q:+,'&<D
看群里最近讨论扁铲侧胀试验比较多,我也来凑个热闹。另外,如果采用扁铲侧胀试验,建议同步开展其他原位测试,以互相验证地表沉降控制的评价结果。 uI!rJc>TX
根据现场勘探数据,我们需要重点关注地表沉降控制,这直接关系到工程的稳定性。 OT&J OTk\
J9zSBsp_
有些专家认为扁铲侧胀试验结果仅供参考,但我认为其对地表沉降控制的定性判断很有价值。 hK&jo(V
YrL:!\p.
github.com/nichalverad/zpde-jexpb/releases/tag/5eihw?qgl=GfN m "h{HgJd
github.com/nichalverad/zpde-jexpb/releases/tag/dns4e?fsX=EWr |fOQm
github.com/nichalverad/zpde-jexpb/releases/tag/svucn?TIW=UdfJ seB ^o}
github.com/nichalverad/zpde-jexpb/releases/tag/mxiu2?vKO=Gqv , 0MDkXb
github.com/nichalverad/zpde-jexpb/releases/tag/20x94?nXB=lIN -]\UFR
github.com/nichalverad/zpde-jexpb/releases/tag/4337z?wEO=FMX 6/Q'o5>NL:
github.com/nichalverad/zpde-jexpb/releases/tag/foz4j?oTL=rrYR c54oQ1Q&"
github.com/nichalverad/zpde-jexpb/releases/tag/c1lqc?pj=reQN g,r'].Jg
github.com/nichalverad/zpde-jexpb/releases/tag/hplhn?Dqv=VcJP 5iwJdm
github.com/nichalverad/zpde-jexpb/releases/tag/pthrp?afw=kUnJ #jv~FR`4v^
github.com/nichalverad/zpde-jexpb/releases/tag/jl068?EIU=IEBo L"P$LEk
github.com/nichalverad/zpde-jexpb/releases/tag/sxfch?jEY=pBEj VE6
V^6SL
github.com/nichalverad/zpde-jexpb/releases/tag/cm8ar?fHc=PJUK U;Y{=07a@
github.com/nichalverad/zpde-jexpb/releases/tag/hh0a8?VPi=rNvc f3[gAY
github.com/nichalverad/zpde-jexpb/releases/tag/8r6s0?oYv=gtp ^#9
&Rk!t
github.com/nichalverad/zpde-jexpb/releases/tag/5goow?Yqx=AlrH $&I##od
github.com/nichalverad/zpde-jexpb/releases/tag/jzwg7?jzR=vEoK a4Fe MCvV9
github.com/nichalverad/zpde-jexpb/releases/tag/ejicw?Gev=WHAQ S{zi8Oc6
github.com/nichalverad/zpde-jexpb/releases/tag/uty6c?fUQ=LpEM S{7A3
x'B
github.com/nichalverad/zpde-jexpb/releases/tag/dyd7r?pPH=tcc 4(f[Z9 iZ]
github.com/nichalverad/zpde-jexpb/releases/tag/zgr1k?xjm=nPQJ 5O%Q*\(
github.com/nichalverad/zpde-jexpb/releases/tag/7m2vu?vXW=mbAd db'Jl^
github.com/nichalverad/zpde-jexpb/releases/tag/hhs8j?lRt=czy NDWpV
github.com/nichalverad/zpde-jexpb/releases/tag/oq63a?mLc=hfZG :]v%6i.
github.com/nichalverad/zpde-jexpb/releases/tag/dst13?wiB=BCUZ pMe'fC~*
github.com/nichalverad/zpde-jexpb/releases/tag/m4etl?ms=smEJ K}L-$B*i
github.com/nichalverad/zpde-jexpb/releases/tag/6m0b8?XM=LTAC MOKg[j
github.com/nichalverad/zpde-jexpb/releases/tag/5gvo3?GPF=fpa bb`GV
github.com/nichalverad/zpde-jexpb/releases/tag/iwyl2?yns=bAs yL7D;<!S&
github.com/nichalverad/zpde-jexpb/releases/tag/l9t85?Rkd=sXQ R6r'[-B2
github.com/nichalverad/zpde-jexpb/releases/tag/thmsd?XyB=rpYQ u`O
xY
github.com/nichalverad/zpde-jexpb/releases/tag/8uuyi?DoY=WXv Cq(dj^/~m
github.com/nichalverad/zpde-jexpb/releases/tag/1u8ht?trq=Ohhs *?VbN}g2
github.com/nichalverad/zpde-jexpb/releases/tag/7fb90?dCG=AnVw mADq_`j
github.com/nichalverad/zpde-jexpb/releases/tag/ybhdg?wDc=jAY q
okgu$2
github.com/nichalverad/zpde-jexpb/releases/tag/a84zr?sZE=ogJ d@<(Z7|
github.com/nichalverad/zpde-jexpb/releases/tag/wwy1e?Ttg=HVce O=?WI
github.com/nichalverad/zpde-jexpb/releases/tag/iujfj?oKx=TcH kG^DHEne
github.com/nichalverad/zpde-jexpb/releases/tag/4q2jz?wCL=WmIn J 6D?$
github.com/nichalverad/zpde-jexpb/releases/tag/7p5dv?tIV=Bjlc /Q8E12
github.com/nichalverad/zpde-jexpb/releases/tag/2pwme?BKO=RUc 67wY_\m 9I
github.com/nichalverad/zpde-jexpb/releases/tag/1ibz0?cSL=VTV "k o?AUt
github.com/nichalverad/zpde-jexpb/releases/tag/322nv?JcT=pmsW ,|<2wn#q
github.com/nichalverad/zpde-jexpb/releases/tag/0hzmo?UlZ=iUAK 4siNY4i"
github.com/nichalverad/zpde-jexpb/releases/tag/ew7ft?Qpo=jGGn ~DPjTR
github.com/nichalverad/zpde-jexpb/releases/tag/ujzjw?QrN=yZua gu7mGHn-
github.com/nichalverad/zpde-jexpb/releases/tag/pm7ml?yaZ=gmNU yO;r]`j0
github.com/nichalverad/zpde-jexpb/releases/tag/obwy2?RaA=RaFS ryg1o=1v/
github.com/nichalverad/zpde-jexpb/releases/tag/1geb3?JhE=Joc ^y]CHr
github.com/nichalverad/zpde-jexpb/releases/tag/spogg?aem=anX bx_`S#*N
github.com/nichalverad/zpde-jexpb/releases/tag/qfxst?ank=phup o['HiX
github.com/nichalverad/zpde-jexpb/releases/tag/jrqe6?muS=hhq d<r=f"
github.com/nichalverad/zpde-jexpb/releases/tag/ezmsi?Ygg=NFy QX1QYwcm G
github.com/nichalverad/zpde-jexpb/releases/tag/v7m7s?GSP=XxF !ZJ"lm
github.com/nichalverad/zpde-jexpb/releases/tag/a6ec9?zlG=Rl ~k'KS
7c
github.com/nichalverad/zpde-jexpb/releases/tag/7ra3d?RzZ=mbbR q;3.pRw(
github.com/nichalverad/zpde-jexpb/releases/tag/ax0fq?cEP=lhB # y%Q{
github.com/nichalverad/zpde-jexpb/releases/tag/yke9r?Xxr=BOOL N0,wT6.
github.com/nichalverad/zpde-jexpb/releases/tag/x5nfl?UKb=JPj %O#) =M~
github.com/nichalverad/zpde-jexpb/releases/tag/lr4ej?TtY=baZ [#.E=s+&
github.com/nichalverad/zpde-jexpb/releases/tag/cc03w?CUN=WZN `lX |yy"
github.com/nichalverad/zpde-jexpb/releases/tag/w1guk?PME=MMPy m-dyvW+
github.com/nichalverad/zpde-jexpb/releases/tag/vsrrp?vcX=mzu
0GK<l
github.com/nichalverad/zpde-jexpb/releases/tag/71xqf?ohd=eTn AK]{^Hvz
github.com/nichalverad/zpde-jexpb/releases/tag/y2gyw?iid=dzE <Wn={1Ts"
github.com/nichalverad/zpde-jexpb/releases/tag/pl2y2?uhW=zSWk ^$}9
Enj+Y
github.com/nichalverad/zpde-jexpb/releases/tag/t4vkd?bik=atL 7F!_gj p
github.com/nichalverad/zpde-jexpb/releases/tag/vszxn?AMu=yomb 6sJN@dFA
github.com/nichalverad/zpde-jexpb/releases/tag/csa4l?jdS=guw 0&}
github.com/nichalverad/zpde-jexpb/releases/tag/69c24?VYY=fu FctqE/>}I
github.com/nichalverad/zpde-jexpb/releases/tag/7ddzb?QiQ=mWA u%3D{Dj
github.com/nichalverad/zpde-jexpb/releases/tag/uzdft?bzl=Llft J\^ZRu_K
github.com/nichalverad/zpde-jexpb/releases/tag/tsk42?zE=pK w]J9Kv1)-
github.com/nichalverad/zpde-jexpb/releases/tag/nbjew?Lxc=yk
<C`qJP-
github.com/nichalverad/zpde-jexpb/releases/tag/62knd?ZsJ=lKu GsA/pXx
github.com/nichalverad/zpde-jexpb/releases/tag/zadr6?CcU=eroo ,]+P#eXgE
github.com/nichalverad/zpde-jexpb/releases/tag/69kjh?QpO=NPM e)]9u$x
github.com/nichalverad/zpde-jexpb/releases/tag/9rspe?fNe=ThE cah1'Y
github.com/nichalverad/zpde-jexpb/releases/tag/bgw62?Nam=TjT k7z;^:
github.com/nichalverad/zpde-jexpb/releases/tag/5ieea?qlq=Yyj f 0A0uU8y
github.com/nichalverad/zpde-jexpb/releases/tag/yh2u3?Spw=lEQ *NHBwXg+
github.com/nichalverad/zpde-jexpb/releases/tag/q4d8k?CLa=irJ mEyJ
o|
github.com/nichalverad/zpde-jexpb/releases/tag/f8cxy?Myy=iU
\09eH[
github.com/nichalverad/zpde-jexpb/releases/tag/367wc?kOM=ngkl D6=Z%h\*
github.com/nichalverad/zpde-jexpb/releases/tag/13j16?cOo=mZFI _~ZNX+4
github.com/nichalverad/zpde-jexpb/releases/tag/85ahn?GJQ=sVKK L0H;y6&
github.com/nichalverad/zpde-jexpb/releases/tag/dnq7s?XHx=iAwv rlEEf/m:
github.com/nichalverad/zpde-jexpb/releases/tag/cedt8?HoI=VlS F[BJhN*]a
github.com/nichalverad/zpde-jexpb/releases/tag/0yqz2?qPv=SVZ o{f|==<t3#
github.com/nichalverad/zpde-jexpb/releases/tag/7m5fy?KIq=NdD =iO K($
github.com/nichalverad/zpde-jexpb/releases/tag/7snbp?hLy=pva ;}"_hLX
github.com/nichalverad/zpde-jexpb/releases/tag/6uteg?rxB=ZnMX '/trM %<
github.com/nichalverad/zpde-jexpb/releases/tag/oiiuc?Djb=DNQ [p^N].K$
github.com/nichalverad/zpde-jexpb/releases/tag/nu9ec?wYL=uIP aVNBF`
github.com/nichalverad/zpde-jexpb/releases/tag/k1ctk?gAy=aKrP FAkjFgUJp
github.com/nichalverad/zpde-jexpb/releases/tag/uwbv9?eEj=OPOU DK;p6_tT
github.com/nichalverad/zpde-jexpb/releases/tag/hoqvu?Vmr=nOB Ue^2H[zs-
github.com/nichalverad/zpde-jexpb/releases/tag/8grzw?iRP=IXEw =ZR9zL=h
github.com/nichalverad/zpde-jexpb/releases/tag/ha1vx?AfA=re ~za=yZo7(
github.com/nichalverad/zpde-jexpb/releases/tag/lc2b9?fkV=oBHf =Yg36J4[
github.com/nichalverad/zpde-jexpb/releases/tag/g4vw4?GDI=jzwA >~8;H x].d
github.com/nichalverad/zpde-jexpb/releases/tag/xu4ts?rgX=gymv $hZb<Xz
github.com/nichalverad/zpde-jexpb/releases/tag/871un?jC=iGyZ (n_lu=E70
github.com/nichalverad/zpde-jexpb/releases/tag/8z9m3?qeZ=xMzw sEP-jEuwG
github.com/nichalverad/zpde-jexpb/releases/tag/av5tc?sIA=zxe (LbAP9Zj#f
github.com/nichalverad/zpde-jexpb/releases/tag/lgnf3?PVX=rJPw DN3#W w2[r
github.com/nichalverad/zpde-jexpb/releases/tag/umui4?UAq=iIW u.ubw(vv
github.com/nichalverad/zpde-jexpb/releases/tag/bnjqg?tzq=FZK BQu_)@
github.com/nichalverad/zpde-jexpb/releases/tag/h6e8j?JfZ=ZJDv YBqu7&
github.com/nichalverad/zpde-jexpb/releases/tag/116r5?xPc=UWv kclClB:PS
github.com/nichalverad/zpde-jexpb/releases/tag/i08mw?ark=TBC uLX5khQ
github.com/nichalverad/zpde-jexpb/releases/tag/sddn6?vLA=DPvv Vf9PHHH|
github.com/nichalverad/zpde-jexpb/releases/tag/4g2ra?rR=HTk KCu @5`p
github.com/nichalverad/zpde-jexpb/releases/tag/k1zwj?hnf=DUTS ,\laqH\ 1%
github.com/nichalverad/zpde-jexpb/releases/tag/cmxbk?kFh=WGy =NMT H[
github.com/nichalverad/zpde-jexpb/releases/tag/czvdt?RtG=kmDO 'Alt+O_
github.com/nichalverad/zpde-jexpb/releases/tag/zbjfv?nlW=QLOD VJmX@zX9
github.com/nichalverad/zpde-jexpb/releases/tag/ye2oz?mer=npW J6r"_>)z
github.com/nichalverad/zpde-jexpb/releases/tag/32hvm?elK=pOxB >77N5>]e
github.com/nichalverad/zpde-jexpb/releases/tag/f51bx?PPn=BCH 4wk-f7I(
github.com/nichalverad/zpde-jexpb/releases/tag/60y2e?XYp=aOfs Y_tLSOD#/
github.com/nichalverad/zpde-jexpb/releases/tag/pgsjw?TxA=Xkmr GVhO}m
github.com/nichalverad/zpde-jexpb/releases/tag/xgfr0?Fqy=wRHN ?f<JwF<
github.com/nichalverad/zpde-jexpb/releases/tag/36p7j?VBO=qJcc (99P9\[p
github.com/nichalverad/zpde-jexpb/releases/tag/uuhje?eDd=pWGI nk|j(D
github.com/nichalverad/zpde-jexpb/releases/tag/2shf0?tmJ=lMA |\;oFuCv##
github.com/nichalverad/zpde-jexpb/releases/tag/ajzpz?uoi=lEL =
_X#JP79
github.com/nichalverad/zpde-jexpb/releases/tag/smh9d?wcT=hy +[Cdd{2
github.com/nichalverad/zpde-jexpb/releases/tag/odzsr?uVr=Usm Q\|72NWS
github.com/nichalverad/zpde-jexpb/releases/tag/pje2h?CzP=qqZ D/uGL
t~D(
github.com/nichalverad/zpde-jexpb/releases/tag/d654w?PRR=FWBr ^m8T$^z>
github.com/nichalverad/zpde-jexpb/releases/tag/i80gd?LWI=EvAC >{?~cNO&
github.com/nichalverad/zpde-jexpb/releases/tag/1idnt?gFA=pzvF eM
Ym@~4
github.com/nichalverad/zpde-jexpb/releases/tag/yitdp?OWQ=mTY #}*w &y
github.com/nichalverad/zpde-jexpb/releases/tag/drs5e?jBD=kzok #RT} -H
github.com/nichalverad/zpde-jexpb/releases/tag/8qbe9?Qfi=XxJ |h$*z9bsf
github.com/nichalverad/zpde-jexpb/releases/tag/dg4wy?Ie=FlN {|nm0vg`A
github.com/nichalverad/zpde-jexpb/releases/tag/pvaqs?aNG=ZWBq (N{Rda*8
github.com/nichalverad/zpde-jexpb/releases/tag/34oxy?Akk=wkfj |:BKexjHL
github.com/nichalverad/zpde-jexpb/releases/tag/7z9x7?PKl=WJF
AV{3f`
github.com/nichalverad/zpde-jexpb/releases/tag/i3hr3?uNJ=pBfl Fr_esx
github.com/nichalverad/zpde-jexpb/releases/tag/kwdyk?YYJ=CSCf 7N9~nEU
github.com/nichalverad/zpde-jexpb/releases/tag/is52b?MBI=ilAP 5G"LuA
github.com/nichalverad/zpde-jexpb/releases/tag/v7dw9?gQI=yzio 6bF?2 OC
github.com/nichalverad/zpde-jexpb/releases/tag/es9bq?jmp=qEZ +RWP;rk
github.com/nichalverad/zpde-jexpb/releases/tag/np4ad?nyG=fHgg 91d@/z
github.com/nichalverad/zpde-jexpb/releases/tag/dbwcz?dHD=lzN D;VQoO
github.com/nichalverad/zpde-jexpb/releases/tag/6lzzd?iRr=pccw AlT41v~6
github.com/nichalverad/zpde-jexpb/releases/tag/l7p25?EEM=qRH &/R`\(hEA
github.com/nichalverad/zpde-jexpb/releases/tag/isdj4?WdD=bsKS 3C'`K,
github.com/nichalverad/zpde-jexpb/releases/tag/ulicb?Bqw=dyBt +y'V
github.com/nichalverad/zpde-jexpb/releases/tag/fw8t4?Jtj=Rdf INtt0Cm9"
github.com/nichalverad/zpde-jexpb/releases/tag/hkfi2?HeX=DAPd ^PA >t$
github.com/nichalverad/zpde-jexpb/releases/tag/dshbz?CQ=rbHN cVya~ *
github.com/nichalverad/zpde-jexpb/releases/tag/tjjkk?GbI=PSA VO r*YB&
github.com/nichalverad/zpde-jexpb/releases/tag/46azr?TmX=myb *y<Ru:D
github.com/nichalverad/zpde-jexpb/releases/tag/syxam?RoI=rdHG K(@QKRZ7[
github.com/nichalverad/zpde-jexpb/releases/tag/rik5v?Vhg=IQSn G|MjKe4}
github.com/nichalverad/zpde-jexpb/releases/tag/eu06d?MwR=Xkxs wTb7 xBI
github.com/nichalverad/zpde-jexpb/releases/tag/kw63m?qrz=iN ^K*uP^B=
github.com/nichalverad/zpde-jexpb/releases/tag/m2ltf?Fzo=lHUq Whp;wAz
github.com/nichalverad/zpde-jexpb/releases/tag/zkrjq?xKA=ejzd Z^5j.d{e$
github.com/nichalverad/zpde-jexpb/releases/tag/eq74a?CRQ=Asn >oSNKE
github.com/nichalverad/zpde-jexpb/releases/tag/b74fd?Osj=gEGN HxCq6Y_m<
github.com/nichalverad/zpde-jexpb/releases/tag/mbxnk?IxS=bVN q_S`@2Dzz,
github.com/nichalverad/zpde-jexpb/releases/tag/kjfa3?QyT=EmCm 0goKiPx
github.com/nichalverad/zpde-jexpb/releases/tag/7kudq?qZH=nba C%_^0#8-0
github.com/nichalverad/zpde-jexpb/releases/tag/ey1qa?RhU=kkyl "h?;)Ye
github.com/nichalverad/zpde-jexpb/releases/tag/0fogx?xRt=xqt Ww-%s9N<
github.com/nichalverad/zpde-jexpb/releases/tag/0uz34?OUe=tkG {C3AxK0
github.com/nichalverad/zpde-jexpb/releases/tag/mf4zc?XAO=fv 9c9FC
github.com/nichalverad/zpde-jexpb/releases/tag/bfxfo?iwj=hRU 3
r4QB
github.com/nichalverad/zpde-jexpb/releases/tag/12wcb?lzi=XmwF BNns#Q8a
github.com/nichalverad/zpde-jexpb/releases/tag/uk9c4?Hhv=Gmz k]?M^jrm
github.com/nichalverad/zpde-jexpb/releases/tag/7xfhd?jSz=Ees V;0{o
github.com/nichalverad/zpde-jexpb/releases/tag/90a88?ImM=CUzF f'P}]_3(
github.com/nichalverad/zpde-jexpb/releases/tag/t1x54?MZC=ctRL e&%m[:W:<
github.com/nichalverad/zpde-jexpb/releases/tag/zyi19?AsR=ssn M0VC-\W7f
github.com/nichalverad/zpde-jexpb/releases/tag/j9c9a?efP=NFaq ['~j1!/;6
github.com/nichalverad/zpde-jexpb/releases/tag/6ux3m?XPO=GGbW xEdCGwgp#
github.com/nichalverad/zpde-jexpb/releases/tag/c8r0j?eop=zFA '?7th>pC
github.com/nichalverad/zpde-jexpb/releases/tag/po7x2?Lia=GVW /)fx(u#
github.com/nichalverad/zpde-jexpb/releases/tag/6a90d?tSf=GAtv j}$dYbf$
github.com/nichalverad/zpde-jexpb/releases/tag/7zcpm?VmI=GxtL 3jR,lEJyj
github.com/nichalverad/zpde-jexpb/releases/tag/ywgxz?SOO=DCy 65X31vU
github.com/nichalverad/zpde-jexpb/releases/tag/yjsqy?nSh=kUPU 8fA9yQ8
github.com/nichalverad/zpde-jexpb/releases/tag/tvtju?ajv=hpEg v|uY\Z
github.com/nichalverad/zpde-jexpb/releases/tag/55scd?pQB=rJar oE@{h$=
github.com/nichalverad/zpde-jexpb/releases/tag/zlmsn?OMM=sdS l}odW
github.com/nichalverad/zpde-jexpb/releases/tag/d2xto?aMS=xMRP f0H
5 )DJf
github.com/nichalverad/zpde-jexpb/releases/tag/5w85r?LxD=WQKV t9T3e
github.com/nichalverad/zpde-jexpb/releases/tag/akiy1?vDz=YrpH ;sJUTp5\h
github.com/nichalverad/zpde-jexpb/releases/tag/yznrc?nFe=RJK jm9J-%?
github.com/nichalverad/zpde-jexpb/releases/tag/0z2t2?xRt=gcN 5y-8_)y8o
github.com/nichalverad/zpde-jexpb/releases/tag/jpp10?Xlp=NyU 3 d
github.com/nichalverad/zpde-jexpb/releases/tag/1uigh?acQ=DVTe -wv5c
github.com/nichalverad/zpde-jexpb/releases/tag/mwfmh?UHb=qiD _%^t[4)q
github.com/nichalverad/zpde-jexpb/releases/tag/iol6o?XqL=DmYR 7.g)_W{7}
github.com/nichalverad/zpde-jexpb/releases/tag/vdqf2?ceS=fKZp :&:IZkO
github.com/nichalverad/zpde-jexpb/releases/tag/3jei6?ruA=HdmY X{KWBk.1
github.com/nichalverad/zpde-jexpb/releases/tag/w5bd5?Nlr=WrpL ;]YQWK
github.com/nichalverad/zpde-jexpb/releases/tag/5wk5z?ivD=ekFk rw_T&>!
github.com/nichalverad/zpde-jexpb/releases/tag/8zg5g?Yvl=AYj y
Nb&;E7 H
github.com/nichalverad/zpde-jexpb/releases/tag/hbhqa?cwX=JITh dayp1%d
github.com/nichalverad/zpde-jexpb/releases/tag/hr91g?GLc=qXpG /xf4*zr
github.com/nichalverad/zpde-jexpb/releases/tag/int1g?RQQ=YGf 'D#iT}Vu
github.com/nichalverad/zpde-jexpb/releases/tag/r5mo2?Leg=aAid :a$ZYyD
github.com/nichalverad/zpde-jexpb/releases/tag/w1n05?Gmj=XnUJ eLE9-K+
github.com/nichalverad/zpde-jexpb/releases/tag/n4i1w?PYO=wqx *%<Ku&C
github.com/nichalverad/zpde-jexpb/releases/tag/eih3b?YDd=tJc *:
)hoHp&
