  • 5411阅读
  • 20回复
Theoretical Geomechanics.pdf [复制链接]
离线myfreelife
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-05-28
Theoretical Geomechanics.pdf (676 K) 下载次数:172
共1条评分 ,土币+5
wangallen88 土币 +5 优秀资料,感谢! 2014-01-17
离线pipilu1984
只看该作者 1楼 发表于: 2008-07-02
INTRODUCTION
These course notes present some theoretical problems related to the Mechanics of a Continuum Solid Body, of particular
importance to Applied Geomechanics, Geological Engineering and Structural Geology. In most cases, only static aspects are
discussed, but some dynamic cases are also presented.
As a rule, the modern tensorial approach is used. Some basic elements are reviewed at the beginning of the notes. More details
can be found into the excellent books of George Backus and Brian Kennett, also available at Samizdat Press. The linear
elasticity and the homogeneity of the continuum solid body are almost thoroughly assumed to be valid, but some elements of
Rheology are also presented.
In most cases, the semi-inverse method is used to solve the problems. According to it, the solution is supposed to be of a
particular form, as a consequence of the simplified hypothesis previously assumed. It is verified that solution checks both the
corresponding equations and the boundary conditions. Based on the Uniqueness Theorem of the Linear Elasticity, it follows the
assumed particular solution is just the general solution of the problem. In all the cases discussed here, the assumed simplified
hypotheses allow one to obtain simple, analytical solutions. At a first glance, the importance of such solutions is minor with
respect to the real cases, where mainly the non-homogeneity of the medium plays a great role. However, the analytical solutions
are the basis for deriving finite element algorithms, allowing one to model satisfactory the complex real cases. Such examples
are also presented.
The author will kindly appreciate any critical remarks on these notes, being very grateful to Samizdat Press for the possibility
to shear his work.
离线chunjunzhang
只看该作者 2楼 发表于: 2008-07-12
本书是一本很专业的书
离线keepfit
只看该作者 3楼 发表于: 2009-06-03
gooooooood
君子務本,本立而道生。
离线paladin10
只看该作者 4楼 发表于: 2009-06-12
好东西,学习了
博觀而約取,厚積而薄發。
离线sjzdh01
只看该作者 5楼 发表于: 2009-07-04
下载学习学习,谢谢提供分享
离线monchhichi
只看该作者 6楼 发表于: 2009-07-27
cheers
离线whwang2001
只看该作者 7楼 发表于: 2009-11-06
xiexie
离线ylxiong
只看该作者 8楼 发表于: 2009-12-20
just download
离线bangsaruoa
只看该作者 9楼 发表于: 2010-06-01
谢谢分享。不错的资料
离线edelmann
只看该作者 10楼 发表于: 2010-11-02
谢谢楼主!
好好学习学习。
有用啊!
离线smilefeng
只看该作者 11楼 发表于: 2010-11-07
呵呵 谢谢楼主啊
