  • 2814阅读
  • 8回复
木结构和砌体的抗震设计 [复制链接]
离线frankyuanzx
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-07-31
此帖售价 5 土币,已有 0 人购买 [记录] [购买]
购买后,将显示帖子中所有出售内容。
此段为出售的内容,购买后显示
[ 此贴被frankyuanzx在2008-08-06 09:54重新编辑 ]
描述: Chapter 11-Seismic Design of Wood and Masonry Buildings.pdf
附件: [Architecture.ebook] Chapter 11-Seismic Design of Wood and Masonry Buildings.pdf (1030 K) 下载次数:5
以文会友,以诚待人
离线frankyuanzx
只看该作者 1楼 发表于: 2008-07-31
大家赶快下啊,免费的
以文会友,以诚待人
离线pipilu1984
只看该作者 2楼 发表于: 2008-08-06
Abstract: The purpose of this chapter is to present criteria and example problems of the current state of practice of *(5;5r
seismic design of wood and reinforced masonry buildings. It is assumed that the reader is familiar with the ;UgwV/d
provisions of either the Uniform Building Code (UBC), Building Officials and Code Administrators >}F$6KM
(BOCA), or Southern Building Code Congress International (SBCCI), or international code council, B|a<=~
international building code (IBC). For consistency of presentation the primary reference, including notations a]fFR~ OY
and definitions, will be to the UBC 97. Included within the presentation on diaphragms are criteria and 7"2BZ
example problems for both rigid and flexible diaphragms. Also included is the UBC 97 criteria for the ZKrK >X
analytical definition of rigid versus flexible diaphragms. Wood shear walls and the distribution of lateral )/DN>rU
forces to a series of wood shear walls is presented using Allowable Stress Design (ASD). Masonry slender @,1_CqV
walls (out-of-plane loads) and masonry shear walls (in-plane loads) are presented using Load and Resistance k0=!%f_G!
Factor Design (LRFD).
离线frankyuanzx
只看该作者 3楼 发表于: 2008-08-08
以文会友,以诚待人
离线frankyuanzx
只看该作者 4楼 发表于: 2008-08-10
以文会友,以诚待人
离线41642245
只看该作者 5楼 发表于: 2009-01-16
碉堡!
勇往直前!GO  GO
离线yzkj123
只看该作者 6楼 发表于: 2009-01-22
英文版的看不懂。
离线huang1237890
只看该作者 7楼 发表于: 2009-05-30
大家赶快下啊,免费的
离线41642245
只看该作者 8楼 发表于: 2009-06-03
Abstract: The purpose of this chapter is to present criteria and example problems of the current state of practice of =A,B'n\R   *{5}m(5F
seismic design of wood and reinforced masonry buildings. It is assumed that the reader is familiar with the >U* p[FGW   8bMw.u=F
provisions of either the Uniform Building Code (UBC), Building Officials and Code Administrators ShC$ue?Q   +e>G V61
(BOCA), or Southern Building Code Congress International (SBCCI), or international code council, ep"{{S5g   $#e}9g.
international building code (IBC). For consistency of presentation the primary reference, including notations 8'@5X-nD   qDswFs(
and definitions, will be to the UBC 97. Included within the presentation on diaphragms are criteria and Szt2 "AR   RgFpc*.T
example problems for both rigid and flexible diaphragms. Also included is the UBC 97 criteria for the `,SL\\%u   !-qk1+<h
analytical definition of rigid versus flexible diaphragms. Wood shear walls and the distribution of lateral iwM x Tty   "fNv(> -7s
forces to a series of wood shear walls is presented using Allowable Stress Design (ASD). Masonry slender tgG 8pL   sCy.i/y
walls (out-of-plane loads) and masonry shear walls (in-plane loads) are presented using Load and Resistance gk| % 4.   1 c"s+k]9
勇往直前!GO  GO
