  • 3551阅读
  • 1回复
geostudio-2012-seep学习(提醒:英文图文解说,不喜勿喷) [复制链接]
离线991824329
只看楼主 倒序阅读 使用道具 楼主  发表于: 2017-03-14
附件出售:1D Exit Review Example.pdf附件出售:1D Verification Examples.pdf附件出售:AIR Tutorial.pdf附件出售:Anisotropy in seepage analyses.pdf附件出售:Caesium 137 Transport in an Unconfined Aquifer.pdf附件出售:Case History Passive Cooling of Permafrost by Air Convection.pdf附件出售:Chimney Venting.pdf附件出售:Convective Air Flow in Heated Column.pdf附件出售:CTRAN Tutorial.pdf附件出售:Cutoff with anisotropy in foundation.pdf附件出售:Dam with concrete cutoff.pdf附件出售:Exit gradient in a seepage analysis.pdf附件出售:Filling pond H vs V functions.pdf附件出售:Freezing Around Pipe with Flowing Water.pdf附件出售:Heave due to infiltration.pdf附件出售:Henry Density Dependent.pdf附件出售:Increasing Temp and Air Pressure in Closed Box.pdf附件出售:Infiltration and Air Pressure Build Up.pdf附件出售:Leakage from pond with clay liner.pdf附件出售:Lower San Fernando Dam.pdf附件出售:Lysimeter behavior.pdf附件出售:Modeling drains.pdf附件出售:Pressure Plate Drying and Wetting.pdf附件出售:Rapid drawdown with effective stress.pdf附件出售:Rapid drawdown.pdf附件出售:Rapid drawdown2.pdf附件出售:Relief well spacing.pdf附件出售:Salt Flow Example.pdf附件出售:Seepage thru an earth embankment.pdf附件出售:Settlement due to pumping well.pdf附件出售:Stability with FE pore water pressure.pdf附件出售:Stability with perched watertable.pdf附件出售:Tunneling Under Air Pressure.pdf附件出售:Upper San Fernando Dam.pdf附件出售:Verification - Consolidation with SEEP.pdf附件出售:Verification - infiltration into dry soil.pdf附件出售:Verification - preferential flow in vertical layers.pdf附件出售:Verification - radial flow to a well.pdf附件出售:Verification - the Kisch leakage problem.pdf附件出售:Verification - the sandbox problem.pdf
离线Sssswait
只看该作者 1楼 发表于: 2018-03-15
这么厉害,英文太差了。还是非常感谢。
