  • 3050阅读
  • 0回复
abaqus提交计算出现错误 [复制链接]
离线911110lfl
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-09-25
in keyword *INITIALCONDITION, file "a.inp", line 2273: Unknown part instance node set PART-1-1.SOIL
in keyword *INITIALCONDITION, file "a.inp", line 2273: Unknown part instance node set PART-1-1.SANDWELL
An initial condition has been specified on node set assembly_part-1-1_soil. This node set is not active in the model
An initial condition has been specified on node set assembly_part-1-1_sandwell. This node set is not active in the model
Permeability is specified on 864 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
