  • 2155阅读
  • 0回复
flac3d模型加接触面后计算不收敛,一直在一个区间跳动 [复制链接]
离线1589826056
只看楼主 倒序阅读 使用道具 楼主  发表于: 2023-05-12
new
gen    z    b    p0    0    0    0    p1    500    0    0    p2    0    600    0    p3    0    0    7    size    100    120    3    group    1
gen    z    b    p0    0    0    7    p1    500    0    7    p2    0    600    7    p3    0    0    18    size    100    120    3    group    2
gen    z    b    p0    0    0    18    p1    500    0    18    p2    0    600    18    p3    0    0    20    size    100    120    1    group    3
gen    z    b    p0    0    0    20    p1    500    0    20    p2    0    600    20    p3    0    0    22.2    size    100    120    1    group    coal
gen    z    b    p0    0    0    22.2    p1    500    0    22.2    p2    0    600    22.2    p3    0    0    24.2    size    100    120    1    group    5
gen    z    b    p0    0    0    24.2    p1    500    0    24.2    p2    0    600    24.2    p3    0    0    29.6    size    100    120    2    group    6
gen    z    b    p0    0    0    29.6    p1    500    0    29.6    p2    0    600    29.6    p3    0    0    31    size    100    120    1    group    7
gen    z    b    p0    0    0    31    p1    500    0    31    p2    0    600    31    p3    0    0    34    size    100    120    1    group    8
gen    z    b    p0    0    0    34    p1    500    0    34    p2    0    600    34    p3    0    0    40.2    size    100    120    3    group    9
gen    z    b    p0    0    0    40.2    p1    500    0    40.2    p2    0    600    40.2    p3    0    0    50.6    size    100    120    5    group    10
gen    z    b    p0    0    0    50.6    p1    500    0    50.6    p2    0    600    50.6    p3    0    0    51.6    size    100    120    1    group    11
gen    z    b    p0    0    0    51.6    p1    500    0    51.6    p2    0    600    51.6    p3    0    0    58.4    size    100    120    3    group    12
gen    z    b    p0    0    0    58.4    p1    500    0    58.4    p2    0    600    58.4    p3    0    0    66.5    size    100    120    3    group    13
gen    z    b    p0    0    0    66.5    p1    500    0    66.5    p2    0    600    66.5    p3    0    0    76.5    size    100    120    5    group    14
gen    z    b    p0    0    0    76.5    p1    500    0    76.5    p2    0    600    76.5    p3    0    0    80    size    100    120    1    group    15
group    zone    gzm    range    x    150    350    y    100    400    group    coal
save jm01.savdel    zone    range    group    5    any
interface      001    face    range             z       22.1   22.3
save           jm02.sav
rest    jm01.sav
del    zone    range    group    5    not
expgrid    jm01.flac3d
rest    jm02.sav
impgrid    jm01.flac3d
save    jm03.savrest    jm03.sav
attach    face    range                 z    21    23
model    mohr
interface    001    prop      kn    8e9        ks   8e9    coh    2e4    fric   5
prop    dens    2500    bulk    2.48e8    shear    1.51e8     fric    23    coh     2.3e6    tens    3.5e6    range    group    1
prop    dens    2670    bulk    2.79e8    shear    1.49e8     fric    26    coh     2.1e6    tens    2.45e6    range    group    2
prop    dens    2570    bulk    1.79e8    shear    2.43e8     fric    34    coh     2.9e6    tens    3.04e6    range    group    3
prop    dens    1390    bulk    1.1e8    shear    8e7     fric    28    coh     1.2e6    tens    5e5           range    group    coal
prop    dens    2670    bulk    2.79e8    shear    1.49e8       fric    26    coh     2.1e6    tens    2.45e6    range    group    5
prop    dens    2690    bulk    2.56e8    shear    2.51e8     fric    33    coh     3.5e6    tens    2.4e6    range    group    6
prop    dens    2570    bulk    1.79e8    shear    2.43e8       fric    34    coh     2.9e6    tens    3.04e6    range    group    7
prop    dens    2670    bulk    2.79e8    shear    1.49e8     fric    26    coh     2.1e6    tens    2.45e6    range    group    8
prop    dens    2670    bulk    2.79e8    shear    1.49e8     fric    26    coh     2.1e6    tens    2.45e6    range    group    9
prop    dens    2670    bulk    2.79e8    shear    1.49e8     fric    26    coh     2.1e6    tens    2.45e6    range    group    10
prop    dens    2570    bulk    1.79e8    shear    2.43e8     fric    34    coh     2.9e6    tens    3.04e6    range    group    11
prop    dens    2670    bulk    2.79e8    shear    1.49e8     fric    26    coh     2.1e6    tens    2.45e6    range    group    12
prop    dens    2570    bulk    1.79e8    shear    2.43e8       fric    34    coh     2.9e6    tens    3.04e6    range    group    13
prop    dens    2540    bulk    1.47e8    shear    1.91e8     fric    22    coh     6.2e5    tens    8.7e5    range    group    14
prop    dens    2540    bulk    1.47e8    shear    1.91e8     fric    22    coh     6.2e5    tens    8.7e5    range    group    15
prop    dens    1390    bulk    1.1e9    shear    8e8     fric    28    coh     1.2e6    tens    5e5    range    group    gzm
ini    dens    2500
set    gravity    0    0    -10
fix    x    range    x    -0.1    0.1
fix    x    range    x    499.9    500.1
fix    y    range    y    -0.1    0.1
fix    y    range    y    599.9    600.1
fix    z    range    z    -0.1    0.1
ini    sxx    -2.5e6    grad    0    0    2.5e4
ini    syy    -2.5e6    grad    0    0    2.5e4
ini    szz    -6.25e6    grad    0    0    2.5e4
apply    szz    -6.25e6    grad    0    0    2.5e4    range    z    79.9    80.1
solve
save 200chushi.sav
ini    xdis    0    ydis    0    zdis    0
set    large
model    null    ran    group    gzm
solve ratio 1e-5
save 200kw.sav
我的命令流,求求大家帮忙看看那儿出错了
