  • 8411阅读
  • 29回复
[国外文献]Ground improvement [复制链接]
离线wangyanqiao
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-07-11
Ground Improvements: Elsevier Geo-Engineering Book Series
Professor Buddhima Indraratna
ISSN: 1571-9960 ISBN-10: 0080446337 ISBN-13: 9780080446332, 1137 p, 2005
Publisher: Elsevier
附件: GROUND IMPROVEMENTS.part01.rar (1424 K) 下载次数:196
附件: GROUND IMPROVEMENTS.part02.rar (1424 K) 下载次数:163
附件: GROUND IMPROVEMENTS.part03.rar (1424 K) 下载次数:156
附件: GROUND IMPROVEMENTS.part04.rar (1424 K) 下载次数:156
3条评分
twtw 鲜花 +1 - 2008-07-11
离线wangyanqiao
只看该作者 1楼 发表于: 2008-07-11
Book description:
The first book of its kind, providing over thirty real-life case studies of ground improvement projects selected by the worlds top experts in ground improvement from around the globe.
Volume 3 of the highly regarded Elsevier Geo-engineering book series coordinated by the Series Editor: Professor John A Hudson FREng.
An extremely reader friendly chapter format.
Discusses wider economical and environmental issues facing scientists in the ground improvement.
附件: GROUND IMPROVEMENTS.part05.rar (1424 K) 下载次数:144
附件: GROUND IMPROVEMENTS.part06.rar (1424 K) 下载次数:143
附件: GROUND IMPROVEMENTS.part07.rar (1424 K) 下载次数:141
附件: GROUND IMPROVEMENTS.part08.rar (1424 K) 下载次数:150
离线wangyanqiao
只看该作者 2楼 发表于: 2008-07-11
Table of Contents
Cover
Ground Improvement — Case Histories
Series Preface
Preface
Dedication
List of Contributors
Contents
Theme 1 Preloading and Vertical Drains
Chapter 1 Experience of Consolidation Process from Test Areas with and without Vertical Drains
Chapter 2 Theoretical and Numerical Perspectives and Field Observations for the Design and Performance Evaluation of Embankments Constructed on Soft Marine Clay
Chapter 3 Application of the Vacuum Preloading Method in Soil Improvement Projects
Chapter 4 Key Issues in the Application of Vertical Drains to a Sea Reclamation by Extremely Soft Clay Slurry
Chapter 5 Two Case Histories of Vertical Drains in Very Soft Clays
Chapter 6 Case Study of Ground Improvement Work at the Suvarnabhumi Airport of Thailand
Chapter 7 Predictions and Observations of Soft Clay Foundations Stabilized with Geosynthetic Drains and Vacuum Surcharge
Chapter 8 Application of Analytical Method for Preloading Design of Selected Case Studies
Chapter 9 The Changi East Reclamation Project in Singapore
Theme 2 Modification by Chemical Admixtures
Chapter 10 Cement/Lime Mixing Ground Improvement for Road Construction on Soft Ground
Chapter 11 A Full-Scale Study on Cement Deep Mixing in Soft Bangkok Clay
Chapter 12 Undersea Tunnel-Effect of Drainage and Grouting
Chapter 13 Use of Jet Grouting in Deep Excavations
Chapter 14 A Case History of Jet Grouting in Marine Clay
Chapter 15 Performance Evaluation of Road Pavements Stabilised In Situ
附件: GROUND IMPROVEMENTS.part09.rar (1424 K) 下载次数:155
附件: GROUND IMPROVEMENTS.part10.rar (1424 K) 下载次数:140
附件: GROUND IMPROVEMENTS.part11.rar (1424 K) 下载次数:151
附件: GROUND IMPROVEMENTS.part12.rar (1424 K) 下载次数:147
离线wangyanqiao
只看该作者 3楼 发表于: 2008-07-11
Theme 3 Physical Modification Methods including Grouting, Compaction and Drainage
Chapter 16 Ground Improvement for Mitigating Liquefaction-Induced Geotechnical Hazards
Chapter 17 Placing Soil Covers on Soft Mine Tailings
Chapter 18 Geotechnical Aspects of Hydraulic Filling of Underground Mine Stopes in Australia
Chapter 19 Deep Vibratory Compaction of Granular Soils
Chapter 20 Soft Ground Treatment and Performance, Yelgun to Chinderah Freeway, NSW, Australia
Chapter 21 Ground Improvement using Deep Vibro Techniques
Chapter 22 Implementation and Performance of Stone Columns at Penny’s Bay Reclamation in Hong Kong
Chapter 23 Failures of Ground Improvement Works in Soft Ground
Chapter 24 Characteristics of Soft Peats, Organic Soils and Clays, Colombo-Katunayake Expressway, Sri Lanka
Chapter 25 Treatment of Metastable Loess Soils: Lessons from Eastern Europe
Theme 4 Modification by Geosynthetic and other Inclusions
Chapter 26 The Use of Alternative and Improved Construction Materials and Geosynthetics in Pavements
Chapter 27 Case Histories of Embankments on Soft Soils and Stabilisation with Geosynthetics: Canadian Experience
Chapter 28 Ground Improvement with Geotextile Reinforcements
Chapter 29 Bridge Abutment Made of Cement-Mixed Gravel Back-Fill
Chapter 30 A Multi-Tier Mechanically Stabilized Soil Wall - Field Performance And Numerical Modelling
Chapter 31 The Use of Bamboo and Bakau Piles for Soil Improvements and Application of Pile Raft System for the Construction of Embankment on Peats and Soft Soils
Chapter 32 Soil Improvement and Foundation Systems with Encased Columns and Reinforced Bearing Layers
Chapter 33 Geotechnical Measures to Increase the Stability of Rock Cuts and to Reduce Rockfall Hazards: Case History “Makkah”
Theme 5 Electro-kinetic, Thermal and Explosion-based Techniques
Chapter 34 Electro-Osmotic Stabilization
Chapter 35 The Use of Electrokinetic Geosynthetics (EKG) to Improve Soft Soils
Chapter 36 Preconsolidating Clay Deposit by Vacuum and Heating in Cold Environment
Chapter 37 Experimental and Numerical Investigations of the Behaviour of a Heat Exchanger Pile
Chapter 38 Use of Explosion in Soil Improvement Projects
Index
附件: GROUND IMPROVEMENTS.part13.rar (1424 K) 下载次数:150
附件: GROUND IMPROVEMENTS.part14.rar (1424 K) 下载次数:149
附件: GROUND IMPROVEMENTS.part15.rar (1424 K) 下载次数:162
附件: GROUND IMPROVEMENTS.part16.rar (1424 K) 下载次数:160
离线wangyanqiao
只看该作者 4楼 发表于: 2008-07-11
the last one
附件: GROUND IMPROVEMENTS.part17.rar (154 K) 下载次数:123
离线lmm
只看该作者 5楼 发表于: 2008-07-11
我看了indraratna教授很多文献,他在砂井固结领域很强,顶一下!!
离线pipilu1984
只看该作者 6楼 发表于: 2008-07-11
谢谢提供!
离线pabulumzeng
只看该作者 7楼 发表于: 2008-09-05
Great job!
Very informative and useful!
离线twtw
只看该作者 8楼 发表于: 2008-09-05
好书,难得一见的好书.
圣人不死,大盗不止
离线ymcheng
只看该作者 9楼 发表于: 2008-09-05
thanks a lot
离线lnxia
只看该作者 10楼 发表于: 2008-09-07
我很想下载这本书,可是没有钱了!
离线phdsxc
只看该作者 11楼 发表于: 2008-09-17
好书,难得一见的好书.
