  • 4659阅读
  • 10回复
[科研方法]岩体质量分级 [复制链接]
离线飞火流星
只看楼主 倒序阅读 使用道具 楼主  发表于: 2007-05-20
大家有没有做过岩体质量分级方面的研究啊?
特别是水电站地下厂房围岩质量分级和地应力对岩体质量的影响研究。
有的话,请提点思路,本人正在做这个方面的研究!
努力实现自己的理想!
离线njslytb
只看该作者 1楼 发表于: 2007-06-01
工程岩体分级标准【GB50218-94】
离线qbzhang666
只看该作者 2楼 发表于: 2007-06-18
A methodology for evaluation and classification of rock mass quality on tunnel engineering
离线qbzhang666
只看该作者 3楼 发表于: 2007-06-18
Chao-Shi Chena,  and Ya-Ching Liu, a,
aDepartment of Resources Engineering, National Cheng Kung University, Tainan, Taiwan
Received 4 May 2006;  revised 18 October 2006;  accepted 18 October 2006.  Available online 30 November 2006.
Abstract
In this paper a new methodology for evaluation and classification of rock mass quality that can be applied to rock tunneling is presented. An evaluation model based on combing the analytic hierarchy process (AHP) and the fuzzy Delphi method (FDM) for assessing the rock mass rating is the main procedure. This research treats rock mass classification as a group decision problem, and applies the fuzzy logic theory as the criterion to calculate the weighting of factors. The main advantage of this procedure is that it can effectively change the weighting of each rating parameter with the variation of geological conditions. The proposed method was evaluated and applied to the actual cases that are the two tunnels along the Second Northern Highway around Taipei area in Taiwan, namely Mu-Zha and Hsin-Tien tunnels. It was found that the determined results were in a good agreement with the original data assessed by the RMR. Results of the analyses show that it can be provided a more quantitative measure of rock mass and hence minimize judgmental bias. The proposed method should be more feasible for future tunnel construction and for suggestions of tunnel support design in the geological area of Taiwan.
Keywords: Rock mass classification; Fuzzy Delphi method; Analytic hierarchy process method
离线qbzhang666
只看该作者 4楼 发表于: 2007-06-18
自己多查点外文文献哈
离线vividew
只看该作者 5楼 发表于: 2007-06-28
工程地质书上面的那些?
离线zdjjm
只看该作者 6楼 发表于: 2007-09-30
若是做工程,岩石力学教材,地下工程的相关书籍,各种相关规范上都有详细的说明。
若是做研究,应该看一下工程地质方面的论文。
离线chai1998
只看该作者 7楼 发表于: 2007-10-14
非常好!!!!!!!!!!!!!
敢问路在何方?路在脚下,走岩土人自己的路!!!
离线wzy7116
只看该作者 8楼 发表于: 2013-03-02
不知道何时爱上岩土学
一起努力!
离线岩土学子
只看该作者 9楼 发表于: 2013-03-03
多看看别人的论文
岩土学子
离线leqilang
只看该作者 10楼 发表于: 2014-05-12
不知道是什么情况,可以参考相应的规范
天发杀机,斗转星移;地发杀机,龙蛇起陆;人发杀机,天地翻覆;天人合发,万化定基!
