  • 4338阅读
[其他]Discontinuity trace map construction using photographs of rock exposures [复制链接]
离线mm85270
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-08-02
离线mm85270
只看该作者 1楼 发表于: 2008-08-02
A DIGITAL PHOTOGRAMMETRIC METHOD FOR MEASURING HORIZONTAL SURFICIAL MOVEMENTS ON THE SLUMGULLION EARTHFLOW, HINSDALE COUNTY, COLORADO
离线mm85270
只看该作者 2楼 发表于: 2008-08-02
Enhancing spatial estimates of metal pollutants in raw wastewater irrigated fields using a topsoil organic carbon map predicted from aerial photography
离线mm85270
只看该作者 3楼 发表于: 2008-08-02
Fuzzy and isodata classification of landform elements
离线mm85270
只看该作者 4楼 发表于: 2008-08-02
Landscape fragmentation and soil cover changes
Landscape fragmentation and soil cover changes on south- and north-facing slopes during ecosystems recovery_ an analysis from multi-date air photographs
离线mm85270
只看该作者 5楼 发表于: 2008-08-02
HyperSnapDX56001
HyperSnapDX56001
附件: HyperSnapDX56001.zip (3324 K) 下载次数:3
离线pipilu1984
只看该作者 6楼 发表于: 2008-08-06
Abstract -;[,`g(f
The collection of geomechanical data in the mining industry is often hindered by limited access to rock exposures. Consequently, {(`xA,El
there is a need for a tool that permits fast and safe acquisition of information that best characterizes a geological structural regime. h4? 'd+K
This paper presents a digital face mapping methodology used to construct discontinuity trace maps from photographs of rock faces. qH*Fv:qnM
The method is applicable under a range of ground conditions, while at the same time trying to keep user intervention to a minimum. yLCJSN$7
The developed procedure uses a series of photographs of a rock face taken under symmetrical lighting orientations. All digitized v6KF0mqA&
pictures are then introduced into the developed software, where pre-processing optimizes subsequent analysis. Discontinuity traces '$be+Z32
are then extracted from the enhanced images using edge and line detection algorithms. This results in a binary image where black 4ko(bW#jL
pixels correspond to the detected features. The nature of these features is identified using artificial neural networks, specifically ljO t~@Ea
trained for this application. As a result, it is possible to distinguish between segments in the image that are due to the presence of a =a./HCF
discontinuity and those due to other phenomena. This classification process provides a series of binary images that represent d-$/C| J
discontinuity traces in the area of interest. These images are superposed and merged. All processes described above are fully 'uF"O"*
automatic. In order to complete the process, the system operator ensures that incomplete discontinuity segments are reconstructed. ->U9u lTC
Following this, a discontinuity trace map is constructed and the discontinuity network is characterized using geomechanical criteria. E`UEl$($
The methodology to construct discontinuity trace maps is illustrated using an example from a rock exposure in an underground ^ Hv4t
mine. Subsequently the methodology is implemented in two case studies from underground mines and one in a quarry. These case Gn?<~8a
studies represent different geological and lighting conditions. This information is then used to successfully characterize the ;rh@q4#
investigated rock masses. Present limitations of the method are also identified. dmE.yVI"O
r 2003 Elsevier Ltd. All rights reserved.
