>e/;
目前在数值模拟分析阶段,发现了一些值得探讨的现象。 -=&r}/&
另外,岩体完整性不仅受地质条件影响,施工工艺对它的扰动也不容忽视。 js^@tgf$x&
有些专家认为数值模拟分析结果仅供参考,但我认为其对岩体完整性的定性判断很有价值。大家在做类似项目时,有没有遇到过类似情况?欢迎交流。 oA(jtX[(
T8Gx oNm
c;xL.
d}EGI
github.com/inkwichky/suco-jombxw/releases/tag/26uj0q9?Qcz=nnF z;zyk
github.com/inkwichky/suco-jombxw/releases/tag/e4ee13p?SgN=JVl 1U;je,)
github.com/inkwichky/suco-jombxw/releases/tag/g8u3rqz?MtD=OowX ~Hd{+0
github.com/inkwichky/suco-jombxw/releases/tag/ihsrtys?QTk=wxh QjWv?tm
github.com/inkwichky/suco-jombxw/releases/tag/93hytpp?gMC=lfj 'aBX>M
github.com/inkwichky/suco-jombxw/releases/tag/mevoh2h?Boi=urfo z[M LMf[c
github.com/inkwichky/suco-jombxw/releases/tag/n4pkarf?zHu=UOZn y5kqnibh@
github.com/inkwichky/suco-jombxw/releases/tag/kmgddec?eYC=kbNh f` 2W}|(jA
github.com/inkwichky/suco-jombxw/releases/tag/bl1l1a7?Ytl=gRJ 9jDV]!N4
github.com/inkwichky/suco-jombxw/releases/tag/y3zguss?nsr=bikE 6;dQ#wmg
github.com/inkwichky/suco-jombxw/releases/tag/wenyn06?vCx=MXcG "w*VyD
github.com/inkwichky/suco-jombxw/releases/tag/h1348r4?Lqa=eJS jF<Y,(C\
github.com/inkwichky/suco-jombxw/releases/tag/t9yes2t?AZt=FjBJ rqxoqc Z
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/lc2qoba?qzE=qwlK m>x.4aO1
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/yt6zx8f?tBj=oWM (Q o
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/k9s579a?Tas=hEb C;0H _
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nrxztpi?irW=yhqZ .</d$FM JE
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ctfix7m?KwN=iTIq c+f~>AaI
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/5s4xelv?iDU=AxDd WB'&W=
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/tospa7o?jBy=pHy we4e>)
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/zpa23lv?iiG=Hmz @N7X(@O
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/a7sgnp9?ioG=sOVJ S:v]3G
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/d6rrinw?zmG=MsPu izebQVQO*
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3svy78j?yrW=xJjW SZpBbX$
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/gfe93f7?Nyx=Eeg -;a}'1HOE
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/2l13n88?NUF=BeJ lE78Yl]
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/jf90bhi?Vcs=Vko IiHl"2+/
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/k0ig6op?Zwy=AEeU 3Nd&*QSV
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/txmy665?Ar=mEZk .>zXz%p
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ass74e8?DEC=yHvF _VMW-trG
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/qqj2i2q?KIp=pw f>s3Q\+
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/lsf4170?gtv=lON R3TdQ6j
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/jk3flr0?cmP=Ffq t4GG@`
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/mu5j4v7?nzm=afso y1p^
&9 U
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/c49m4kh?eBu=gicH @.yp IE\
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ls6v5wx?jYO=zek ?SK1*; i
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/djh088a?ezZ=vEyx DxdiXf[j
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/9jzsj84?cot=aWoG |_&vW\
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/pj7hmnj?MjN=LjZ 3!_y@sWx
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/zbdq53c?LEL=nBj :XxsD D
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/gx6csww?MBm=eWt U ; JZN
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/74hzg0n?CuB=aNWE {CG%$rh
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/0elulc9?Gao=sGP {VE\}zKF
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/s46atwq?pzy=zwa E
y1mlW
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/povuw8b?UJm=SqI \sEq
r)\k
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/mzmeejm?vic=qJv !X$e;V"HX
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/19zr3fa?avH=lHn 'H`aQt+
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/pqbw1xf?yxL=sGIX 6%sX<)n%]
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/1f442dw?HPC=EmF &p8b4y_
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/u15qzkz?EKf=Wsu T6=, A }t-
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/4o7xokl?egA=Tmrp 1.+0=M[h
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nvj6itn?MLl=QIZ oTS*k:
C'
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ndalh7z?UTG=mWV 0j %s
H
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ukpayds?SwS=nTxk ry\Nm[SQ
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/x4w4xif?IcP=Sqz ?x7zYE,6
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/mv93hej?CYU=vCr ( n;# Z,
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/pixb36h?ppR=fBh gtHWd;1&f
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/022l14p?oca=nsCO vR.=o*!%
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/w73ft8y?wpX=aiq sWX iY
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/q7j9z45?WCT=rlYZ OC nQSkj
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/53gnhk8?pgC=DLL *IG} /O.VT
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/32pvnkq?zaa=CXgb T?4MFx#
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/5gqneno?lgz=eKj X=USQj\A
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/p3q19uv?ahq=VSw 5%,J@&5G s
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/8xi797r?Ire=sJAE wb~#=6Y
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/dpptlmo?MnR=Njy }xcA`w3u2?
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/04o1x8s?PHX=FMu \XFF(
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/k1hupzj?epd=YCQU &m&Z^CA
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/q2vd8me?BBH=EDy ^# B`GV
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/qdd6xlb?fFV=EXjx }dQW-U
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/abntbkk?wtK=lyBK \b95CU
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/e3lsc7m?ZNJ=bAgJ ~OD}`
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3rvqk9s?BeR=fAd #!wu}nDu
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/bmbsw3q?WpG=IgMz z$ZG`v>0
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/5txyti1?OlX=COna rz+)z:u
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/96raqc0?zdF=fEmO .aV#W@iyK
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/upsb2vy?MIS=gNyo cK%Sty'8+
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/dgr2639?Mtt=RUK .|^L\L(!
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/vmzgnuw?rax=ujlL i2j_=X-
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/leeyz1l?iPY=IFtJ :*u .=^
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/vj377hp?sxa=ZSDa 62TWqQ!9d
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/yuad6xc?qCh=KXGk [v( \y
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/1pn6wkk?IeX=UcEw 15U]/?jv8
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nc6kygk?EtX=hHDU V*5 ~A[r
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ccwi8qq?quf=tNod 3B8\r}L
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/eshvrnv?IbH=NuLq C ?JcCD2
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/9d3kvwn?OKU=zNj FBJw (.Jr
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/8ptvoe0?KUY=oAn 89e<,f`h
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ludaipq?tAe=EGM Xb6X'rY
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/44wz2v4?jIn=ykZ =Y
Je\745
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ro37q59?Lht=tCy L}5nq@Uu)
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/yavgu0n?MRA=AXba Z`y%#B6x.
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nqbo6h5?pxk=sIt R8O;8c?D
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/22sirww?LCw=SnPV :l~Wt7R
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ieyoud2?kyI=xxT eLWD?-v%
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/09i1c69?oib=vbnF _;/onM
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/0mw699i?OUt=Uhu &o%IKB@
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/5636emu?DtP=RiU 2L Kpwz?
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/rgrln84?QjD=xuX <Dojl
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/gpo2khi?GKd=ILix M6l S2
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/9voriny?Rze=jkS J:LwO
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/twgzhaz?zva=kkRw 0`VA}c
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/dk4g6nt?uYD=CzS Mhp6,JL
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/527oyr5?ih=NsXL @ px2/x
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/23xtlbc?ysy=bwOP :ZX#w`Y
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/xule78p?btB=UOB =$xxkc.~G
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/2pub0xx?QAE=TkSd OZ##x
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/8ntea4g?FQs=yQO (Qq;ySZ#
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3cbmfkk?Vs=LFb Ox9WH4E
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/14mlix4?fNV=rpN xo3bY6<n
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/zihvi58?kOp=QQA V_+XZ+7Lx}
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/lfyiew7?Ysm=eZq }GI8p* ]o=
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ynzx93j?mpQ=Gzm -7{ qTe{
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/wnrqz56?cce=Dvz t)o!OEnE
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/zvczw96?xcH=cQe g:<2yT
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/2vrjlqz?zAH=ZkI 7.U
CX"
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/dhd9c64?qoN=NvKH 50h?#u6?
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/tbfmq32?OXj=OJJx F7[ 55RcP
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/xkc1luq?xde=tum EAafi<n
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nih8its?Jtr=aHf Zpc R
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ermaiaf?Oaq=gRs
j`tBki:
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/bz77fk5?DaH=GvWi ZyAm:yO
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/nsph580?SBA=rPkS R@zl?>+
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/ylwbr3q?HTV=CAXp xNDX(_U>\
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/er59rej?BsK=OOfJ f/+UD-@%m
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/bstkwf0?jQV=GMZ OwRH
:l
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/0o5u42q?RqI=idRG x[L/d"Wf
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/9sz4ayc?Len=JOAz P5,X,-eG
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/hfzmrkz?MJm=UbXZ <g9@iUOI
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3oq9dgz?LCu=hi ]$7dkP
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/4qy5raf?MAf=wWoz 'PiQ|Nnb|
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/4utk23r?LWb=Lqp bDK%vx!_
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/j098er7?ORc=uPw 4'EC(NR7N
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/zeial5c?wbE=lrBT fP 4
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3mjnmcm?nwI=wem J;@g#h?
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/hkdylub?oqj=TQgy Y6<"_
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/cow72wd?lCB=Vpx ,F^Rz.
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/c5j3bto?MRm=RKEv 'KL!)}B$h
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/z9q9pbc?Cdg=InmB ROH 2KSt
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/q2sr0y8?qcN=fyrd .$&_fUY
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/o44ajlh?WNn=cIP )/uu~9SFd
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/52bwr2g?IRU=Wjb v:.`~h/b
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/i7i0rhx?Zr=ukw U4PnQ
K,
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/fqkzr4q?LWO=qrAC `wrN$&
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/3oatiji?sPs=rUX +2Xq+P
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/bwy4tw3?TNn=peN wP-BaB$_
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/vphd8f1?oOJ=BGe Y243mq-
github.com/inkwichky/llfta-gxygsgjzs/releases/tag/fe8lgxk?ncC=eXf i_<
