end
def qingling
bp=ball_head
  b_xvel(bp)=0
  b_yvel(bp)=0
  b_xdisp(bp)=0
  b_ydisp(bp)=0
bp=b_next(bp)
end_loop
end;-----------------------------------------------------------------------------------------------------
JSET id=1 dip=0 origin=(0.035,0.03)
replace
qingling
save MX.SAV
pause
; ;给定力学参数
prop fric=0.5
prop pb_kn=1e8 pb_ks=1e8 pb_rad=0.5
prop pb_nstren=5e7 pb_sstren=5e7
property n_bond=0 s_bond=0 range jset 1
property fric 0.2 range jset 1
plot creat bound_condition
plot add ball blue red
;plot add vel black
;plot add cf white
plot show
cycle 1000
; ;施加边界条件
free x y range x 0.001,0.069 ;leave ends fixed
ini xvel=1e-6  range x 0,0.001 y 0.03,0.06
fix x  range x 0,0.001 y 0.03,0.06
ini xvel=1e-6  range x 0,0.07 y 0.059,0.06
fix x   range x 0,0.07 y 0.059,0.06
ini xvel=1e-6  range x 0.069,0.07 y 0.03,0.06
fix x   range x 0.069,0.07 y 0.03,0.06
fix y range x 0,0.07 y 0,0.001
cycle 1000
离线wangjianqun
只看该作者 1楼 发表于: 2014-09-02
pfc5.0版交流群  104409137
本人有巨量岩土工程资料3.6个G还有理正软件及勘察软件等岩土软件。想要的联系我QQ是603481026
