  • 1354阅读
  • 0回复
abaqus建立砂井排水固结最后提交submit计算提示出现如下错误,请问是什么原因? [复制链接]
离线911110lfl
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-06-21
The job "Job-3" has been created.
The job input file "Job-3.inp" has been submitted for analysis.
Error in job Job-3: Permeability is specified on 496 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
Job Job-3: Analysis Input File Processor aborted due to errors.
Error in job Job-3: Analysis Input File Processor exited with an error.
Job Job-3 aborted due to errors.
