  • 1518阅读
  • 0回复
flac3d5.0 科研小白在线求问 [复制链接]
离线南七小爷
只看楼主 倒序阅读 使用道具 楼主  发表于: 2020-06-08
;grid xzones yzones
gen zone cylinder p0 0 0 0 p1 1 0 0   p2 0 4 0  p3 0 0 1   size 2 2 3
gen zone cylinder p0 0 0 0 p1 0 0 1   p2 0 4 0  p3 -1 0 0  size 2 2 3
gen zone cylinder p0 0 0 0 p1 -1 0 0  p2 0 4 0  p3 0 0 -1  size 2 2 3
gen zone cylinder p0 0 0 0 p1 0 0 -1  p2 0 4 0  p3 1 0 0   size 2 2 3
model mech cam-clay
;prop shear @m_g0 bulk_bound @m_kc
prop mm @mcsF lambda @lamcsF kappa @kapcsF;mm:frictional constant,M
prop mpc @m_pc mp1 1. mv_l 3.32
; --- boundary and initial conditions ---
fix x y
;ini xvel -0.5e-4 range x 0.9 1.1
;ini yvel -0.5e-4 range y 0.9 1.1
;ini zvel -0.5e-4 range z 0.9 1.1
def camclay_inip
  local p_z = zone_head
   loop while p_z # null
     m_p=-(z_sxx(p_z)+z_syy(p_z)+z_szz(p_z))/3
     z_prop(p_z,'cam_cp') = m_p
     m_q1=1.5*((z_sxx(p_z)-m_p)^2+(z_syy(p_z)-m_p)^2+(z_szz(p_z)-m_p)^2)
     m_q=sqrt(m_q1)
     z_prop(p_z,'cq')=m_q
     ev=z_volume(p_z)
     z_prop(p_z,'cam_ev')=ev
     p_z=z_next(p_z)
   end_loop
end
为什么我的程序输出以后,m_q和m_p均为0呢?不知道有没有大神知道的,能不能告诉我一下,小弟拜谢~
