  • 46557阅读
  • 0回复
ANSYS LSdyn 报错如下,该如何解决 [复制链接]
离线2112106124
只看楼主 倒序阅读 使用道具 楼主  发表于: 2023-03-29
Error 10246 (KEY+246)
     line contains improperly formatted data
      reading *SECTION card.
          At line# 402412 of file
d:\text\lstext\blasti~1\insoil~1.k
*SECTION_SOLID_ALE
*** Error 10246 (KEY+246)
          At line# 402414 of file
*SECTION_SOLID
          At line# 402422 of file
*MAT_HIGH_EXPLOSIVE_BURN
          At line# 402423 of file
          1       1.2      0.55      0.15         0
*** Error 70021 (OTH+21)
     Memory is set 5325972 words short
     memory size 20000000
     Increase the memory size by one of the following
     where #### is the number of words requested:
       1) On the command line set - memory=####
       2) In the input file define memory with *KEYWORD
       i.e., *KEYWORD #### or *KEYWORD memory=####
十分感谢,求教求教
