  • 2183阅读
[热点探讨]pile property?soil property?which is more important? [复制链接]
离线georgexue
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-06-12
many specialists are discussing the pile properties, such as the concrete strength, bending moment, bearing capacity etc. AYsHA w
I am wondering the design principle for a geotechnical engineer. j5smmtM`s
what kind of position in your mind is it, for the soil properties when the piles are designed? 4 B[uF/[
please elaborate what you have thought about and explain it accordingly. T`u ,!S
it is a better way to discuss it with some practical problems. =RM]/O9
离线parkdai
只看该作者 1楼 发表于: 2008-08-25
They are the same important.
戴斌
北京荣创岩土工程股份有限公司
教授级高级工程师
注册土木工程师(岩土)
离线lypjspdi
只看该作者 2楼 发表于: 2008-08-26
the design of pile is on the base the safety of the soil, that is ,the soil is not failued
原来是这样!
离线parkdai
只看该作者 3楼 发表于: 2008-08-26
The base of the design of pile fundation is the bearing capacity  and the settlement. The bearing capacity of pile depends on the soil's support, and the trength of pile's structure. The settlement of pile foundation also depends on the strata under the foundation, and  s/d (piles distance over diameter ).
戴斌
北京荣创岩土工程股份有限公司
教授级高级工程师
注册土木工程师(岩土)
