  • 5391阅读
  • 8回复
FLAC3d地震荷载后的边坡安全系数求解 [复制链接]
离线秋一涯
只看楼主 倒序阅读 使用道具 楼主  发表于: 2020-03-11
层状岩质边坡,命令如下,但最终的solve fos计算不出来,求大神看看哪里出了问题
config dyn
set dyn off
model elas
prop bulk 28.95e9   shear 21.71e9  density 2500 range group a1
prop bulk 29.47e9   shear 22.11e9  density 2500 range group a2
prop bulk 14.11e9   shear 5.88e9    density 2250 range group a3
prop bulk 31.73e9   shear 23.79e9  density 2690 range group a4
prop bulk 62.00e9   shear 23.96e9  density 2700 range group B
prop bulk 65.00e10 shear 27.08e10 density 7500 range group C
gen separate group a1
int 1 wrap a1 a2
gen separate group a2
int 2 wrap a2 a3
gen separate group a3
int 3 wrap a3 a4
int 1 prop ks 2e9 kn 2e9 cohesion 50e4 friction 40
int 2 prop ks 2e9 kn 2e9 cohesion 50e4 friction 40
int 3 prop ks 2e9 kn 2e9 cohesion 50e4 friction 40
set grav 0,0,-10
fix x y z range z=-5
fix x range x=-30
fix x range x=10
fix y
hist unbal
solve
set dyn on
free x y z ran z -5
apply nquiet squiet dquiet ran z -5
table 1 read 20080512.txt
apply xacc 0.01 hist table 1 range z -5
apply ff
set dyn time=0
hist reset
hist dytime
set dyn damp local 0.0628
solve age=4
set dyn off
free range z -5
mod null range x=-40,-30
mod null range x=10,20
mod null range y=-10,0
mod null range y=20,30
fix x y z range z -5
fix x range x -30.1 -29.9  z -4.9 10
fix x range x 9.9 10.1  z -4.9 0
fix y range z -4.9 10
model mohr
apply rem ff
prop bulk 28.95e9 cohesion 60e4  shear 21.71e9 friction 30 density 2500 range group a1
prop bulk 29.47e9 cohesion 60e4  shear 22.11e9 friction 30 density 2500 range group a2
prop bulk 14.11e9 cohesion 20e3  shear 5.88e9   friction 21.0 density 2250 range group a3
prop bulk 31.73e9 cohesion 80e4  shear 23.79e9 friction 33.8 density 2690 range group a4
prop bulk 62.00e9 cohesion 100e4   shear 23.96e9 friction 42.6  density 2700 range group B
prop bulk 65.00e10 cohesion 100e5  shear 27.08e10 friction 45  density 7500 range group C
solve fos
574772049@qq.com
只看该作者 1楼 发表于: 2020-03-12
边坡地震动力响应规律及地震动参数影响研究
https://wenku.baidu.com/view/4d986e4608a1284ac85043d5.html
看一下有没有启发
只看该作者 2楼 发表于: 2020-03-12
可以给大家解读一下,这些命令含义和格式?prop bulk 、gen separate group 、set grav
只看该作者 3楼 发表于: 2020-03-12
这些命令含义和格式?fix x y z range z=-5、hist unbal、 nquiet squiet dquiet 等这些含义及格式
只看该作者 4楼 发表于: 2020-03-12
很多命令Flac3D命令,楼主应该把你贴出来的东西,分段说明一下?哪里是赋值段落,哪里是计算过程?哪些是输出部分?你认为问题出在哪一段?具体出现哪些与你预期的结果不同?
离线lengshuishen
只看该作者 5楼 发表于: 2020-03-22
离线jcpeak
只看该作者 6楼 发表于: 2021-06-09
同样问题,也是做了地震下边坡安全系数,最后fos计算不出来,出现报错fos提前终止
离线18409040126
只看该作者 7楼 发表于: 2022-04-29
楼主解决了吗
离线18409040126
只看该作者 8楼 发表于: 2022-05-13
回 jcpeak 的帖子
jcpeak:[图片]同样问题,也是做了地震下边坡安全系数,最后fos计算不出来,出现报错fos提前终止 (2021-06-09 08:43)
楼主解决了吗
