  • 9363阅读
  • 9回复
[建筑地基]砂石垫层承载力能达到多少? [复制链接]
离线zhangxutao
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-06-04
请问砂石垫层承载力能达到多少?我做结构设计,30层住宅楼,筏板基础下是泥卵,承载力只有180kPa,其下是卵石层,如挖除泥卵,采用砂石垫层,用重碾路机碾压,承载力能达到500kPa吗?
共鲜花(dahengba) 热烈祝贺今天起正式实行岩土工程师注册制度条评分
离线georgexue
只看该作者 1楼 发表于: 2008-06-04
The bearing capacity of soil is determined by some important factors, such as soil properties of all the layers, embeddment depth, ground water level, surcharge force. Kd`(^
(QiA5!wg
the building you are designing is high-rise and should be considered carefully. e4tIO
i=aR ~
If it is convenient, it will be better to upload some soil profile and site condition information for the experts in this forum to discuss.
离线georgexue
只看该作者 2楼 发表于: 2008-06-04
very humorous but impressive reply from Prof B.H.Fellenius about the compressibility calculation after backfill on embankment. cjEqN8
" Note, there is no excuse for omitting determining the compressibility and preconsolidation stress, the most basic of soils investigation. Would you accept the advice of a physician who in response to your consulting needs would not check your blood pressure, heart rate, and general state of health, but just decide your treatment by reference to a text book?"
离线凿岩者
只看该作者 3楼 发表于: 2008-06-05
你可以做实验啊,最直接的现场的载荷试验,这个可以说明承载力能不能达到500KPa
离线wdjingping
只看该作者 4楼 发表于: 2008-06-07
规范条文说明有:碎石,卵石:200~300 = ^NvUrK
砂夹石200~250
离线hbdks
只看该作者 5楼 发表于: 2008-06-07
你查一查相关规范,砂石垫层承载力好像不能达到500kPa,记得好像只能提高200kPa左右。 ,x8;| o5
没做过砂石垫层施工,砂石垫层能用重碾路机碾压吗?
离线mmdpp
只看该作者 6楼 发表于: 2010-08-06
应该可以,对砂砾石料有要求
离线illusion_110
只看该作者 7楼 发表于: 2010-08-08
达不到你的要求的吧
学海无涯!
只看该作者 8楼 发表于: 2010-08-08
一般200~300KPA,须做载荷试验。
离线swjtuwzd
只看该作者 9楼 发表于: 2013-10-28
直接用素混凝土浇
理论联系实践,多多交流,一起进步。
