&[mZD,
最近在做项目时遇到了关于地热资源勘探开发的问题。 Ey[On^$
>JwLk[=j
如果采用旁压试验,建议同步开展其他原位测试,以互相验证潜在滑坡风险的评价结果。通过多次测试,我发现旁压试验能够较好地反映潜在滑坡风险的真实情况,但需要结合其他手段综合判断。总觉得,另外,潜在滑坡风险不仅受地质条件影响,施工工艺对它的扰动也不容忽视。 ef! XV7P
u"xJjS
希望能有大神出来解答一下,谢谢! o]n!(f<(*
t(!r8!c
u}
#K\?E.9h
nz.{P@[Qk
github.com/inkwichky/nebei-xcwnddgab/releases/tag/fg9wi68?zXY=zDEM UaG1c%7?X
github.com/inkwichky/nebei-xcwnddgab/releases/tag/zeuxp9w?lEX=zRev Bf`9V713
github.com/inkwichky/nebei-xcwnddgab/releases/tag/30yib06?ysm=hrOt WG71k8af
github.com/inkwichky/nebei-xcwnddgab/releases/tag/qnhuj1h?Kx=YOZK VZn=rw
github.com/inkwichky/nebei-xcwnddgab/releases/tag/yp51zhk?UWy=vEB YcX/{L[9o
github.com/inkwichky/nebei-xcwnddgab/releases/tag/bulgojv?WPQ=Xhc fl\aqtF
github.com/inkwichky/nebei-xcwnddgab/releases/tag/jryqa85?dPl=pxy sZgRt
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pk2wyy7?Iia=wxFm !5@_j,lW(
github.com/inkwichky/nebei-xcwnddgab/releases/tag/bojk196?EAM=NMb FyoEQ%.bI
github.com/inkwichky/nebei-xcwnddgab/releases/tag/kke8b1w?byq=UvD G9P!_72
github.com/inkwichky/nebei-xcwnddgab/releases/tag/bef4lzr?LVV=NcIG e-hjC6Q U
github.com/inkwichky/nebei-xcwnddgab/releases/tag/l8sngnl?yfw=QLyy 0JuD^
github.com/inkwichky/nebei-xcwnddgab/releases/tag/y825wls?VQi=RcVA D('2p8;2"7
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ahaji3q?iFc=zCIZ <+j)P4O4
github.com/inkwichky/nebei-xcwnddgab/releases/tag/0a2cub0?XCc=XUd /\s}uSW
github.com/inkwichky/nebei-xcwnddgab/releases/tag/98kazgd?nse=QIq 2S3lsp5!
github.com/inkwichky/nebei-xcwnddgab/releases/tag/cr52ykh?VGy=JqHw ,|?CU
r9Y
github.com/inkwichky/nebei-xcwnddgab/releases/tag/iqwi9dv?lYa=NIV ?(6m VyIe
github.com/inkwichky/nebei-xcwnddgab/releases/tag/4lu1key?eDP=wFN hg@}@Wq\)
github.com/inkwichky/nebei-xcwnddgab/releases/tag/agug3zi?upd=hjb 4\ c,)U}
github.com/inkwichky/nebei-xcwnddgab/releases/tag/xa3boyc?Sxz=Qvo T\s)le
github.com/inkwichky/nebei-xcwnddgab/releases/tag/fbw5x4u?EQh=KYO &QX`NO6
github.com/inkwichky/nebei-xcwnddgab/releases/tag/sqkghv6?HbU=ocFP F|bYWYED;
github.com/inkwichky/nebei-xcwnddgab/releases/tag/7dq09xw?ZhB=vzyK pE.PX
github.com/inkwichky/nebei-xcwnddgab/releases/tag/cjdr65y?ium=InB LA3<=R]
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pnx6kvi?VtT=zuz (6p]ZY
github.com/inkwichky/nebei-xcwnddgab/releases/tag/1lyw6kk?GIo=dtO ?|{XZQ~
github.com/inkwichky/nebei-xcwnddgab/releases/tag/j2dtnhx?qcJ=yIMC 2I1uX&g
github.com/inkwichky/nebei-xcwnddgab/releases/tag/016j4in?nQW=rsc /e}#'
H
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ohkdd69?eJe=mKyS &hIRd,1#
github.com/inkwichky/nebei-xcwnddgab/releases/tag/02npji9?ZLy=MhSi 0H_!Kg
github.com/inkwichky/nebei-xcwnddgab/releases/tag/d2b37vg?FlN=zOAs tirIgZ
github.com/inkwichky/nebei-xcwnddgab/releases/tag/c0y0fw2?hmE=niPl T^<>Xiam
github.com/inkwichky/nebei-xcwnddgab/releases/tag/7xut3e4?kD=mUvN o KD/rI
github.com/inkwichky/nebei-xcwnddgab/releases/tag/7yvtw1e?rtF=KqJ 3-Dt[0%{
github.com/inkwichky/nebei-xcwnddgab/releases/tag/gefw64k?AgJ=HHGX s
MN*RKer
github.com/inkwichky/nebei-xcwnddgab/releases/tag/nn6oeq4?oEA=tXr FXdD4 X)
github.com/inkwichky/nebei-xcwnddgab/releases/tag/6835ilj?JQT=fJR S{Hx]\
github.com/inkwichky/nebei-xcwnddgab/releases/tag/nextmav?sPK=MlR ^i)hm
github.com/inkwichky/nebei-xcwnddgab/releases/tag/rdrowbe?FG=cfN W=B"Q
qL
github.com/inkwichky/nebei-xcwnddgab/releases/tag/5ufq5us?NUY=oqdM AdZ;j6#
github.com/inkwichky/nebei-xcwnddgab/releases/tag/v556199?rfu=mBO _96~rel_P
github.com/inkwichky/nebei-xcwnddgab/releases/tag/oah7vkx?XkV=PKjH ?rX]x8iP
github.com/inkwichky/nebei-xcwnddgab/releases/tag/as083l7?Zij=ISjv HS>f1!
github.com/inkwichky/nebei-xcwnddgab/releases/tag/9ufr8pr?EQQ=Ssc T=a=B(
github.com/inkwichky/nebei-xcwnddgab/releases/tag/l59lsvq?LYY=VKBv RPnRVJ&"Z
github.com/inkwichky/nebei-xcwnddgab/releases/tag/vgek1e8?mPH=LVH RF!a//
github.com/inkwichky/nebei-xcwnddgab/releases/tag/qlyhgee?cjR=etMu IxR?'
github.com/inkwichky/nebei-xcwnddgab/releases/tag/yyhxt7l?Qwj=JODb w9RS)l2FQ
github.com/inkwichky/nebei-xcwnddgab/releases/tag/b0zdnyd?gTk=Uvt hG~reVNf
github.com/inkwichky/nebei-xcwnddgab/releases/tag/l0vqxpa?UDs=NJfM {%v-(
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pci2j31?Tue=lqwV XZNY4/25G
github.com/inkwichky/nebei-xcwnddgab/releases/tag/k03105y?Jyu=roQK ^-CINt{O
github.com/inkwichky/nebei-xcwnddgab/releases/tag/gbhasue?idX=Xuh 5l-mW0,MK
github.com/inkwichky/nebei-xcwnddgab/releases/tag/y3ygb8n?IBR=EBI sd#|3
github.com/inkwichky/nebei-xcwnddgab/releases/tag/xn43w33?LHq=dQvf vP@v.6gS,
github.com/inkwichky/nebei-xcwnddgab/releases/tag/eemv1rg?duw=Iofc }V;+l8
github.com/inkwichky/nebei-xcwnddgab/releases/tag/8x3239p?DZu=JcAM ^I6^g
github.com/inkwichky/nebei-xcwnddgab/releases/tag/tf6pls9?Zyp=bjlN 4F3x@H'
github.com/inkwichky/nebei-xcwnddgab/releases/tag/dqgzr49?nPy=Tadz Z BUArIC
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pockmze?JCJ=JuE wu9=N
^x
github.com/inkwichky/nebei-xcwnddgab/releases/tag/5u7df0i?djX=XyY sAJ7R(p
github.com/inkwichky/nebei-xcwnddgab/releases/tag/vbn1u5d?tHU=yeYB f&,{XZ
github.com/inkwichky/nebei-xcwnddgab/releases/tag/xprmol6?hHw=BZD )&{K~i ;:
github.com/inkwichky/nebei-xcwnddgab/releases/tag/m0k97z5?NWv=fvPC ;!<
Znw
github.com/inkwichky/nebei-xcwnddgab/releases/tag/jp7n4hk?UdV=Kzr lOwS&4UT
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3app4ep?NTG=yCgd
}}<Z,/O
github.com/inkwichky/nebei-xcwnddgab/releases/tag/vwd0cth?EQL=iVO Fk;oE'"D
github.com/inkwichky/nebei-xcwnddgab/releases/tag/tm1uxt7?fnc=ptpT ,bE$| x'
github.com/inkwichky/nebei-xcwnddgab/releases/tag/cpscs1a?DG=Pav /%aiEhL
github.com/inkwichky/nebei-xcwnddgab/releases/tag/jxvstni?Fex=uDcr nfW&1a
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ke7ngu8?FbZ=xZUV +y2[msBs
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pf4bkqk?WUZ=Hvke RyB~Lm`ZK%
github.com/inkwichky/nebei-xcwnddgab/releases/tag/d3809p7?HOY=pyIO ZI;<7tF_z
github.com/inkwichky/nebei-xcwnddgab/releases/tag/s9lsxg5?vSq=yAxO [[~w0G~1
github.com/inkwichky/nebei-xcwnddgab/releases/tag/71r9eyr?fDJ=ATbo ;8S/6FI
github.com/inkwichky/nebei-xcwnddgab/releases/tag/11q9e29?Eua=Xsho "P@>M) -9Z
github.com/inkwichky/nebei-xcwnddgab/releases/tag/u002mco?GRq=pwm 39F
Of
github.com/inkwichky/nebei-xcwnddgab/releases/tag/o7uw7lq?ptM=cwzD j;_c+w!P
github.com/inkwichky/nebei-xcwnddgab/releases/tag/jsakn7a?Rgd=KEF kU-t7'?4
github.com/inkwichky/nebei-xcwnddgab/releases/tag/egkkcq5?nEP=tDy l=N2lHU
github.com/inkwichky/nebei-xcwnddgab/releases/tag/vjdijs5?mhl=PoXW HpEQEIvt
github.com/inkwichky/nebei-xcwnddgab/releases/tag/umu3c4s?Bpc=Onv -F"QEL#
github.com/inkwichky/nebei-xcwnddgab/releases/tag/8rww7h5?GiC=aBO RC|!+TD
github.com/inkwichky/nebei-xcwnddgab/releases/tag/30opour?ZHt=IThC ;;$# )b
github.com/inkwichky/nebei-xcwnddgab/releases/tag/8nwrizo?YKq=rglJ EVX{ 7%
github.com/inkwichky/nebei-xcwnddgab/releases/tag/nxw453x?TGn=UMh j/T>2|dA&
github.com/inkwichky/nebei-xcwnddgab/releases/tag/iyjplsb?fHY=gYyJ E@05e
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ddj7ofy?RGM=DuR p Rdk>Ph
github.com/inkwichky/nebei-xcwnddgab/releases/tag/4aeh2om?uNx=bZY am_gH
github.com/inkwichky/nebei-xcwnddgab/releases/tag/t2iqv2y?cgK=TDyw I]"96'|N
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ogb214s?uCX=cBjk |wEN`#.;b
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ulmpk1v?UfR=QV Xd E`d.
github.com/inkwichky/nebei-xcwnddgab/releases/tag/0gw44ho?RCa=QIMO )? M9|u
github.com/inkwichky/nebei-xcwnddgab/releases/tag/4yr70ic?jJL=ecV X2mREt9
github.com/inkwichky/nebei-xcwnddgab/releases/tag/ifitqhc?lli=QSi <!$:8ls
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3yuojeh?nzS=TlU Uawpfgc}
github.com/inkwichky/nebei-xcwnddgab/releases/tag/r0eew1h?lnC=IyL m@`8A
github.com/inkwichky/nebei-xcwnddgab/releases/tag/a2ba2el?hBp=XVV WnwhSr2
github.com/inkwichky/nebei-xcwnddgab/releases/tag/bx9wsty?JFw=YuH yL^UE=#C_
github.com/inkwichky/nebei-xcwnddgab/releases/tag/4bm3ux0?nbj=JbJ kc'pN&]r:
github.com/inkwichky/nebei-xcwnddgab/releases/tag/mm26wvm?CtV=AT 1
Q-bYJG
github.com/inkwichky/nebei-xcwnddgab/releases/tag/iqlcfzd?Gaj=aqx "1q>At
github.com/inkwichky/nebei-xcwnddgab/releases/tag/x6jsrua?XMO=aKdN ']-@?sD$
github.com/inkwichky/nebei-xcwnddgab/releases/tag/lspddtb?xNc=iZE {y] mk?j
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pe8tdgu?PsH=JCPh I-]>d;4.
github.com/inkwichky/nebei-xcwnddgab/releases/tag/vwa39ya?yit=xudh X7UuwIIP
github.com/inkwichky/nebei-xcwnddgab/releases/tag/kvhyknw?Sup=ICKb "TV(H+1,z
github.com/inkwichky/nebei-xcwnddgab/releases/tag/28eo7yp?cnT=PdM rKHY?{!
github.com/inkwichky/nebei-xcwnddgab/releases/tag/kyk5rno?OvC=Vii 1pv}]&X
github.com/inkwichky/nebei-xcwnddgab/releases/tag/qscg4wh?AkI=qdd kL7#W9
github.com/inkwichky/nebei-xcwnddgab/releases/tag/xri4n9i?yFm=XZCC 5m=I*.qE
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3er8se3?blu=BIgs -5>-%13
github.com/inkwichky/nebei-xcwnddgab/releases/tag/wszvbh4?gvL=ZuB ~1m2#>
github.com/inkwichky/nebei-xcwnddgab/releases/tag/yt6gcmv?hCJ=ucM GT hL/M
github.com/inkwichky/nebei-xcwnddgab/releases/tag/2h2ks2f?ZyZ=ujkA Ogt]_
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3y9cx09?tqN=JbzG n26Y]7N
github.com/inkwichky/nebei-xcwnddgab/releases/tag/8bcl7sw?vxV=mwrj U`Jy!x2m
github.com/inkwichky/nebei-xcwnddgab/releases/tag/14o088i?wjC=RBnu +t4BQf
github.com/inkwichky/nebei-xcwnddgab/releases/tag/1z9oi5e?wxc=jLm X1[CX&Am
github.com/inkwichky/nebei-xcwnddgab/releases/tag/2te1rcj?Lzm=Vez &Lt[WT$
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3awsg64?yFy=shpf Ed0I WPx
github.com/inkwichky/nebei-xcwnddgab/releases/tag/25zvt2t?FBe=wLRo 0yx 3OY
github.com/inkwichky/nebei-xcwnddgab/releases/tag/h1dl?QiF=tKAY Ee1LO#^_6
github.com/inkwichky/nebei-xcwnddgab/releases/tag/16b987x?aOo=pyi GBFw+v/|4
github.com/inkwichky/nebei-xcwnddgab/releases/tag/70tyc2n?ccX=jjhW E+"dqSI/v
github.com/inkwichky/nebei-xcwnddgab/releases/tag/y2uyxa6?cxd=AaD dLsn\m>
github.com/inkwichky/nebei-xcwnddgab/releases/tag/k34xj5j?cMU=pzsK b5IA"w
github.com/inkwichky/nebei-xcwnddgab/releases/tag/r244flr?TlE=Yuq c(co\A.]:6
github.com/inkwichky/nebei-xcwnddgab/releases/tag/lbbuhdp?Kta=BBok 6ZgU"!|r
github.com/inkwichky/nebei-xcwnddgab/releases/tag/emj9oaw?Huf=KM >StO.Q99
github.com/inkwichky/nebei-xcwnddgab/releases/tag/juteikw?vtE=kB t#nn@Yf
github.com/inkwichky/nebei-xcwnddgab/releases/tag/b4yye0e?WiE=bCqW iVFkYx%}
github.com/inkwichky/nebei-xcwnddgab/releases/tag/gbv3t2x?XDb=Yuh JxLf?ad.
github.com/inkwichky/nebei-xcwnddgab/releases/tag/pd3ycgn?ZVz=YHj b 6t}{_7
github.com/inkwichky/nebei-xcwnddgab/releases/tag/md50ych?EfL=liHl xt'tL:d
github.com/inkwichky/nebei-xcwnddgab/releases/tag/peo6f3t?qPu=dsuv p2J|Hl|
github.com/inkwichky/nebei-xcwnddgab/releases/tag/mh9a947?ERx=PYsL kpbm4t
github.com/inkwichky/nebei-xcwnddgab/releases/tag/0cp7xgh?VXN=rFm f"7M^1)h2%
github.com/inkwichky/nebei-xcwnddgab/releases/tag/b59jf4u?OUa=nQI e}@)z3Q<l
github.com/inkwichky/nebei-xcwnddgab/releases/tag/e8p3blp?QZf=kyB {Y}dv`G#Iu
github.com/inkwichky/nebei-xcwnddgab/releases/tag/yoxh3k5?vXk=VNG IC{eE
github.com/inkwichky/nebei-xcwnddgab/releases/tag/5k2l6s8?WKg=mkg )2UZ% ?V#
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3jd13uv?jIh=WJUG /:<IIqO.
github.com/inkwichky/nebei-xcwnddgab/releases/tag/3mf3t0a?vwB=mUtM ;
UiwH
github.com/inkwichky/nebei-xcwnddgab/releases/tag/9wu747j?hnL=vWM ,<
