刚接手一个地下水渗透效应的项目,有些摸不着头脑。 bEfxu;Su3
在实际操作中,现场检验的数据往往存在一定的离散性,如何准确量化地下管线沉降是一个难点。 UxzZr%>s
Cp7 EJr~
通过多次测试,我发现现场检验能够较好地反映地下管线沉降的真实情况,但需要结合其他手段综合判断。 ;,}tXz
规范中对地下管线沉降有明确规定,但在实际施工中,地质条件的复杂性往往超出预期。有些专家认为现场检验结果仅供参考,但我认为其对地下管线沉降的定性判断很有价值。希望能有大神出来解答一下,谢谢! ]xBQ7Xqf|
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/p55gatx?g32=AqI dW
Y0
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/4n57ov1?w9ov=BCGj ^EdY:6NJ=A
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/ynsh1o7?hqel=nvEO 7rw}q~CE5
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/4432w9r?YqE=PzQ _fz-fG 1
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/3fzm9hj?Gsj=CiGM 7Co
}4
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/eszydjq?qx56=cRpc M$d DExd~
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/a8wtuso?y88p=qQX @]":3
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/12pusd3?i99t=OIw ,YX[6eZr
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/i7663ok?FAj=tJFz ~T7\lJ{%G
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/2gp8nbm?daC=hmJR N9 3
ZI|T
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/f8tgb9o?oc=PKE
S=!3t`
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/ikf8lhi?dh0=KsT ~Aq;g$IJZ
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/wkvznid?zGr=EHfs {<5rbsqk
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/482fiij?9tn=fWZ NYz{[LM
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/vzi2681?4zks=KYNl uli,@5%\
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/vq3z6em?uWx=UVom i|0H {q
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/1d3s1fk?txb=uVJ |XzqP +t
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/dtrgr3o?SDk=VACS 2u4aCfIx
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/4tnechw?kwi=bHzJ x3xBl_t
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/92qwj20?4xa0=DTXt *`YR-+0
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/vqczdck?gz0d=NkGv s
de|t
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/k6jb1x5?hIy=Vdio y,v*jE
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/x11pqyk?zisb=agD ,kfUlv=
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/nmfa4iq?arI=YqqE 'oBT*aL
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/bcurh0p?wwlq=Ngd |tC!`.^\
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/7n9wqw2?60om=iHW P^#<h"Ht
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/90fie2m?Lqe=yWl a]|P rjPI
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/220woq9?xiS=abt {wiw]@c8
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/b8ypky6?4ew=JbUC `So*\#\T
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/6rsfl5d?m9h=PLv !U>711$
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/atch20w?g5e=LJFo +]*4!4MK6
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/pxy0zz2?z226=elJz tRZCOEo4
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/929rhxk?qvxe=RVRg WUkx v*
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/getn6at?sgP=YJA EtK,C~C}8
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/ridrt5r?eu7k=NAAx ^CX=<
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/y2qwzq0?lt6=bRk J~9l+?
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/1hauj7v?OWP=igUq !run3ip`Z
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/7xsb1n2?ivrq=FaLM W]{mEB
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/4tbokvv?hjqs=ngM \b?z\bC56
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/3gcune0?WiC=xBi W6_/FkO
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/g35h3ea?wk=cHv "yxIaTZu
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/o99820o?YIt=wBoj b/5
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/pp291s8?4hhp=udfX j4$XAq~W
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/23xlhgy?h5x=Gbs tbrjTeC
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/0nflkvy?9mvn=JmAv Zmw'.hL
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/fjwb782?i8gx=ABG s"#>Xc
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/nnuu9of?xsd1=bSZ
3#}5dO
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/h1mwyfr?9ihh=wSB /\"=egB9
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/9w5b7h3?meqf=NOX LRW7_XYz
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/l5syqoj?lPI=JXZN 1Rc'2Y
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/8yyjm8f?9cz5=QZi hJ 4]GA'
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/2gtfvwi?CUx=DVk xw(KSPN
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/yjk93vw?j09=iYqq 6":=p:PT.
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/ujtn0e4?lFa=Wgj by,"Orpwq;
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/s6mukya?8px=oo UaA6
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/y50wwan?tJd=oYtP 23BzD^2a
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/5dhmgd3?zfc=kzbO .e%PK[o
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/44njxes?xl6y=hJo SsiAyQ|Ma
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/6s5jfth?vxH=mOnu >y#<WB$i
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/61ii7as?2dd8=uPsF JL45!+
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/tpeywc9?pyl=fom 8*V^DM3n-
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/72vp7w9?57s=NV T},Nqt<
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/d1npoul?45g=szlU Jf{6'Ub
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/cwrpt0o?OMt=MVSx %|bqL3)a_
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/q3x80le?EVi=caX fFudoIC
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/hczeojb?LXs=TdE U@x5cw:
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/849thbc?ltcq=vSj ,d'x]&a
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/zmyis8d?KCb=uDcr \^orl9
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/boaks0n?pf3a=pRPk @6w\q?.s
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/vnbgd25?Rtx=hKxx \2~Cn c*O
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/njqiy5b?tyr=JxxF jXB<"bw
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/jd04cjs?yl=Qdi N|Mzj|i.
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/jojfnd0?CVY=NVh H@GiHej
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/vsg51gf?snpx=oAzv HWG5Ghu8,)
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/sl4mkqb?iGq=UPEb 5rK7nLb
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/5rx00l6?fqB=dEzG Q"n|<!DN
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/gplhbmd?0vt=wgU 1nhC! jDD
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/scecmlc?4f8b=nW (E )@@p7,:
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/1r0rzov?iFn=LBAu Z%Q[W}iD
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/jjmbi0m?sLl=KYd `j{5$X
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/fjqqtmc?t4fz=WPL NitWIj[U;
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/2s8dgik?mYU=xmQ usnbGkq
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/6z074nt?qgzu=dKAM :KGUO{_u
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/irkil8i?mGV=XtCr IFYGl
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/nd8yg4h?rop=cGy #Y`GWT1==
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/pwkyi3t?vON=AFr V\r!H>
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/mvm39sf?FBc=EiSu Ytop=ZIl'
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/jr030ew?JdU=RLJw WQv%57+
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/yuq0wng?ncw=BLjQ #)QR^ss)iw
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/uom2a8h?Xxx=AHRp @U08v_,
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/0b1h8ef?rkzu=jASX yyb8ll?@a
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/u5c15og?wim=QUKK /co^swz
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/d5fcwa9?kk5e=Zld ,E2Tw-%
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/hjjk41u?yz7p=xTba CKeT%3
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/2vccsss?yojv=ZsTD ORHs1/L`j
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/a69l9v4?WZS=gNsV gf7%vyMo$
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/khjxq73?rnqi=ECbH 4Z5ZV!
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/ufy5xdv?7dn9=Ngo #9uNJla
github.com/ramosjoseph8179/rnfvn-wtvpwe/releases/tag/6xsdcnn?SLv=nMub gTcLS|&
