  • 1686阅读
  • 1回复
FLAC中的open write read 的用法 [复制链接]
离线good1990919
只看楼主 倒序阅读 使用道具 楼主  发表于: 2015-11-07
大家有谁用过open write read 的用法?能否给我举个例子,调用了好几次都是失败的,谢谢
离线茳上风
只看该作者 1楼 发表于: 2015-12-01
def array_initiate
  array line(100)
  line_ptr=0
end
@array_initiate
def linkforce
    loop n(1,36)
    lkid=10001+(n-1)*10000
    lp=find_lk(lkid)
    lkfo_x=lk_ldrfor(lp,1)
    lkfo_y=lk_ldrfor(lp,2)
    lkfo_z=lk_ldrfor(lp,3)
    lkid2=lkid
    line_ptr=line_ptr+1
    line(line_ptr)=string(lkfo_x) + '  ' + string(lkfo_y) + '  ' + string(lkfo_z) + '  ' + string(lkid)
    end_loop
end
@linkforce
def file_write
  filename='lk_force5_3_1.txt'
  file_status = open(filename, 1, 1)
  file_status = write(line, line_ptr)
  file_status = close
end
@file_write
