  • 1778阅读
  • 0回复
abaqus建模计算出现error,可视化模块没有图像,field output空白 [复制链接]
离线911110lfl
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-06-24
错误:Permeability is specified on 238 elements but the initial void ratio is not defined. Use *initial conditio n s  to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
