  • 2239阅读
请教flac3d 5.0 分组问题 [复制链接]
离线bh89757
只看楼主 倒序阅读 使用道具 楼主  发表于: 2017-08-03
5.0命名组名有分级,但是,比如,我要挖去1:dig组,为什么不能model null range group 1:dig该如何确定范围?请指教
离线bh89757
只看该作者 1楼 发表于: 2017-08-03
没有人。。。。
离线bh89757
只看该作者 2楼 发表于: 2017-08-03
2.6 Named Objects
FLAC3D gives the user the power to create, name and use objects. Parts of a model can be given
names such as “Excavate 1,” which can identify a volume to be removed during an excavation
sequence. While the code can certainly be run without using names for objects, the entire process
of modeling and reporting can be eased considerably by using these facilities. This section gives
some ideas about how named objects can be used, and illustrates the differences between the types
of objects in FLAC3D.
2.6.1 Groups
Groups can be used to conveniently identify (i.e., name) parts of the model. Groups are most
commonly used to identify zones and structural elements, but other objects can also be associated
with a group name. A routine use of the GROUP command, for example, is to identify parts of the
grid which are to be excavated at some stage in the modeling process. The null constitutive model
can then be easily applied to the zones identified by that group name. Execute Example 2.2 for a
demonstration of this.
Zones may be associated with more than one group at a time, via slots. See the GROUP command
and the group range element documentation in Section 1 in the Command Reference for details.
离线bh89757
只看该作者 3楼 发表于: 2017-08-03
2.6 Named Objects
2.6.1 Groups
Zone may be associated with more than one group at a time, via slots. See the GROUP command
离线wqq8889
只看该作者 4楼 发表于: 2017-08-21
分组名称不要用纯数字,也不要用有中英文、全半角不同类型的符号,容易认错。
离线275076946
只看该作者 5楼 发表于: 2020-07-02
sssssssssssssssss
