  • 4163阅读
[求助]求教大神FLAC3D 5.0版本如何将主应力导入tecplot并计算能量 [复制链接]
离线lyp90123
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-01-04
以前用3.0版本的时候有一个程序段,可以输出一个dat文件,导入tecplot可以看到能量,换成5.0版本之后不能用了,哪位大神能帮忙修改一下?
老程序如下:
;; Initialization
def ini_mesh2tec
    IO_READ  = 0
       IO_WRITE = 1
    IO_FISH  = 0
    IO_ASCII = 1
    N_RECORD = 5
    ZONE_NGP = z_numgp(zone_head)
    array buf(1)
    tec_file = 'tec10.dat'
;; Edit the tec_range to set plot range
    command
        ran name tec_range
    endcommand
end
ini_mesh2tec
;; If plotit = 1, plot the zone
def plot_test
    plotit = 1
    if z_model(p_z) = 'NULL' then
        plotit = 0
    endif
    if inrange('tec_range',p_z) = 0 then
        plotit = 0
    endif
end
;; Get number of zones to plot
def get_nzone
    n_zone = 0
    p_z = zone_head
    loop while p_z # null
        plot_test
        if plotit = 1 then
            n_zone = n_zone + 1
        endif
        p_z = z_next(p_z)
    endloop
end
get_nzone
;; Write Tecplot File Head
def write_head
    buf(1) = 'TITLE     = "FLAC3D to Tecplot 10"\n'
    buf(1) = buf(1) + 'VARIABLES = "X(m)" \n"Y(m)" \n"Z(m)" \n'
    buf(1) = buf(1) + '"DISP(m)" \n"XDISP(m)" \n"YDISP(m)" \n"ZDISP(m)" \n'
    buf(1) = buf(1) + '"SIG1(Pa)" \n"SIG2(Pa)" \n"SIG3(Pa)" \n'
    buf(1) = buf(1) + '"SXX(Pa)" \n"ENERGY(J)" \n"SZZ(Pa)" \n'
    buf(1) = buf(1) + 'ZONE T="GLOBAL" \n'
    buf(1) = buf(1) + ' N=' + string(ngp) + ','
    buf(1) = buf(1) + ' E=' + string(n_zone) + ','
    if ZONE_NGP = 4 then
        buf(1) = buf(1) + ' ZONETYPE=FETETRAHEDRON \n'
    else
        buf(1) = buf(1) + ' ZONETYPE=FEBrick \n'
    endif
    buf(1) = buf(1) + ' DATAPACKING=BLOCK \n'
    buf(1) = buf(1) + ' VARLOCATION=([8-13]=CELLCENTERED) \n'
    buf(1) = buf(1) + ' DT=(SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE SINGLE SINGLE )'
    status = write(buf,1)
end
;; Calculate displacement magnitude
def get_gp_disp
    gp_disp = gp_xdisp(p_gp)*gp_xdisp(p_gp)
    gp_disp = gp_disp + gp_ydisp(p_gp)*gp_ydisp(p_gp)
    gp_disp = gp_disp + gp_zdisp(p_gp)*gp_zdisp(p_gp)
    gp_disp = sqrt(gp_disp)
end
;弹性模量和泊松比需在此输入
def get_z_energy
bosong=0.28
tanmo=350000000
    z_energy = z_sig1(p_z)*z_sig1(p_z)
    z_energy = z_energy + z_sig2(p_z)*z_sig2(p_z)
    z_energy = z_energy + z_sig3(p_z)*z_sig3(p_z)
     z_energy = z_energy -2*bosong* z_sig1(p_z)*z_sig2(p_z)
     z_energy = z_energy -2*bosong* z_sig1(p_z)*z_sig3(p_z)
    z_energy = z_energy -2*bosong* z_sig2(p_z)*z_sig3(p_z)
    z_energy = z_energy/2
    z_energy = z_energy/tanmo
end
;; Write gp-related data,such as Coordinates and Displacements
def write_gp_info
    p_gp = gp_head
    loop while p_gp # null
        buf(1) = ''
        loop i(1,N_RECORD)
            if p_gp # null then
                caseof  info_flag
                    case 0
                        buf(1) = buf(1) + string(gp_xpos(p_gp)) + '  '
                    case 1
                        buf(1) = buf(1) + string(gp_ypos(p_gp)) + '  '
                    case 2
                        buf(1) = buf(1) + string(gp_zpos(p_gp)) + '  '
                    case 4
                        get_gp_disp
                        buf(1) = buf(1) + string(gp_disp) + '  '
                    case 8
                        buf(1) = buf(1) + string(gp_xdisp(p_gp)) + '  '
                    case 16
                        buf(1) = buf(1) + string(gp_ydisp(p_gp)) + '  '
                    case 32
                        buf(1) = buf(1) + string(gp_zdisp(p_gp)) + '  '
                endcase
                p_gp = gp_next(p_gp)
            endif
        endloop
    endloop
end
;; Write zone-related data,such as Stresses
def write_zone_info
    p_z = zone_head
        buf(1) = ''
        loop i(1,N_RECORD)
            if p_z # null then
                plot_test
                if plotit = 1 then
                    caseof  info_flag
                        case 0
                            buf(1) = buf(1) + string(z_sig1(p_z)) + '  '
                        case 1
                            buf(1) = buf(1) + string(z_sig2(p_z)) + '  '
                        case 2
                            buf(1) = buf(1) + string(z_sig3(p_z)) + '  '
                        case 4
                            buf(1) = buf(1) + string(z_sxx(p_z)) + '  '
                        case 8
                         get_z_energy
                            buf(1) = buf(1) + string(z_energy) + '  '
                        case 16
                            buf(1) = buf(1) + string(z_szz(p_z)) + '  '
                    endcase
                endif
                p_z = z_next(p_z)
            endif
        endloop
    endloop
end
;; Write Zone Connectivity
def write_zone
    p_z = zone_head
        buf(1) = '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 1))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 2))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 3))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 4))) + '  '
        else
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 5))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 7))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 8))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 6))) + '  '
        endif
        plot_test
        if plotit = 1 then
        endif
        p_z = z_next(p_z)
    endloop
end
;; Main Function
def mesh2tec
    status = close
    status = open(tec_file,IO_WRITE,IO_ASCII)
    if status = 0 then
        write_head
        info_flag = 0
        write_gp_info
        info_flag = 1
        write_gp_info
        info_flag = 2
        write_gp_info
        info_flag = 4
        write_gp_info
        info_flag = 8
        write_gp_info
        info_flag = 16
        write_gp_info
        info_flag = 32
        write_gp_info
        info_flag = 0
        write_zone_info
        info_flag = 1
        write_zone_info
        info_flag = 2
        write_zone_info
        info_flag = 4
        write_zone_info
        info_flag = 8
        write_zone_info
        info_flag = 16
        write_zone_info
        write_zone
        status = close
        ii = out('Successfully Write ' + string(n_zone) + ' Zone Data Into File ' + tec_file)
    else
        ii=out('Open File Error! Status = ' + string(status))
    endif
end
mesh2tec
离线laiyonghui
只看该作者 1楼 发表于: 2016-04-25
你好,你的问题解决了,我想请教你啊,希望给与帮助
离线无言琥珀
只看该作者 2楼 发表于: 2018-08-31
你好 大神 你的问题解决了吗 可以分享一下吗 谢谢您
