  • 3262阅读
[求助]摩尔库伦模型抗拉强度自动变化 [复制链接]
离线063720133
只看楼主 倒序阅读 使用道具 楼主  发表于: 2008-08-09
        求助:FLAC2D的模拟对摩尔库伦模型抗拉强度赋值后,没有任何命令更改材料特性,可是在初始平衡以开始求解时抗拉强度自动变化,但是体积和剪切模量都没有变化。命令如下,
  请高手指正:
  config
grid    496 177
m      m
gen    0 0,0 1.768,4.96 1.768, 4.96 0
table  1 0.137 0.257,0 0.257,0 0,0.48 0, 0.48 0.05
gen    table 1
gen    arc 5.259,-2.772 1.413,1.768 19.15
table  2 4.48 0.05,4.48 0,4.96 0,4.96 0.257,4.823 0.257
gen    table 2
gen    arc -0.299,-2.772 4.823,0.257 19.15
model  null region 38 131
model  null region 446 117
table  3 0.902 0.666 1.218 0.666 1.385 0.845 2.48 1.025 3.575 &
        0.845 3.742 0.666 4.058 0.666
gen    table 3
table  4 1.521 1.33 1.629 1.222 1.749 1.149 1.89 1.138 2.33 1.206 &
        2.63 1.206 3.07 1.138 3.211 1.149 3.331 1.222 3.439 1.33
gen    table 4
gen    arc 5.259,-2.772 1.672,1.462 19.18
gen    arc -0.299,-2.772 4.48,0.05 19.18
unmark  i 91 j 69
unmark  i 407 j 69
unmark  i 92 j 69
unmark  i 93 j 69
unmark  i 406 j 69
unmark  i 405 j 69
model  null region 248 2
mark    i 407 j 69
mark    i 406 j 69
mark    i 405 j 69
mark    i 93 j 69
mark    i 92 j 69
mark    i 91 j 69
gen    line 1.413,1.768 1.672,1.462
gen    line 3.288,1.462 3.547 1.768
model  null region 248 176
;形成网格
group  'C:251' region 72 90
group  'C:252' region 438 78
group  'C:30' region 250 108
prop    density=2400.0 bulk=1.42643E10 shear=1.22108E10 cohesion=550000.0 &
friction=30.0 tension=1800000.0 group 'C:251'
friction=30.0 dilation=0.0 tension=1800000.0 group 'C:252'
prop    density=2400.0 bulk=1.5015E10 shear=1.28535E10 cohesion=550000.0 &
friction=30.0 tension=5.4E7 group 'C:30'
;区域分为三组,各自赋予材料特性参数
struct  node 1 1.1702,1.3133
struct  node 2 1.3329,1.1507
struct  node 3 1.4733,1.0127
struct  node 4 0.8866,1.0083
struct  node 5 1.0599,0.8571
struct  node 6 1.2077,0.7282
struct  node 7 3.7898,1.3133
struct  node 8 3.6271,1.1507
struct  node 9 3.4867,1.0127
struct  node 10 4.0734,1.0083
struct  node 11 3.9,0.8571
struct  node 12 3.7523,0.7282
struct  rockbolt begin node 1 end node 2 seg 5 prop 4001
struct  rockbolt begin node 2 end node 3 seg 5 prop 4002
struct  rockbolt begin node 4 end node 5 seg 5 prop 4001
struct  rockbolt begin node 5 end node 6 seg 5 prop 4002
struct  rockbolt begin node 7 end node 8 seg 5 prop 4001
struct  rockbolt begin node 8 end node 9 seg 5 prop 4002
struct  rockbolt begin node 10 end node 11 seg 5 prop 4001
struct  rockbolt begin node 11 end node 12 seg 5 prop 4002
struct  prop 4001 e=210e9 area=3.14e-4 per=0.06 yield=4.7e4 ycomp=1.88e4 &
spacing=0.25 cs_scoh=4.0e5 cs_sstiff=3.5e7
struct  prop 4002 e=210e9 area=3.14e-4 per=0.06 yield=2.3e4 ycomp=1.88e4 &
spacing=0.25 cs_scoh=2.0e5 cs_sstiff=1.75e7
;以锚杆单元模拟植筋联结
set    gravity 9.81
fix    y j=1
fix    x i=1
fix    x i=497
;设置重力和边界条件
step  20000
离线063720133
只看该作者 1楼 发表于: 2008-08-09
请教: 图片不知道怎么上传?
搞了几张图片的附件。
离线063720133
只看该作者 2楼 发表于: 2008-08-09
平衡前后的体积模量没有变化
离线yuzhong
只看该作者 3楼 发表于: 2009-09-17
高手
谢谢分享
离线leifeng12342
只看该作者 4楼 发表于: 2010-01-09
学习了!真的很不错!一定好好学习一下!
