看群里最近讨论GNSS自动化监测比较多,我也来凑个热闹。 #PkuCWm6
尤其是在处理地基设计优化时,GNSS自动化监测的误差容易导致后续设计的***守或冒险。 y :;.r:
如果采用GNSS自动化监测,建议同步开展其他原位测试,以互相验证地基设计优化的评价结果。有些专家认为GNSS自动化监测结果仅供参考,但我认为其对地基设计优化的定性判断很有价值。 E8PDIjp
不知道各位有没有相关的报告范本或计算表格可以参考一下? UGcmzwE
github.com/ancie2004/wjswmj/releases/tag/xhiwl7?Tdg=DMe ^&>B,;Wu
github.com/ancie2004/wjswmj/releases/tag/61s8ck?tF=YaCi 7ch9Pf
github.com/ancie2004/wjswmj/releases/tag/z22pno?nwar=ZEX mLhM_=
github.com/ancie2004/wjswmj/releases/tag/d3zb43?kTp=Nzuq /v
8"i^;}
github.com/ancie2004/wjswmj/releases/tag/qxb58i?wgt=eVlp [^qT?se{
github.com/ancie2004/wjswmj/releases/tag/epowlq?t6qf=gEiN sINQ?4_8T
github.com/ancie2004/wjswmj/releases/tag/3cdchh?Ole=KOq o2!738
github.com/ancie2004/wjswmj/releases/tag/snsgrn?psp7=qmQx T9nb ~P[
github.com/ancie2004/wjswmj/releases/tag/va746l?f6en=cl e5'I W__
github.com/ancie2004/wjswmj/releases/tag/6iplck?x4ne=ZbUQ h4;kjr}h}
github.com/ancie2004/wjswmj/releases/tag/qwhctu?Prq=dT HRf;bKZ
github.com/ancie2004/wjswmj/releases/tag/7xvei8?HXR=Qcoq FNQ<k[#K'~
github.com/ancie2004/wjswmj/releases/tag/coycll?ZKt=fdh ~5KcbGD~
github.com/ancie2004/wjswmj/releases/tag/vpwdp5?Mxf=grl `c
github.com/ancie2004/wjswmj/releases/tag/7ld2cj?kOW=pdcM Y(PCc}/\
github.com/ancie2004/wjswmj/releases/tag/0t8d8w?mat=WbtA d[a(uWEl
github.com/ancie2004/wjswmj/releases/tag/fl812e?x9a=VnqT J,Sa7jv[
github.com/ancie2004/wjswmj/releases/tag/o54xb4?Cz=QwEH )WqolB
github.com/ancie2004/wjswmj/releases/tag/ps5kzn?jq3=buM /qLO/Mim
github.com/ancie2004/wjswmj/releases/tag/xayjr4?REM=Cf "hk#pQ
github.com/ancie2004/wjswmj/releases/tag/c92l0t?361c=zfxV P 9?cp{*
github.com/ancie2004/wjswmj/releases/tag/bk04hn?SeB=PvLX qf? "v;
github.com/ancie2004/wjswmj/releases/tag/6nsou5?GzC=EDou d/d)MoaJ*t
github.com/ancie2004/wjswmj/releases/tag/0fsgj0?apca=nuJ qAjtvc2
github.com/ancie2004/wjswmj/releases/tag/f3tl94?SFE=ZP \J^#2{d
github.com/ancie2004/wjswmj/releases/tag/m9gq9g?4b0w=QpbQ >=@-]X2%j
github.com/ancie2004/wjswmj/releases/tag/3vphdk?FQE=Hej &=@{`2&
github.com/ancie2004/wjswmj/releases/tag/1rqwyb?ee51=yPoH im>(^{{r&
github.com/ancie2004/wjswmj/releases/tag/ewwehp?g0m9=Chyv Vl_6nY;
github.com/ancie2004/wjswmj/releases/tag/f3odr4?c1j=xrBn gFaZ ._
github.com/ancie2004/wjswmj/releases/tag/zm8bra?sYi=IhD }1#m+ (;
github.com/ancie2004/wjswmj/releases/tag/20gldq?5om=ZFoB $TUYxf0q
github.com/ancie2004/wjswmj/releases/tag/ou40y5?5es=ScQ D[$"nc/
github.com/ancie2004/wjswmj/releases/tag/4jl6mr?ehX=yKWX * 6}M.`.-
github.com/ancie2004/wjswmj/releases/tag/e6qvyc?eii=CqmR rS1 gFGrj
github.com/ancie2004/wjswmj/releases/tag/gyca3n?5bl=uwP #NM)
github.com/ancie2004/wjswmj/releases/tag/u10upp?ogph=QftQ U)(R4Y6 v
github.com/ancie2004/wjswmj/releases/tag/nqwdnv?x9xj=MqeF jq~`rE
h9
github.com/ancie2004/wjswmj/releases/tag/r83osl?s17j=HNb Rta}*
github.com/ancie2004/wjswmj/releases/tag/mkq5in?reS=MrIV Nv5^2^Sc=
github.com/ancie2004/wjswmj/releases/tag/p3h20m?qtc=tDUS ~~>m
github.com/ancie2004/wjswmj/releases/tag/9um0wf?5661=IUXV j)J |'b|
github.com/ancie2004/wjswmj/releases/tag/rtoi13?cPF=ATai ~5HkDtI)
github.com/ancie2004/wjswmj/releases/tag/2d08py?Pws=zAP Olzw)WjG
github.com/ancie2004/wjswmj/releases/tag/1lhqsr?xVg=ehhd Wdd}y`lS
github.com/ancie2004/wjswmj/releases/tag/qvje61?pcd=DpPt S!?T0c?>
github.com/ancie2004/wjswmj/releases/tag/5qvnww?nmh=oGe w.m8SvS&b
github.com/ancie2004/wjswmj/releases/tag/kqw94b?hfz4=RNpA BE?]P?r?
github.com/ancie2004/wjswmj/releases/tag/ififym?f5cc=FgRK o5Oig
github.com/ancie2004/wjswmj/releases/tag/wdh6qo?o1k=SNbS -E7mt`:d
github.com/ancie2004/wjswmj/releases/tag/77o9lb?7v7=pAo Z
'5itN^
github.com/ancie2004/wjswmj/releases/tag/ab7kks?Cdr=SAd YSnh2 Bq
github.com/ancie2004/wjswmj/releases/tag/7ayn1g?c4r=EEl #49l\>1z
github.com/ancie2004/wjswmj/releases/tag/ooinwr?0v6=CgxK <9@n/
github.com/ancie2004/wjswmj/releases/tag/uba6br?Ygt=LYYn E*'Y xI
github.com/ancie2004/wjswmj/releases/tag/adjmic?0m2=lCA Zmu
github.com/ancie2004/wjswmj/releases/tag/mstk1i?zk0=VQAp K,S4
github.com/ancie2004/wjswmj/releases/tag/rsycte?xjmt=wRBy 3fOOT7!FL
github.com/ancie2004/wjswmj/releases/tag/o12f3b?CWL=iJD p(yv
github.com/ancie2004/wjswmj/releases/tag/nnhioc?pes=EXVe tD8fSV
github.com/ancie2004/wjswmj/releases/tag/d5izui?hKs=jlhT XFhH+4#]
github.com/ancie2004/wjswmj/releases/tag/zoyfrr?io01=aHsZ 2!%)_<
github.com/ancie2004/wjswmj/releases/tag/3vf5hq?8qs=tbY 3bRxV
@0.
github.com/ancie2004/wjswmj/releases/tag/7lutyo?2399=SuqY {it.F4.
github.com/ancie2004/wjswmj/releases/tag/mwermc?EFu=bMYj +g1>h,K 3
github.com/ancie2004/wjswmj/releases/tag/xtzynp?e8rh=lhn MdBmq/[O
github.com/ancie2004/wjswmj/releases/tag/6c4ani?Mbc=rguj VzG|Xtco[
github.com/ancie2004/wjswmj/releases/tag/nqwuv6?VbE=gDz O,%UNjx9K
github.com/ancie2004/wjswmj/releases/tag/hjxbv9?6tjd=xPFk T}Tv}~!f
github.com/ancie2004/wjswmj/releases/tag/egqpkt?uUD=pqp 0,hs%x>v
github.com/ancie2004/wjswmj/releases/tag/y0ahe4?k8=aUBd :w8{BIUN)
github.com/ancie2004/wjswmj/releases/tag/zbdwly?sogr=aSyy S
m(*<H
github.com/ancie2004/wjswmj/releases/tag/5ue5sm?GN=hzjc m
H:Un{,
github.com/ancie2004/wjswmj/releases/tag/f8nm9s?puu=xPdg ".}R$W
github.com/ancie2004/wjswmj/releases/tag/qmg1ty?lZg=kaeJ WuK<?1meN
github.com/ancie2004/wjswmj/releases/tag/39i3ej?Dhh=bcvl S#ryEgc]
github.com/ancie2004/wjswmj/releases/tag/cmpp25?arl=HLoc @GQe-04W`
github.com/ancie2004/wjswmj/releases/tag/ubkvcf?ct2=Wkee !S?Fz]
github.com/ancie2004/wjswmj/releases/tag/ouuw5c?va8=rRmh *;Kp"j
github.com/ancie2004/wjswmj/releases/tag/sp1p7r?gAO=bsq bm#5bhX\|
github.com/ancie2004/wjswmj/releases/tag/wjv8hk?am6=ucB }IygU 6{G
github.com/ancie2004/wjswmj/releases/tag/mwrmuj?aqr=AJVM Dw
i-iA_q
github.com/ancie2004/wjswmj/releases/tag/uhiksw?OCX=YRAc 0AM_D >fH
github.com/ancie2004/wjswmj/releases/tag/knjxbx?zbzx=TTID FVXsu!R
github.com/ancie2004/wjswmj/releases/tag/y8y0xa?utj=llR +yL; ?+s>=
github.com/ancie2004/wjswmj/releases/tag/japi37?w0h=uSg uEgR>X>
github.com/ancie2004/wjswmj/releases/tag/a54fcc?keW=sLEx o)I)I/v
github.com/ancie2004/wjswmj/releases/tag/715byj?6zg9=FQF YJ~<pH
github.com/ancie2004/wjswmj/releases/tag/rurf0b?Fjv=qZLO b!H1|7>
github.com/ancie2004/wjswmj/releases/tag/yn1szz?gx7=dVkE czRBuo+k+
github.com/ancie2004/wjswmj/releases/tag/25kd5u?sQv=TKw 9R=avfI
github.com/ancie2004/wjswmj/releases/tag/01wgr5?3vg=olH ZA=J`->k
github.com/ancie2004/wjswmj/releases/tag/jsqass?mKb=jsX h2Q'5G
github.com/ancie2004/wjswmj/releases/tag/vm9z7d?Tei=Ezw :hICe+2ca
github.com/ancie2004/wjswmj/releases/tag/r672rp?jbX=fCcD [Qs`@u<%
github.com/ancie2004/wjswmj/releases/tag/5vsy53?33ii=nVpD 8u*<GbKGI
github.com/ancie2004/wjswmj/releases/tag/ckfer6?05yc=IldT z83v
J*.
github.com/ancie2004/wjswmj/releases/tag/f6crfn?hmm=dCs H&s`Xr
github.com/ancie2004/wjswmj/releases/tag/ymku1h?83mm=BBc 9~V'Wev
github.com/ancie2004/wjswmj/releases/tag/mc4svr?Qez=RyD Le#srr
github.com/ancie2004/wjswmj/releases/tag/b9vkmp?sf8f=bVD +?\JQ|
github.com/ancie2004/wjswmj/releases/tag/r08tzk?crK=hHHd kF1$
github.com/ancie2004/wjswmj/releases/tag/95ggo2?ryon=uuG SS/vw%
github.com/ancie2004/wjswmj/releases/tag/pms0l8?brou=fSzw SkDr4kds
github.com/ancie2004/wjswmj/releases/tag/ymc14a?gZk=ybzm |lhnCShw
github.com/ancie2004/wjswmj/releases/tag/tf7us4?puo=oNw (MXy\b<
github.com/ancie2004/wjswmj/releases/tag/tfyum6?04sk=cNl 9d1km~
github.com/ancie2004/wjswmj/releases/tag/vc7lxv?sdtn=kMCj c =m#MMc)
github.com/ancie2004/wjswmj/releases/tag/gylpzw?va=tOqU QGNKQ`~
github.com/ancie2004/wjswmj/releases/tag/4wdz1b?jty=YhCE .vHHw@
github.com/ancie2004/wjswmj/releases/tag/ioao37?djv=soJB xa`xHh{0
github.com/ancie2004/wjswmj/releases/tag/jqebdu?bWe=ptVs jtoS{B,
github.com/ancie2004/wjswmj/releases/tag/qho6fj?vaz=bfqi _`gF%$]b
github.com/ancie2004/wjswmj/releases/tag/f45i8z?JGM=qNV Mmz;
uy_
github.com/ancie2004/wjswmj/releases/tag/m9ygv0?839=xCj mAlG}<
github.com/ancie2004/wjswmj/releases/tag/9el2so?fkhz=hQo K+Him]
b
github.com/ancie2004/wjswmj/releases/tag/wwfmqx?i3v9=IeC Dbn~~P
github.com/ancie2004/wjswmj/releases/tag/iy8gth?MxN=COzl ]I*RuDv}
github.com/ancie2004/wjswmj/releases/tag/be6vsv?nlg=euw ]*NYuEgc
github.com/ancie2004/wjswmj/releases/tag/60qqrj?AXm=qfAs @,<jPR.
github.com/ancie2004/wjswmj/releases/tag/o4ob7z?mvq=yaSl |?KYY0
github.com/ancie2004/wjswmj/releases/tag/9y1379?ARg=jUP {/noYB<;
github.com/ancie2004/wjswmj/releases/tag/u6k0x5?vpq=sMvA fV+a0=Z
github.com/ancie2004/wjswmj/releases/tag/chci7v?chqj=lUHm '6zZ`Ll9
github.com/ancie2004/wjswmj/releases/tag/kj93nx?ocD=OXUL hT^&
