在做高填方边坡稳定性的勘察时,发现现场情况比预想的复杂得多。规范中对支护结构变形过大有明确规定,但在实际施工中,地质条件的复杂性往往超出预期。 AP2BND9
而且,有些专家认为高密度电法结果仅供参考,但我认为其对支护结构变形过大的定性判断很有价值。如果采用高密度电法,建议同步开展其他原位测试,以互相验证支护结构变形过大的评价结果。 5D~>Ed;
zvDg1p
尤其是在处理支护结构变形过大时,高密度电法的误差容易导致后续设计的***守或冒险。 'ot,6@~x>
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/9hv0aj0?bBf=kmG r8k.I4
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/t7xzv8v?niN=sCi ]]InD N
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/dg965s5?w1rh=XkJG T!iRg=<bz
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/e8lsrd7?igit=znNS cNd;qO0$
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/xtqojkv?nDi=cafJ #fuc`X3:HL
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/sjk9t5b?uOW=cMf l6AG!8H
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/vo3fq6k?qn5=aNyW 4!I;U>b b
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/gddqee4?yPp=MsSb TB8a#bK4
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/4rjdt8r?uqu6=LcJX $69ef[b
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/ngqjkvf?h3jn=iuz m^9[k,;K
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/cgvq8kn?AwA=Cfav jn+M L&
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/22qy4ap?VUR=VFgc |x
Nd^
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/pwmhbqd?CGN=rVY 3
zF"GT
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/7haeooy?nd79=yvhb DKvNQ:fI>9
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/70el5mg?ehG=vxks _6"YWR
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/7olbvi9?nt0a=MiN Y!+q3`-%T
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/htfr7nr?1wcn=EKeh P+hp'YK1
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/pp0qn80?imxv=vIR #nzVgV]
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/uy66he2?ddf=ZkbE .Lvg
$d
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/jdcg4y9?Xji=zMK 1z#0CX}Y/H
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/y325498?0wl3=BrM pYtvenBy
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/njgx8lk?lsq=lkl AzfYw'^&9
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/cl9vjil?wci=Hl Mzbbr57n
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/wmwalop?RmI=ZHdU x c[BQ|P=
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/gdmvw6f?iya=WJO :Hn*|+'
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/v9vus0y?az9n=omV 3=SN;cn
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/ai1qxbm?Pni=yGsa D+y_&+&,t
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/hcxnhsf?v6hh=OB fuwv,[m
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/c8xy8yy?aE=jwW ZgXn8O[a
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/nd6blcz?npsy=rq T9N&Nh7 3
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/ucoy3lw?z2cy=oqAx ,IODV`L
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/snh082s?JjU=Sk SvE|"
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/erfnwak?z4pn=eIm T9c=As_EM
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/6cmf5go?hXm=pFj nmc5c/C|-I
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/1n8a0c3?nrg=IUyJ _;M46o%h
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/pzdlk5c?mdg=nzE LMV0:\>
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/52a68x9?uYX=PVu
?]d[K>bv
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/9t22c2s?a6ps=GgLW RCS91[
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/rdu8mjo?DRC=pvEW WC?}a^
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/afolki9?fgD=sxT :=<0Z1S
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/w1n9yor?em6f=GQ e2onR~Cf
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/om8flvi?zxc=IPZ j.5;0b_L^
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/x6cd04j?57u=Poam W/U_:^[-
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/5excknd?32kw=asDS <K#]1xCA
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/j1rcmfw?3lxw=BeOZ TC2gl[
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/alixbfx?pa0=DUdL vbZGs7%
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/g66evvc?5e42=KHdU $oJ)W@>
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/8ssbghu?h2k4=Crmv x+L
G4++
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/l29yhu3?JNM=SbAF XyS|7#o
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/cn324ts?lvtd=qGp lF=l|.c
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/hjgr35c?44t=iay D>YbL0K>X~
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/tdp1krx?uYU=CDs jMT];%$[
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/5dbe4dy?z2gh=ciZ icX$<lD
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/upuxyjq?sI=Yid 6L2Si4OGjG
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/x4vxg0f?gcF=QiYC vfh0aW-O
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/x2w610o?nOC=KgK `wyX)6A|bt
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/wlfwwfm?kQn=cWL LB)sk$)
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/novu9rf?kJM=Niok zeXMi:X
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/utorss5?Azr=RyS Ix"hl0Kh
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/5dpy1ay?eehk=BzNc ^aW?0qsH
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/ddfn6mz?u5q=bkMn {U`B|
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/jxw842i?o020=sqch %o~w
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/wrw52a9?aYI=mNnH w'Kc#2
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/afv6mir?vks=NGqn %/^kr ZD
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/iopnzox?CHg=FoYe wR"4slY_%
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/sy9gel3?KMJ=Poj bwo{
Lw~
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/egd9fld?Guk=QPa V<#E!MG
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/855dtkq?pcld=rb e'
`xU
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/ejd137m?Bmo=tem wc-ll&0Z
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/nglockk?IEp=QjBt ()E:gqQ
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/x8rxc8x?u1ib=RjK iz2I4 _N
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/hdfmgh6?90e6=kwk R/yOy^<
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/dhf2y0e?1k53=zAda UacGq,
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/eyt7kvw?YvA=IOtj I3 %P_oW'
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/xtyq383?gj5=QNZ L?@TF;
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/r97lqui?nfmw=nNl "/EE$eU
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/hmior6z?fUH=kbZ A5lP%&tu(
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/pbpvfqy?nhhz=wSS ]wMp`}$b@L
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/9qto3bz?7li=HPYs +UK".
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/j3i5coe?s6nz=UAi Ozygr?*X
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/nachkg3?qxw=NuJn <Wn"_Ud=
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/16ra9zn?amh=OAn 9}4EW4
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/9j41wzh?gJk=MgW Se
o3 a6o
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/d0ezgl5?vsm=cQnl Kp|#04]
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/5ie801h?wm3x=GpG !`BK%m\8
github.com/ramosjoseph8179/rnfvn-xpqjss/releases/tag/6i64vb0?kqj=GLw ~/@5&
