  • 1782阅读
  • 0回复
FLAC2D问题请教各位大神~ [复制链接]
离线iloveyoutoo
只看楼主 倒序阅读 使用道具 楼主  发表于: 2017-07-11
各位好:
     小弟目前在用FLAC2D7.0模拟加筋地基,用strip结构单元来模拟土工条带。现在遇到一个问题,想通过指针,监测strip各个单元部分(segment)的轴力情况,将轴力最大处的segment的轴力和ID号输出。目前小弟对指针不甚熟悉,手册中有一例子可供参考,但小弟怎么修改都达不到目的。请各位指点!
手册中的类似算例如下。个人理解是指针分层次,里面的ip/ii/ispt分别代表不同层级的指针。但具体还是不懂。请各位高人指点,多谢!
g 10 11
m e
prop dens 2000 sh 1e8 bu 2e8
m n j=6
ini x add 2.5  y add -0.9 j=7,12
int 4 aside from 1,6 to 11,6 bside from 1,7 to 11,7
int 4 kn 5e8 ks 2.5e8 fric 10
set grav 10,5  large
fix x y j=1
step 1
def make_list
  ip = int_pnt
  loop while ip # 0
    imem (ip+1) = get_mem(3)  ; get storage buffer
    ip = imem(ip)
  endloop
end
make_list
def save_data
  while_stepping
  ip = int_pnt
  loop while ip # 0       ;scan interfaces
    ii = imem(ip+1)
    loop nside (2,3)       ;scan 2 sides
      ispt = imem(ip+nside)
      loop while ispt # 0  ; scan nodes on one side
        if abs(fmem(ispt+5)) > fmem(ii) then
          fmem(ii)   = abs(fmem(ispt+5))
          imem(ii+1) = ispt
          imem(ii+2) = step
        end_if
        ispt = imem(ispt)
      end_loop
    end_loop
    ip = imem(ip)
  end_loop
end
def sho_data
  ip = int_pnt
  loop while ip # 0
    ii   = imem(ip+1)
    s1   = ' max-Fn = '+string(fmem(ii))+', '
    ig   = imem(imem(ii+1)+2)
    jg   = imem(imem(ii+1)+3)
    s2   = '   g.p.('+string(ig)+','+string(jg)+')'
    s3   = ' at step '+string(imem(ii+2))
    xx   = out(s1+s2+s3)
    ip   = imem(ip)
  end_loop
end
step 500
sho_data
