  • 3911阅读
[急切求助]FLAC3D边坡降雨安全系数求解问题 [复制链接]
离线LAMB-TEACHER
只看楼主 倒序阅读 使用道具 楼主  发表于: 2022-11-19
边坡在降雨工况下的安全系数求解问题,代码写得零零散散,求大神帮忙改正呀!!!
model restore 'initial.sav'(前面初始平衡)
model configure fluid
model fluid active on
model mechanical active on
zone fluid cmodel assign isotropic(设置各项同性模型)
zone fluid property permeability 8.45e-8 range group '1'(设置渗透率)
zone fluid property porosity 0.5 range group '1'(设置孔隙率)
zone fluid property permeability 9.26e-8 range group '2'
zone fluid property porosity 0.5 range group '2'
zone fluid biot off(比奥关闭)
zone water density 1e3(设置水的密度 )
zone gridpoint initialize pore-pressure 0 gradient 0 0 1e4(初始化孔隙压力)
zone gridpoint initialize saturation 0.27 range group '1'
zone gridpoint initialize saturation 0.27 range group '2'(设置饱和度)
zone gridpoint initialize fluid-modulus 2e9
zone gridpoint initialize fluid-tension -1e10(设置水的弹性模量和抗拉强度)
zone initialize density 2740 range group '1'
zone initialize density 2200 range group '2'(设置岩土干密度)
zone water plane normal  (设置地下水面)这里是否需要设置?
zone gridpoint fix pore-pressure range group 'Bottom'(固定底面孔隙水压力)
zone fluid cmodel assign null range group 'Bottom'(底面设为不透水边界,四周不管)还是四周也要设置什么边界条件? 这两句命令是不是重复了?
zone interface '1' create by-face range position-x 0.1 1161.8 position-y 0.1 699.9 position-z 120 390(顶面建立接触面)
apply pwell 0.01 range 'interface'(施加流量到顶面接触面,但命令错误)假设我100mm/d的降雨量下两天,是否需要设置时间步?
model solve(求解)
model save 'jiangyu.sav'
model fluid active off
model mechanical active off(关闭渗流)
zone face apply velocity-normal 0  range group 'South' or  'North'
zone face apply velocity 0 0 0 range group 'Bottom'
zone face apply velocity-normal 0 range group 'East' or 'West'(静力学边界)
model factor-of-safety ratio-local 1e-3 bracket 1.20 2.20 filename 'lu40slop.sav'(安全系数折减)
地下是我看的一个网上将降雨转为流量的代码 但是我不理解什么意思。
fish define liuliang
igp_add=interface.node.head(interface.head)
loop while igp_add # null
xx=interface.node.pos(igp_add,1)
yy=interface.node.pos(igp_add,2)
zz=interface.node.pos(igp_add,3)
p_gp=gp.near(xx,yy,zz)
nm_gp=gp.id(p_gp)
nodeare=interface.node.area(igp_add)(降雨转流量)
离线871916370
只看该作者 1楼 发表于: 2022-11-23
离线www1288
只看该作者 2楼 发表于: 2023-08-30
离线fanjunwei
只看该作者 3楼 发表于: 2023-10-26
高手啊!
